I recently bought a Prime G2 and I'm still playing around with it, looking at the demo programs. Every time I run the Demo_BREAK the calculator crashes.
EXPORT Demo_BREAK()
FOR A FROM 1 TO 10 DO
B:= (A+3) MOD 5;
IF B==1 THEN BREAK;
The crash occurs when the program exits, so if I add a message box, the message box text is displayed and then the calculator crashes. Following advice I have tried memory resets and formatting the C drive in recovery mode with no success.
Does this happen to anyone else's G2?
Software Version 2.1.14181 (2018 1016)
Thanks.
Steve
It might be because you haven't declared your variables. This could cause instability (I have had the 39Gii (Prime's smaller brother) hang due to this requiring battery removal).
EXPORT Demo_BREAK()
LOCAL A, B; <-- add this line
B:= (A+3) MOD 5;
IF B==1 THEN BREAK;
-Bart
(09-02-2019 10:05 AM)BartDB Wrote: [ -> ]Hi,
EXPORT Demo_BREAK()
B:= (A+3) MOD 5;
IF B==1 THEN BREAK;
-Bart
Thanks for the reply. The program is one of the built in demos on the G2 so shouldn't need altered. I tried what you suggested though and still get the crash.
Steve
Seems like BREAK is doing exactly what it should. It breaks the program, the calculator, and everything!
I have had the emulator crash too.
At first all seemed fine, then I had entered a formula on the Home screen.
With the formula and result still on the Home screen,
go to Program, run Demo_BREAK, it executes fine
when trying to change back to Home the emulator hangs.
(similar with functions on the CAS screen, if doing something else after running the program, emulator soon hangs).
So definitely something bad there, that has probably always been there but now precipitating with the new G2 hardware.
-Bart
(09-02-2019 03:41 PM)BartDB Wrote: [ -> ]Hi,
Steve
-Bart
Thanks for the reply Bart,
I'm beginning to suspect that the G2 just doesn't like the BREAK command. I have managed to stop the calculator crashing in the demo program by adding an extra IFERR block.
#pragma mode( separator(.,;) integer(h32) )
EXPORT Demo_BREAK()
B:= (A+3) MOD 5;
IF B==1 THEN
MSGBOX("END");
IFERR BREAK;
THEN END;
MSGBOX("A "+A+ " B "+B);
BREAK;
However I'd be reluctant to do this in a complicated program.
Question now is it just my G2 or is it a general problem?
(09-01-2019 05:59 PM)sc99cs Wrote: [ -> ]Hello,
EXPORT Demo_BREAK()
B:= (A+3) MOD 5;
IF B==1 THEN BREAK;
Thanks.
Steve
It happens to me as well. Are we about due for a firmware update? Someone mentioned we might be. I hope the BREAK problem was fixed. If we could choose only one or the other (XOR?), I'd rather have existing bugs squashed than new features!
Bonjour
Sauf erreur de ma part, ce bogue était présent sur les modèles G1 et
avait était corrigé lors d'une mise à jour.
Espérons que la G2 ne nous ressorte pas tous les bogues que la G1 a connu.
Hello
Unless I'm mistaken, this bug was present on the G1 and
had been fixed during an update.
Let's hope the G2 doesn't bring up all the bugs the G1 has known.
Thanks Tom and Tyann.
At least I now know that my G2 isn't faulty as such but this is a general problem with the calculator.
Steve
Unfortunately I do not have a G2 to test.
However, another way to do the program:
EXPORT Another_Loop()
LOCAL A, B;
A:=0;
WHILE B<>1 DO
A:=A+1;
B:= (A+3) MOD 5;
MSGBOX(A);
or the following:
EXPORT Demo_BREAK()
LOCAL A, B;
B:= (A+3) MOD 5;
IF B==1 THEN
MSGBOX(A);
KILL;
However, this one will show an error message after the MSGBOX result is displayed.
-Bart
(09-02-2019 05:33 PM)BartDB Wrote: [ -> ]Hi,
LOCAL A, B;
A:=0;
WHILE B<>1 DO
A:=A+1;
B:= (A+3) MOD 5;
MSGBOX(A);
or the following:
EXPORT Demo_BREAK()
LOCAL A, B;
B:= (A+3) MOD 5;
IF B==1 THEN
MSGBOX(A);
KILL;
-Bart
Posts crossed but I'll give this a try.
I am in same situation as original poster. New G2 and latest update installed - calculator crashes. Program runs fine on my other HP Prime non-G2.
