08-10-2019, 03:13 PM
As has been well documented here, the HP48 timekeeping is 'not too hot'.
As we know, the crystal is a 'standard' 32768Hz crystal that is multipiied up to get the calculators '4MHz' operating frequency. (I wonder if this multiplication varies with OS version? I'm currently studying a ver R and a ver L.)
Has anyone studied or actually executed a replacement of the crystal?
- The physical package is an industry standard type and quite large, so it should be easy mechanically.
- In selecting a replacement, I suspect series resistance, capacitance are critical, but I'm no expert here.
- What was the spec of the original crystal?
I will pursue finding a more accurate replacement (assuming one exists).
TomC
TomC
