2
3 5 7
11 13 17 19 23
29 31 37 41 43 47 53
59 61 67 71 73 79 83 89 97
Write an RPL program that lists the elements in the central column of the triangle of primes above, starting from a(0) = 2 up to a(k). For example,
2 -> {2 5 17}
5 -> {2 5 17 41 73 127}
99 -> {2 5 17 41 73 ... ... 101323 103613}
My checksum is # 7A67h.
Have fun!
(06-30-2019 08:41 PM)Gerson W. Barbosa Wrote: [ -> ]My checksum is # 7A67h.
Incidentally, the number of bytes belongs in the central column :-)
Gerson:
(06-30-2019 08:41 PM)Gerson W. Barbosa Wrote: [ -> ]Write an RPL program that lists the elements in the central column of the triangle of primes above, starting from a(0) = 2 up to a(k).
You need to define what
k is supposed to be.
Also, as this is (as usual) an RPL mini-challenge I won't enter my HP-71B solution, which is a short one-liner.
Have a nice weekend.
(06-30-2019 09:10 PM)Valentin Albillo Wrote: [ -> ].
Hi, Gerson:
You need to define what k is supposed to be.
Hello, Valentin,
I hope the examples I have provided compensate for some lack of rigor from my part. “
k” is the number of elements in the list minus 1.
Yes, it can fit in one HP-71BASIC line if either NEXTPRIME() or PRIME() function is available. Of course, being this an RPL mini-chalenge, the size of your BASIC code won’t compare to equivalent RPL codes. However, considering optimized algorithms can possibly make for shorter RPL codes than we currently have, I think the submission of non-RPL programs might be helpful, so they’re always welcome.
Best regards,
Gerson.
HP-42S implementation:
00 { 86-Byte Prgm }
01▸LBL "PRCOL"
02 STO 00
03 1
04 STO+ 00
05 STO 01
06 ENTER
07 NEWMAT
08 STO "R"
09 INDEX "R"
10 2
11 STOEL
12 GROW
13 STO 03
14 STO 04
15 GTO 03
16▸LBL 00
17 2
18 STO+ 01
19 1
20 STO 02
21▸LBL 01
22 2
23 STO+ 02
24 RCL 02
25 X↑2
26 RCL 01
27 X<Y?
28 GTO 02
29 LASTX
30 MOD
31 X=0?
32 GTO 00
33 GTO 01
34▸LBL 02
35 DSE 03
36 GTO 00
37 J+
38 STOEL
39 2
40 STO+ 04
41 RCL 04
42 STO 03
43▸LBL 03
44 DSE 00
45 GTO 00
46 RCL "R"
47 CLV "R"
48 END
Thank you, Gerson! I always enjoy these challenges.
(06-30-2019 11:57 PM)Thomas Okken Wrote: [ -> ]HP-42S implementation:
00 { 86-Byte Prgm }
01▸LBL "PRCOL"
02 STO 00
03 1
04 STO+ 00
05 STO 01
06 ENTER
07 NEWMAT
08 STO "R"
09 INDEX "R"
10 2
11 STOEL
12 GROW
13 STO 03
14 STO 04
15 GTO 03
16▸LBL 00
17 2
18 STO+ 01
19 1
20 STO 02
21▸LBL 01
22 2
23 STO+ 02
24 RCL 02
25 X↑2
26 RCL 01
27 X<Y?
28 GTO 02
29 LASTX
30 MOD
31 X=0?
32 GTO 00
33 GTO 01
34▸LBL 02
35 DSE 03
36 GTO 00
37 J+
38 STOEL
39 2
40 STO+ 04
41 RCL 04
42 STO 03
43▸LBL 03
44 DSE 00
45 GTO 00
46 RCL "R"
47 CLV "R"
48 END
Wow! Only 86 bytes, 77 without LBL. Slightly less here, but NEXTPRIME is built into the HP-49/50g. Well done!
wp34s version:
001 LBL A
002 INC X
003 # 001
004 # 000
005 STO T
006 X<>Y
007 NEXTP
008 X<>Y
009 DSE X
010 BACK 004
011 x<> T
012 INC X
013 INC X
014 X<>Y
015 PSE 10
016 X<>Y
017 DSE Z
018 BACK 013
019 X<>Y
020 END
The 34S version is going to be difficult to beat. Eighteen steps without the initial LBL and the END. Everything is on the stack and no labels or extra registers needed.
For a moment there, I thought that steps 5 and 6 could be combined using the [<->] shuffle command. Alas, no. They need to be separate steps.
I think steps 3 and 4 might possibly be contender for combining.
Pauli
My simplistic RPL solution. 83 bytes, checksum # EBAAh. Optimized for speed rather than size. An input of 9 takes 1.19 seconds on my HP 50. An input of 99 takes 397 seconds, or 6.98 seconds on EMU48. The HP Prime could solve this almost instantly as the Prime has the 'ithprime' function.
*Spoiler alert*
\<< I\->R \-> n
\<< 2 2. n 2. *
FOR k DUP 1. k
START NEXTPRIME
NEXT 2.
STEP n 1. + \->LIST
(07-01-2019 12:25 PM)Paul Dale Wrote: [ -> ]The 34S version is going to be difficult to beat. Eighteen steps without the initial LBL and the END. Everything is on the stack and no labels or extra registers needed.
