Full Version: Earthquake: Earthquake Calculations
Quake calculates M0, Magnitude and energy of a quake, and compares quakes.
All of the formulae here can be applied to earthquakes, many can also be applied to other planets.
Quake Version 1.0 calculates M0, Magnitude and energy of quakes, and compares quakes.
 LOCAL CRID:="Quake V1.0: 2019 StephenG1CMZ";
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT("Earthquake calculations are estimates");
  PRINT("and can be calculated differently.");
  PRINT("No liabilIty is accepted");
  WAIT;
 //STD MATH
 LOG10(NUM)
 //AVOID RISK OF MISTAKING LOGS
  RETURN LOG(NUM);
 //END MATH
 EXPORT M0Nm(RigidityNm2,Aream2,Slipm)
 //Calculate SeismicMoment in Nm^2
 //=rigidity x area x slip
 //The rigidity of rock is a constant number based on the rock type. It has units of pressure. Typical assumptions are on the order of 3 x 10^10 N/m2.
 //Slip is a length and it is on the order of centimeters (meters for a great earthquake).
 //Area is in units of length2 and is often on the order of km2.
 //The units for seismic moment are then Nm (newton meters).
 //As an example, the 2004 26 December Sumatra-Andaman earthquake had the following dimensions as reported by Lay et al. (2005): Its slip averaged about 5 m, its rupture length was about 1300 km and the fault width was between 160 - 240 km. Assuming a rigidity of 3 x 10^10 N/m2 gives us a seismic moment of 4.4 x 10^22Nm.
  LOCAL Rigidity:=RigidityNm2;
  LOCAL Area:=Aream2;
  LOCAL Slip:=Slipm;
  RETURN Rigidity*Area*Slip;
 MW(M0)
  //Calculate Mw = (2/3)*logM0 - 6.05
  LOCAL MM:=(2/3)*LOG10(M0)-6.05;
  RETURN MM;
 EXPORT Magnitude(RigidityNm2,Aream2,Slipm)
  RETURN MW(M0Nm(RigidityNm2,Aream2,Slipm));
 //These magnitudes are approximations to Richter scale but not same
 EXPORT Magnitude_(M0)
  RETURN MW(M0);
 EXPORT EnergyJ(Magnitud) // //"Magnitude" is a reserved word or function
 // Calculate E, where Log10(E) = 5.24 + 1.44M
 //Empirical good for M>5
 //This estimates damaging energy
  RETURN ALOG(5.24+1.44*Magnitud);//J
 EXPORT EnergyH(Magnitud)
  LOCAL HIROSHIMA:=7.4ᴇ12;//J
  RETURN EnergyJ(Magnitud)/HIROSHIMA;
 EXPORT Energyt(Magnitud)
  LOCAL TNT:=4.184ᴇ9;//J PER TONNE
  RETURN EnergyJ(Magnitud)/TNT;
 //Comparing Quakes
 EXPORT RelAmplitude(MagA,MagB)
 //Compare relative amplitude, any order
  LOCAL BIGGER := 10^ABS(MagA-MagB);
  RETURN BIGGER; //unitless
 EXPORT RelEnergy(MagA,MagB)
 //Compare relative energy (damage), any order
  LOCAL BIGGER   := RelAmplitude(MagA,MagB);
  LOCAL STRONGER := 10^(ABS(MagA-MagB)/2)*BIGGER;
  RETURN STRONGER; //unitless
 //Examples
 ExM0()
  // Calculate upper and lower bounds for ex
