07-01-2019, 07:36 PM
i try using plotfunc() while working in cas mode. The calculator give a picture of the graph in stack. Some graph doesn’t look good e.g straight line as my example. So how can I control the scale of this plot command.
I guess, there must be some parameter specify in this command. What is the syntax of the command?
And if I plot it without specifying the plot range, how can I control default plotting behavior?
[attachment=7417][attachment=7418][attachment=7419][attachment=7420]
