Best Pi approximation using decimal digits permutations:
85910 / 27346 = 355 / 113 ≈ 3.141592
920, abs error ≈ 2.67e-7
Proof:
Since 355/113 is one of Pi's convergents, and the next convergent is 103993/33102
A better ratio, if exist, must be a semi-convergent:
(52163+355k)/(16604+113k), k>=0
(52163+355k) + (16604+113k) (mod 9) ≡ 7 ≠ 0
Thus, better ratio does not exist.
Update: With hex digits permutations, this produce best pi approximation
0xFE86C29B / 0x5104AD73 = 4270244507 / 1359261043 ≈ 3.141592653590, abs error ≈ 2.94e-13
(07-24-2019 10:30 AM)BartDB Wrote: [ -> ] (07-23-2019 06:18 PM)Gerson W. Barbosa Wrote: [ -> ]That is,
π = 22/7 - ∫(0,1,X^4*(1-X)^4/(1+X^2),X)
Similar equalities can be automatically obtained on the HP-50g with help of a small User-RPL program. The Egyptian Fractions part --
WHILE SWAP DUP -5. ALOG SQ >
REPEAT DUP INV CEIL DUP UNROT INV - UNROT +
END 6. ALOG SQ * SWAP
-- is borrowed code from forumer
3298 here.
For example,
22 ENTER 7
\<< / \->NUM DUP IP R\->I DUP UNROT - { }
END 6. ALOG SQ * SWAP NIP DUP SIZE NOT NOT
{ 1 - X SWAP ^ 0 + \GSLIST + } { DROP } IFTE
4 X 2 ^ 1 + / - COLLECT
EVAL
'(X^8+X^6+3*X^2-1)/(X^2+1)'
Indeed,
'∫(0,1,(X^8+X^6+3*X^2-1)/(X^2+1),X)'
EVAL DISTRIB
'-π+22/7'
That is,
π = 22/7 - ∫(0,1,(X^8+X^6+3*X^2-1)/(X^2+1),X)
Notice this is a different integrand polynomial. The original one is more elaborate so that the difference area is continuous, not distributed between both sides of the x-axis.
Likewise,
π = 377/120 - ∫(0,1,(X^61+X^59+X^9+X^7+3*X^2-1)/(X^2+1),X)
and
π = 3 + ∫(0,1,(-3*X^2+1)/(X^2+1),X)
Yeah, mine was always 355/113. I used it a lot (with 4-bangers!) before calculators became available with a dedicated Pi key. It was easy to remember and pretty darned accurate.
(07-22-2019 03:14 PM)Gerson W. Barbosa Wrote: [ -> ]Now, time for a little riddle.
The following appears to be a pretty bad approximation. It really is, depending on how we look at it. However, when I change only one digit or, equivalently, when I remove one of its parts, it returns a perfect 10-digit result on my HP-41C, which I am using to evaluate it. BTW, I have used the HP-41C for this one because of its 10-digit display and a seldom used useful built-in function which most of my Voyagers lack. Too many tips, but it doesn't matter :-)
Have fun!
\(\frac{\frac{26}{7}-\frac{6}{11211}}{\left (\frac{4141}{3313}\right ) ^{\frac{3}{4}}}\)
There hasn’t been any response to this puzzle, but it’s my fault. As I said, I forgot to mention something else had to be assumed. I will post the answer tomorrow, but I’ll give you another tip, in case you still want to give it a try. Remember numbers are not always what they look, as in the phrase “There are 10 types of people, those who understand binary and those who don’t”.
See my latest post ‘Proving the Duffin-Schaeffer conjecture’- if I’d read this one first I’d have used it as a reply instead.
(08-14-2019 09:14 PM)Gerson W. Barbosa Wrote: [ -> ]\(\frac{\frac{26}{7}-\frac{6}{11211}}{\left (\frac{4141}{3313}\right ) ^{\frac{3}{4}}}\)
Puzzle solved
If assumed all
octal numbers, numerator converted back to
decimal:
22/7 - 6/4745 = 104348/33215 = 3.141592654 (10 digits, rounded)
This value happened to be one of Pi convergents, from continued fraction terms: [3;7,15,1,292,1]
Thus, all is needed is to "remove" the denominator, by changing exponent to 0/4
(08-14-2019 10:46 PM)Albert Chan Wrote: [ -> ] (08-14-2019 09:14 PM)Gerson W. Barbosa Wrote: [ -> ]\(\frac{\frac{26}{7}-\frac{6}{11211}}{\left (\frac{4141}{3313}\right ) ^{\frac{3}{4}}}\)
Puzzle solved
If assumed all octal numbers, numerator converted back to decimal:
Exactly, congrats!
Perhaps I should have chosen a higher base to make it a bit more difficult to check :-)
(08-14-2019 11:09 PM)Gerson W. Barbosa Wrote: [ -> ]Perhaps I should have chosen a higher base to make it a bit more difficult to check :-)
It is even harder if the
base goes negative.
For negative base, we do not need the minus sign.
Example, your original puzzle in
negaoctal base: (166/7 + 6/172627) / (14241/15473)
3/4
(07-26-2019 11:02 PM)Bill Duncan Wrote: [ -> ]Yeah, mine was always 355/113. I used it a lot (with 4-bangers!) before calculators became available with a dedicated Pi key. It was easy to remember and pretty darned accurate.
That's a really good one.
(Made in China)
