Held each year, intended for high school students, they include calculator exams.
These HP calculators are now permitted (early on, only TI calculators were permitted):
HP-9G
HP-28 series
HP-38G
HP-39 series
HP-40 series
HP-48 series
HP-49 series
HP-50 series
Exams going back to 2008 can be downloaded from here:
<http://mathcontest.uh.edu/>
Forum members may find this trove of problems amusing, trivial, or (in some cases) worthwhile education in the use of their HP calculator. (Not surprisingly, the HP-50 has some distinct advantages over the other permitted models.)
For example, I found this problem, from the 2019 exam, worthwhile:
A quadrilateral has its vertices (listed in clockwise order) as
(–6.94, –1.2), (–5.16, 3.84), (3.4, 2.18), and (2.46, –6.72).
Give the area of this quadrilateral.
Surveyors among you may recognize this one. A short RPL program on the 50g solves it quickly.
(07-11-2019 03:30 PM)telemachos Wrote: [ -> ](–6.94, –1.2), (–5.16, 3.84), (3.4, 2.18), and (2.46, –6.72).
Another way is to calculate angles θ between 2 diagonals:
Slope m1 = (2.18 + 1.2) / (3.4 + 6.94) = 3.38 / 10.34
Slope m2 = (-6.72 - 3.84) / (2.46 + 5.16) = -10.56 / 7.62
tan(θ) = (m1-m2) / (1 + m1 m2) ≈ 3.13114
sin(θ) = tan(θ) / √(1 + tan(θ)²) ≈ 0.952598
area = ½ product of diagonals * sin(θ) ≈ ½ √(3.38² + 10.34²) * √(10.56² + 7.62²) * 0.952598 = 67.473
(07-11-2019 08:26 PM)John Keith Wrote: [ -> ]It's already done for you.
https://www.hpmuseum.org/forum/thread-11...t=shoelace
For quadrilateral, we could reduce ops with a more compact formula.
Area = ½|(x3-x1)(y4-y2) - (x4-x2)(y3-y1)|
This reduce Shoelace 9 multiply and 8 add/sub to just 3 multiply and 5 subtract.
We could also use this formula for triangle area, by letting {x4,y4} = {x3,y3}
Example, with
XCas:
area4(a,b,c,d) := 0.5*abs(det([c-a,d-b]))
area3(a,b,c) := area4(a,b,c,c)
a,b,c,d := [-6.94,-1.2], [-5.16, 3.84], [3.4,2.18], [2.46,-6.72]
area4(a,b,c,d) → 67.473
area3(a,b,c) + area3(a,c,d) → 23.0486 + 44.4244 = 67.473
I think this makes the best use of the HP-50g's capabilities:
Input:
{ [–6.94 –1.2] [–5.16 3.84] [3.4 2.18] [2.46 –6.72] }
Program (56.5 bytes):
<< DUP HEAD + << CROSS >> DOSUBS ΣLIST ABS 2 / >>
Output: 67.473
(07-12-2019 04:41 PM)telemachos Wrote: [ -> ]I think this makes the best use of the HP-50g's capabilities:
Input:
Output: 67.473
... and the one I've been using in my survey package for 20+ years on HP48G
Input:
Output: 67.473
Very nice program! I think it is the smallest HP-48 compatible shoelace program yet. It can be made even shorter using the null-tag method from
this thread, which shaves 9 bytes off the size, like so:
\<< DUP HEAD + :: CROSS DOSUBS \GSLIST ABS 2 /
I will also link my shoelace thread to this one.
(07-12-2019 04:41 PM)telemachos Wrote: [ -> ]...
Input:
Getting the data into that format could be an awkward exercise if attempting to enter it directly from the calculator's keyboard. It's very close, though, to the format that would exist if you used the built-in MatrixWriter to create it:
[[–6.94 –1.2] [–5.16 3.84] [3.4 2.18] [2.46 –6.72]]
On both the 48GX and the 50g, the following two commands will convert a matrix created by the MatrixWriter to a "list of vectors" format compatible with the given shoelace programs in this thread:
I find the MatrixWriter to be convenient for this type of data entry (as well as maintenance). Judicious use of the various array commands (and AXL on the 50g) can often help to transform an array to a wide variety of useful formats.