  PRINT ({M0Nm(3*10^10,1300ᴇ3*(160ᴇ3),5),"..",M0Nm(3*10^10,1300ᴇ3*(240ᴇ3),5)," =4.4 x 10^22"}+" Nm ");
 ExMW()
  PRINT ({MW(4.4ᴇ22),"=9.05"}+" Magnitude ");
 ExEnergy()
  PRINT({EnergyJ(5.0),EnergyJ(6.0),EnergyJ(7.0),"=2.8ᴇ12 =7.8ᴇ13?? =2.1ᴇ15"}+" J ");
  PRINT({EnergyH(5.0),EnergyH(6.0),EnergyH(7.0)," "}+" Hiroshima ");
  PRINT({EnergyJ(9.05),"=1.84ᴇ18"}+" J ");
  PRINT({Energyt(5.0)}+" tTNT ");
 ExRel()
  PRINT({RelAmplitude(7.1,6.4)," =5"});
  PRINT({RelEnergy   (7.1,6.4)," =11.2"});
 EXPORT Examples()
  ABOUT();
  PRINT();
  PRINT("[=] signifies expected value");
  WAIT;
  ExM0();
  ExMW();
  ExEnergy();
  ExRel();
  WAIT;
 EXPORT HELP()
  ABOUT();
  PRINT();
  PRINT("UNITS");
  PRINT("M0Nm: M0 in Nm");
  PRINT("Magnitude: not exactly Richter");
  PRINT("Energy: in J, Hiroshimas or tonnesTNT");
  PRINT("Relamplitude: unitless");
  PRINT("RelEnergy: unitless ");
  PRINT(" ");
EXPORT References ()
 PRINT("formulae and examples-
https://www.e-education.psu.edu/earth520/content/l7_p4.html");
 PRINT("https://www.hpmuseum.org/forum/thread-13239.html");
 EXPORT QUAKE()
   ABOUT();
Was thinking that I read somewhere in the HP Calculator Owner's Handbook
about earthquake magnitude, later found that was from the HP-45 manual and
couple more User's Handbook.
Sample from the manual:
The 1906 San Francisco earthquake, with a magnitude of 8.25 on the
Richter Scale is estimated to be 105 times greater than the Nicaragua quake of
1972. What would be the magnitude of the latter on the Richter Scale?
The Equation is 8.25 - (LOG 105)
8.25 [ENTER] 105 [LOG] display 2.02 [-] display 6.23
Answer: rating on Richter Scale is 6.23
Gamo
Thanks Gamo.
It's good to see that my results match that example.
If you wanted to solve such a problem with this program - rather than directly using the HP solve on the relevant equation, here is how I checked those results.:
EXPORT EX1906()
 LOCAL KNOWN:=8.25;
 LOCAL GREATER:=105;
 LOCAL SMALLER:=1/GREATER;
 LOCAL CANDIDATES;
 PRINT();
 PRINT("SMALLER "+SMALLER);
 //CHOOSE POSSIBLE
 CANDIDATES:={KNOWN,6.22,6.23};
 //LIST VALUES
 PRINT(CANDIDATES);
 PRINT(Amplitudes(CANDIDATES,1));
 //VISUALLY CHOOSE NUMBER IN LIST
 //CLOSE TO SMALLER AND VERIFY THAT IS
 //GREATER
 PRINT(Amplitudes(CANDIDATES,3));
 //RESELECT CANDIDATES AS NECESSARY
 //SIMILARLY
 //PRINT(Energies({KNOWN,6.9},1));
 //PRINT(Energies({KNOWN,6.9},2));
Actually that uses functions from my next version, which extend the comparison of two magnitudes to a list of values.
Earthquake V 1.1
All functions can now handle lists of values.
Error handling improved.
A list of values can be compared for relative amplitude and energy.
