09-07-2019, 01:43 PM
this my first post ever, so i will try my best. I am a new owner of a NoV-64d modul and have made two experience, that I like to share.
First on my Windows 10 Pro 64 bit PC the programmer don't work with a long USB-cable plug into a blue USB-3.1-Port. The steps
- Programming ROM
- Progragmming EPROM
- Verify ROM
are working.
Next I see "Error..." and a Messagebox with "The board is not responding…". Plugged into the HP-41CX, the NoV-64d was invisible then.
It works well with a short USB cable on a black USB 2.0 port.
Second I programm a AECROM into the NoV-64d and make COPYROM to page 10 and 11. The part with the unit-conversen works very well. I can switch the mode with holding down the ON-key. No Problem so far.
Then I try to use the PROG-command. I can Input the Programname and the Formular. After R/S the HP-41CX go off suddenly. The very same is happen with my iPhone App i41CX with HEPAX in Port1 and the AECROM in any other port.
A workaround is to connect a HP 82143A Printer. Then the HP-41CX don't go off after the R/S and I can "ENTER:LBL,CONS.". Again it is the same with the real HP-41CX and the i41CX App, where a Printer is build in and can be disabled.
Without HEPAX in Port1 there is no Problem with the AECROM in the App.
Best Regards
Klaus
- Programming ROM
- Verify ROM
are working.
Best Regards
Klaus
