07-19-2019, 12:30 PM
An extract from Planning Fuel Conservative Descents in an Airline Environment Using a Small Programmable Calculator, NASA, Scientific & Technical Information Branch, Technical Paper 2393, May-1985 (84 pgs.)
Summary
An investigation into the feasibility of using the open-loop guidance in an airline operational environment was conducted. The algorithm was programmed on a small programmable calculator for use with … A version of the flight-management descent algorithm was implemented on a Hewlett-Packard HP-41CV programmable calculator. Open-loop guidance was provided by the calculator … This report contains a description of the programmable calculator software, the … performance model used in the algorithm computations, and the results of the model-validation and pilot-evaluation flight tests.
Appendix A--Program Flow Chart
Appendix B--Calculator Program
Descriptions, explanations, diagrams, equations, tables, illustrations, figures, flowcharts, listings etc.; thoroughly documented!
Best!
SlideRule
Summary
Best!
SlideRule