 LOCAL MN:="Earthquake V1.1: ";
 LOCAL CRID:=MN+" © 2019 StephenG1CMZ";
 EXPORT RigidityTypical:=3ᴇ10; //FOR CONVENIENCE
 LOCAL EPSILON:=1ᴇ−308;//SMALLEST NONZERO (LIMIT VALUE USED FOR LOG0)
 ABOUT()
  PRINT();
  PRINT(CRID);
  WAIT;
 //STD MATH
 LOG10(NUM) //AVOID RISK OF MISTAKING LOGS
  RETURN LOG(NUM);//LOG10
 //END MATH
 // Calculations for a single quake
 // Parameters may be numeric or list
 EXPORT AnEarthquake__() //HEADER
  LOCAL Area:=Aream2;
  LOCAL Slip:=Slipm;
 MW(M0)
  LOCAL M00:=MAX(M0,EPSILON);//GUARD M0≤0
  LOCAL MM:=(2/3)*LOG10(M00)-6.05;
  IF MIN(M0)≤0 THEN
   MSGBOX(MN+"MW:\n"+"LOG≤0: "+STRING(M0));
  RETURN MM;
  RETURN MW(M0);
 //Comparing 2 Quakes (unused)
 // Comparing a list of quakes
 EXPORT ComparingEarthquakes__() //HEADER
 EXPORT Amplitudes(Magnitudes,INDX)
 //Compare relative amplitude with indexed value=1
 //Errors return empty list (except LOG:LIMITED)
  LOCAL MAG;
  LOCAL BIGGER;
  CASE
   IF TYPE(Magnitudes)=Type({}) THEN
    IF SIZE(Magnitudes)=0 OR INDX>SIZE(Magnitudes) THEN
     RETURN {};
    MAG:=Magnitudes(INDX);
    BIGGER := 10^(Magnitudes-MAG);
   DEFAULT
    RETURN {}; //{MN+"Provide a list"};
 EXPORT Energies(Magnitudes,INDX)
 //Compare relative energy (damage) with indexed value=1
  LOCAL MAG;
  LOCAL BIGGER;
  LOCAL STRONGER;
   CASE
      RETURN {};
     BIGGER   := Amplitudes(Magnitudes,INDX);
     STRONGER := 10^((Magnitudes-MAG)/2)*BIGGER;
    DEFAULT
 //Examples
 ExM0()
  // Demonstrates mixing list and numeric
  PRINT ({M0Nm(3*10^10,{1300ᴇ3*(160ᴇ3),1300ᴇ3*(240ᴇ3)},5)," =4.4 x 10^22"}+" Nm ");
 ExMW()
 ExEnergy()
  PRINT({EnergyJ({5.0,6.0,7.0}),"=2.8ᴇ12 =7.8ᴇ13?? =2.1ᴇ15"}+" J ");
 ExRel()
  //PRINT(Amplitudes({7.1,6.4},1));
  //PRINT(Energies({7.1,6.4},1));
  PRINT(STRING(Amplitudes({7.1,6.4},2))+" =5");
  PRINT(STRING(Energies({7.1,6.4},2))+" =11.2");
 EXPORT Examples()
  ABOUT();
  //PRINT();
  WAIT;
  ExM0();
  ExMW();
  ExEnergy();
  ExRel();
 EXPORT HELP()
  ABOUT();
  PRINT();
  PRINT("All functions allow lists");
  PRINT("UNITS");
  PRINT("RelativeAmplitudes: unitless");
  PRINT("RelativeEnergies: unitless ");
  PRINT(" ");
 EXPORT References()
 EXPORT EARTHQUAKE() //MAIN
   ABOUT();
Version 1.2:
Estimates M0 and magnitude.
Estimates distance/time.
Compares relative size and strength.
Most functions allow lists of values.
In English, francaise and polskie.
 LOCAL VER:=" V1.2: ";
 LOCAL MN:="Earthquake"+VER;
 LOCAL LANGSE:={" English ",""," French ","","","","",""," Polish "};
 LOCAL LANGS :={" English ",""," français ","","","","",""," polskie "};
 LOCAL LANGS2:={"EN","","FR","","","","","","PL"}; //EN CHINESE FR GERMAN SPANISH DUTCH PORTUGUESE JAPANESE PL
 LOCAL SL:=1;//SL
 //VELOCITY in unit/s (to match Centre distance)
 EXPORT VP; //TYPICAL 6 km/s OR 1.7*VS
 EXPORT VS; //TYPICAL 3 km/s
   //THE TYPICAL VALUES HERE REFER TO LOCAL WAVES
 LOCAL EPSILON:=1ᴇ−308;//STD MATH:SMALLEST NONZERO (LIMIT VALUE USED FOR LOG0)
 LOCAL MNF:={"Earthquake","","Tremblement de terre","","","","","","Trzęsienie ziemi"}+VER;
 LOCAL MAGT:={"Magnitude","","Grandeur","","","","","","Wielkość"};
 LOCAL RELT:={"Relative ","","Relative ","","","","","","względna "};
 LOCAL AMPLT:={"Amplitude","","Amplitude","","","","","","Amplituda"};
 LOCAL ENERGT:={"Energy","","Énergie","","","","","","Energia"};
 ABOUT()
  LOCAL ABT:={"Earthquake calculations are estimates and can be calculated differently. No liability is accepted.","",
   "Les calculs sismiques sont des estimations et peuvent être calculés différemment.  Aucune responsabilité n'est acceptée.","","","","","",
   "Obliczenia trzęsienia ziemi są szacunkowe i można je obliczyć inaczej.  Nie ponosimy odpowiedzialności."};
  PRINT();
  PRINT(CRID);
  PRINT(MNF(SL));
  PRINT(ABT(SL));
  WAIT;
 //STD MATH
 //END MATH
 // Parameters may be numeric or lists
  LOCAL Rigidity:=IFTE(RigidityNm2,RigidityNm2,RigidityTypical);//Use Typical value if none supplied
  LOCAL Area:=Aream2;
  LOCAL Slip:=Slipm;
 MW(M0)
  IF MIN(M0)≤0 THEN
  RETURN MM;
  RETURN MW(M0);
  RETURN ROUND(ALOG(5.24+1.44*Magnitud),0);//J
 //Timing requires VP and VS to be set
 //Typically km/s but ensure these units match
 //VP VS (km/s) DISTANCE (km) TDELTA (s)
 EXPORT GetVPVS()
 //PROMPT USER FOR VP VS
 //(CALLABLE BY USER OR AUTOMAGICALLY TO AVOID ERROR)
 //TYPICALLY 6km/s and ?
