08-03-2019, 04:27 AM
08-03-2019, 03:01 PM
08-03-2019, 04:17 PM
[CAS] (With CAS setup Simplify setting to Maximum)
solve(r = ((9/4)*p+25),p) ==> {(4*r-100)/9}
Note: Used lower case variables here, Upper case variables are reserved.
08-03-2019, 06:20 PM
(08-03-2019 04:17 PM)DrD Wrote: [ -> ][CAS] (With CAS setup Simplify setting to Maximum)
You can also use the uppercase vars, but they have to be inside single quotes. Just be careful if you evaluate the expression, the calculator will use the stored values.
simplify(solve('R' = ((9/4)*'P'+25),'P')) ==> {(4*R-100)/9}
08-04-2019, 03:52 PM
(08-03-2019 04:17 PM)DrD Wrote: [ -> ][CAS] (With CAS setup Simplify setting to Maximum)I get "Bad argument value" when i input your solution
08-05-2019, 12:00 PM
Just make sure you work in CAS "environment" and use lowercase letters in the equation
Also double-check your writing.
Best,
Aries
Best,
Aries
