(08-21-2019 07:34 PM)Podalirius Wrote: [ -> ]I reinstalled 9CFA and ALL WORKS VERY WELL!!!
I am sorry for my mistake.
No need to be sorry, learning is a difficult path and mistakes are part of it.
(08-21-2019 07:34 PM)Podalirius Wrote: [ -> ]A little doubt: to swap from MMU 0 to one of the MMU installed by CFGINI, is enough to type "9???" PPLUG or I have to use the code that Mr. Monte posted in this help?
Actually you do not swap, well ... you can, but in all our examples up to now, we never did.
So for our limited view of things, you override your MMU configuration set 0 with another MMU configuration set 1 to F with RCLCFG or from one of the "9???" with PLUG or PPLUG.
(08-21-2019 07:34 PM)Podalirius Wrote: [ -> ]For example, to change to another configuration:
MMUDIS
MMUCLR
"YFNX" PLUGH
MMUEN
RCLCFG ?
In general yes but you must map the "YFNX" module to the same page as the configuration you want to import.
Ex #1: for set 4 or "9PWR", "YFNX" is mapped to page 7 (PLUGH)
Ex #2: for set F or "9HIL", "YFNX" is mapped to page D (PLUG3U)
(08-21-2019 07:34 PM)Podalirius Wrote: [ -> ]Of course I don't select 9HIL because we have your configuration!
Not so sure, if you save it like my last post suggested it (STOCFG 2) then you use "9CFB" not "9HIL".
Configuration names and numbers ...
Name Set MMU-Type Description
0 Primary Active configuration used by the system
"9CFA" 1 Primary Alternate Configuration A
"9CFB" 2 Primary Alternate Configuration B
"9BAS" 3 Primary Basic Configuration
"9PWR" 4 Secondary Power-User Configuration
"9MTH" 5 Secondary Mathematics Configuration
"9SCI" 6 Secondary Scientist’s Configuration
"9INF" 7 Secondary Informatics Configuration
"9PRG" 8 Secondary Programming Configuration
"9ELE" 9 Secondary Electrical Engineering Configuration
"9MEC" A Secondary Mechanical Engineering Configuration
"9MAP" B Secondary Maps & Words Configuration
"9PLY" C Secondary Playground Configuration
"9BGM" D Secondary Brainy Games Configuration
"9CST" E Secondary Custom Configuration
"9HIL" F Secondary HP-IL Configuration
Note: configuration names was taken from the 41CL Calculator Manual (sy41cl.pdf) page 59 (rev. 2019-06-22)
Some of the functions affecting MMU Registers ...
Function Parm From Description
MMUCLP YFNX Erase RAM Primary MMU Registers (sets 0 to 3 are cleared)
MMUCLS YFNX Erase RAM Secondary MMU Registers (sets 4 to F are cleared)
CFGINI YFNF Copy default values from ROM to RAM Secondary MMU Registers (sets 4 to F)
PLUG "Name" YFNX Copy specified configuration name to active configuration (set 0)
PPLUG "Name" YFNX Copy specified configuration name to active configuration (set 0)
RCLCFG 1 to F YFNX Copy specified configuration set (1..F) to active configuration (set 0)
STOCFG 1 to F YFNX Copy active configuration (set 0) to specified configuration set (1..F)
EXCFG 1 to F YFNX Exchange active configuration (set 0) with specified configuration set (1..F)
LOCK 0 to F YFNX Lock specified page in active configuration (set 0)
UNLOCK 0 to F YFNX Unlock specified page in active configuration (set 0)
Note: MMU locked entries are not copied or exchanged. (YFNX is always locked and cannot be unlocked while MMU is enabled)
Also, like Monte said in an earlier port, you can lock the HePaX ROM+RAM in place, preventing an override of your HePaX setup by another configuration.
In your case to lock the pages, the procedure is:
LOCK B // lock HePaX ROM
LOCK C // lock HePaX RAM page 1
LOCK D // lock HePaX RAM page 2
LOCK E // lock HePaX RAM page 3
LOCK F // lock HePaX RAM page 4
To unlock the pages, the procedure is:
UNLOCK B // unlock HePaX ROM
UNLOCK C // unlock HePaX RAM page 1
UNLOCK D // unlock HePaX RAM page 2
UNLOCK E // unlock HePaX RAM page 3
UNLOCK F // unlock HePaX RAM page 4
Sylvain
edit: typo & added some details