  LOCAL TTL:={"Enter Velocity of P and S waves","","Entrez la vitesse des ondes P et S","","","","","","Wprowadź prędkość fal P i S"};
  LOCAL LBL:={"VP","VS"};
  LOCAL HLPP:={"Primary wave (typically  6 km/s, 1.7*VS)","","Vague primaire (généralement 6 km / s, 1.7*VS)","","","","","","Fala pierwotna (zazwyczaj 6 km / s, 1.7*VS)"};
  LOCAL HLPS:={"Secondary wave (typically  3 km/s)","","vague secondaire (généralement 6 km / s)","","","","","","Fala wtórna (zazwyczaj 3 km / s)"};
  LOCAL HLP:={HLPP(SL),HLPS(SL)};
  INPUT({VP,VS},TTL(SL),LBL,HLP);
 EXPORT CentreL(TDELTA)
 //Distance to centre-Local usable up To 100-250km.
 //Simple formula for constant velocity
 //TDELTA=(TimeS-TimeP) s (alt. to match VP VS)
 //RESULTS in m or km (ie. as VP VS)
  LOCAL DST;
  IF VP-VS==0 OR VP==0 OR VS==0 THEN
   MSGBOX(MN+"CentreL\n"+"VP-VS=0");
   GetVPVS();
  //MSGBOX({TDELTA,VP,VS});//INPUTLOG
  DST:=(TDELTA)*(VP*VS)/(VP-VS);
  RETURN ROUND(DST,0);//unit matching VS//ROUND to km
 //These trivial distace-time-velocity formulae assume constant velocity
 EXPORT Delay(DISTANCE) // DISTANCE ≤250 km
 //GIVEN DISTANCE,HOW LONG AFTER P WILL S ARRIVE
 //DISTANCE:UNITS TO MATCH VP VS
 //RESULTS MATCH UNITS OF VELOCITIES VP VS
  IF VP==0 OR VS==0 THEN
   MSGBOX(MN+"\n"+"VP/0 VS/0:"+STRING({VP,VS}));
   GetVPVS();
  //MSGBOX({DISTANCE,VP,VS});//INPUTLOG
  RETURN (DISTANCE/VP)-(DISTANCE/VS);
 EXPORT AnEarthquake(Magnitud)
 //Describe an Earthquake
  PRINT();
  PRINT(STRING(Magnitud)+" Magnitude");
  PRINT(" ");
  PRINT(STRING(EnergyJ(Magnitud))+" J");
  PRINT(STRING(Energyt(Magnitud))+" t(TNT)");
  PRINT(STRING(EnergyH(Magnitud))+" Hiroshima");
  LOCAL MAG;
  LOCAL BIGGER;
  CASE
     RETURN {};
   DEFAULT
  LOCAL MAG;
  LOCAL BIGGER;
  LOCAL STRONGER;
   CASE
      RETURN {};
    DEFAULT
 EXPORT Earthquakes(Magnitudes,INDX)
 //Describe relative earthquakes
 //Values onscreen need to be rounded to 9
 //to prevent occasional overlap.
