07-09-2019, 11:45 AM
This is a group of programs that compute functions related to necklaces and bracelets (number theory, not jewelry!). The following sequences are covered:
A000011
A000013
A000016
A000029
A000031
A000046
A000048
A001037
A059053
A059076
A179781
A308706
Due to many inter-dependencies between programs, I am posting these programs as a directory object. Additionally, the programs require the GoferLists library and Gerald Hillier's MOB command, which computes the Moebius Mu function. The programs must be used in Exact mode.
In each program, an input of an integer n will return the corresponding A(n) for that sequence. These programs are very computationally intensive and can take several seconds on the physical calculator for large integers.
Leading zeros in the sequence names have been removed to improve readability in the calculator's menu displays.
A000011
A000013
A000016
A000029
A000031
A000046
A000048
A001037
A059053
A059076
A179781
A308706
%%HP: T(3)A(R)F(.);
DIR
A11
\<< DUP A13 SWAP I\->R 2. / IP R\->I 2 SWAP ^ + 2 /
A13
IF DUP I\->R 1. >
THEN DUP DIVIS DUP REVLIST 2 SWAP ^ SWAP 2 * EULER * \GSLIST SWAP 2 * /
ELSE DROP 1
END
A16
IF DUP I\->R 2. >
THEN DUP DIVIS
\<< I\->R 2. MOD
\>> Filter DUP PICK3 SWAP / 2 SWAP ^ SWAP EULER * Sum SWAP 2 * /
ELSE DROP 1
END
A29
\<< DUP A31 OVER I\->R
IF DUP 5. >
THEN SWAP 2 / UNROT 2. MOD { 1 - 2 / 2 SWAP ^ } { 2 / 1 - 2 SWAP DUP2 1 - ^ UNROT ^ + } IFTE +
ELSE DROP
END
A31
\<< DUP I\->R
IF 3. >
THEN DUP DIVIS DUP REVLIST 2 SWAP ^ SWAP EULER * \GSLIST SWAP /
ELSE 1 +
END
A46
IF DUP I\->R 3. >
THEN DUP A48 SWAP A179781 + 2 /
ELSE DROP 1
END
A48
IF DUP I\->R 3. >
THEN DUP DIVIS
\<< I\->R 2. MOD
\>> Filter DUP PICK3 SWAP / 2 SWAP ^ SWAP MOB * Sum SWAP 2 * /
ELSE DROP 1
END
A1037
IF DUP I\->R 1. >
THEN DUP DIVIS DUP REVLIST MOB SWAP 2 SWAP ^ * \GSLIST SWAP /
ELSE 1 +
END
A59053
\<< DUP I\->R
IF 6. >
THEN DUP A13 DUP ROT I\->R 2. / IP R\->I 2 SWAP ^ + 2 / -
ELSE DROP 0
END
A059076
\<< \-> n
\<< 0 n
FOR k k A31
NEXT n 1 + \->LIST 1 2 3 3 n
START OVER 2 *
NEXT n 1 + \->LIST - 2 /
A179781
IF DUP I\->R 3. >
THEN DIVIS DUP REVLIST MOB SWAP I\->R 2. / IP R\->I 2 SWAP ^ * \GSLIST
ELSE DROP 1
END
A308706
IF DUP I\->R 6. >
THEN DUP A48 SWAP A179781 - 2 /
ELSE DROP 0
END
END