 //You may prefer to omit this rounding.
  LOCAL II;
  LOCAL DP:=9;
  LOCAL SW:=320;
  LOCAL AMPLS:=Amplitudes(Magnitudes,INDX);
  LOCAL STRONGS:=Energies(Magnitudes,INDX);
  RECT_P();
  TEXTOUT_P(MN+MNF(SL),0,220);
  TEXTOUT_P(MAGT(SL),0,0);
  TEXTOUT_P(AMPLT(SL),SW/5,0);
  TEXTOUT_P(ENERGT(SL),2*SW/4,0);
  TEXTOUT_P(RELT(SL)+INDX,3*SW/4,0);
  IF TYPE(Magnitudes)==TYPE({}) THEN
   FOR II FROM 1 TO MIN(SIZE(Magnitudes),10) DO //10-11 PER SCREEN:1SCREEN
    TEXTOUT_P(ROUND(Magnitudes(II),4),0,20*II);
    TEXTOUT_P(ROUND(AMPLS(II),DP),SW/6,20*II);     //ROUND FOR DISPLAY
    TEXTOUT_P(ROUND(STRONGS(II),DP),2*SW/4,20*II); //ROUND FOR DISPLAY
  FREEZE;
  WAIT;
 //Examples
 ExM0()
 ExMW()
 ExEnergy()
  //PRINT({EnergyJ({5.0,6.0,7.0}),"=2.8ᴇ12 =7.8ᴇ13?? =2.1ᴇ15"}+" J ");
  //PRINT({EnergyH(5.0),EnergyH(6.0),EnergyH(7.0)," "}+" Hiroshima ");
  //PRINT({EnergyJ(9.05),"=1.84ᴇ18"}+" J ");
  //PRINT({Energyt(5.0)}+" tTNT ");
  WAIT;
  AnEarthquake(7.1);
 ExRel()
  //PRINT(STRING(Amplitudes({7.1,6.4},2))+" =5");
  //PRINT(STRING(Energies({7.1,6.4},2))+" =11.2");
  WAIT;
  Earthquakes({1,2,3,4,5,6,7,8,9,10,11,12,13},4);
 EXPORT Examples()
  ABOUT();
  //PRINT();
  WAIT;
  ExM0();
  ExMW();
  ExEnergy();
  ExRel();
 EXPORT HELP()
  LOCAL ALL:={"Most functions allow lists","","La plupart des fonctions permettent les listes","","","","","","Większość funkcji pozwala na listy"};
  LOCAL MAG:=MAGT(SL)+": "+{"Not exactly","","Pas exactement","","","","","","Nie dokładnie"}+" Richter";
  LOCAL UL:= {"Unitless","","Sans unité","","","","","","Bez jednostki"};
  ABOUT();
  PRINT();
  PRINT(ALL(SL));
  PRINT(" ");
  //PRINT("UNITS");
  PRINT("M0Nm: Nm");
  PRINT(MAGT(1)+": "+MAG(SL));
  PRINT(ENERGT(SL)+": J, Hiroshimas or tonnesTNT");
  PRINT("GetVPVS: km/s?");
  PRINT("CentreL: km  ? (≤100-250km");
  PRINT("Delay:      s?");
  PRINT(" ");
  PRINT("RelativeAmplitudes: "+UL(SL));
  PRINT("RelativeEnergies: "+UL(SL));
  PRINT(" ");
 EXPORT Languages()
  LOCAL TTL:=IFTE(SL,LANGS2(SL)+LANGS(SL)+LANGSE(SL),LANGS2+LANGSE);
  IF CHOOSE(SL,TTL,LANGS2+LANGS+LANGSE) THEN
   MSGBOX(LANGS2(SL)+LANGS(SL)+LANGSE(SL));
  ABOUT();
  Languages();
  //ABOUT();
References providing formulae and examples
1. https://www.e-education.psu.edu/earth520...l7_p4.html - Earthquake magnitude and energy
2. https://www.hpmuseum.org/forum/thread-13239.html - Relative strength of 2 earthquakes
3. https://www.google.com/url?sa=t&source=w...NFcE6pGX2B" - PDF - Earthquake location and speed