Steps 3 and 4 can be replaced by CPX .
Mine turned out to be very close to John's solution:
*** Anti-spoil (scroll down to see) ***
(classic RPL version - 108 bytes in newRPL)
M « 2 1 M FOR 'K' DUP 1 K 2 * START
NEXTPRIME
NEXT
NEXT
M 1 + →LIST
(newRPL dialect - 96 bytes )
'M' LSTO 2 1 M FOR 'K' DUP 1 K 2 * START
NEXTPRIME
NEXT
NEXT
M 1 + →LIST
We are at 96 bytes for newRPL, can't beat the 50g with classic RPL in size (never will), but in speed is a different story...
Runs the 99 case in 172 msec (second run), or 489 msec for the first run (which runs at 6 MHz for some time before the "turbo" kicks in). Runs the 150 case in 5.61 seconds (second run) and 5.98 sec for the first run, in this case the difference between the first/second run becomes a lot less relevant.
(07-01-2019 01:52 PM)Claudio L. Wrote: [ -> ]...speed is a different story...
Runs the 99 case in 172 msec ...
Gee, only aboutr 2300* faster!
I really need another HP 50...
(07-01-2019 05:05 PM)John Keith Wrote: [ -> ] (07-01-2019 01:52 PM)Claudio L. Wrote: [ -> ]...speed is a different story...
I do need a third one.
My newer 50g (CNA2240GYB) is slightly slower than yours: 402.76 seconds for k=99. My program is a bit slower as well: 409.17 seconds.
# 7A67h
73 bytes
« { } 1 0 DUP 5 ROLL
START 1 OVER
START UNROT NEXTPRIME ROT
NEXT UNROT + LASTARG NIP ROT 2 +
NEXT DROP2
(07-01-2019 05:20 PM)Gerson W. Barbosa Wrote: [ -> ]My newer 50g (CNA2240GYB) is slightly slower than yours: 402.76 seconds for k=99. My program is a bit slower as well: 409.17 seconds.
Your program might be slower but sure it's more clever!
I ran it in newRPL just for kicks: 108 bytes (had to make slight modifications for newRPL, won't comment here to avoid spoiling the answer to others).
Your code runs 99 in 176 msec under newRPL.
By the way, at 108 bytes you also take the title of newRPL Champion too. That's because I realized my solution does not work properly for an input of 0, so I'm disqualifying myself :-).
I re-coded the challenge so it works properly but it grew up to 136 bytes (from 96 bytes), on the other hand it now does 99 in 134 msec.
**** Anti - Spoiler ****
Here's my rework that meets the original requirements:
2 * 'M' LSTO 2 DUP 'K'
LSTO WHILE K M ≤ REPEAT
DUP 1 K START
NEXTPRIME
NEXT
K 2 + 'K' STO
END
M 2 / 1 + →LIST
And this is Gerson's code ported to newRPL:
{ } 1 0 DUP 5 ROLL START
1 OVER START
UNROT NEXTPRIME
ROT
NEXT
UNROT DUP UNROT ADD
SWAP ROT 2 +
NEXT
DROP2
Here " + LASTARG NIP" was replaced with "DUP UNROT ADD SWAP", because newRPL does not support LASTARG, also + and ADD have swapped their functionality. It adds 4 bytes (1 command) in size to his original solution.
(07-01-2019 04:49 AM)Gerson W. Barbosa Wrote: [ -> ]wp34s version:
001 LBL A
002 INC X
003 # 001
004 # 000
005 STO T
006 X<>Y
007 NEXTP
008 X<>Y
009 DSE X
010 BACK 004
011 x<> T
012 INC X
013 INC X
014 X<>Y
015 PSE 10
016 X<>Y
017 DSE Z
018 BACK 013
019 X<>Y
020 END
Your algorithm is great! Here is a slightly optimized version of the program (24 bytes), removing the unnecessary X<>Y instructions :
001 LBL A
002 c#001
003 <>XYZY
004 NEXTP
005 DSE T
006 BACK 002
007 INC Y
008 INC Y
009 PSE 10
010 DSL Z
011 BACK 008
012 END
EDIT: further optimized by removing the initial INC X with the usage of DSL in step 11.
(07-01-2019 11:13 PM)Didier Lachieze Wrote: [ -> ] (07-01-2019 04:49 AM)Gerson W. Barbosa Wrote: [ -> ]wp34s version:
001 LBL A
002 INC X
003 # 001
004 # 000
005 STO T
006 X<>Y
007 NEXTP
008 X<>Y
009 DSE X
010 BACK 004
011 x<> T
012 INC X
013 INC X
014 X<>Y
015 PSE 10
016 X<>Y
017 DSE Z
018 BACK 013
019 X<>Y
020 END
001 LBL A
002 c#001
003 <>XYZY
004 NEXTP
005 DSE T
006 BACK 002
007 INC Y
008 INC Y
009 PSE 10
010 DSL Z
011 BACK 008
012 END
A
slightly optimized version? I wonder what your
heavily optimized one would look like! :-)
Very nice! Indeed a masterpiece.
Yes, I noticed there were too many X<>Y instructions. “Let me remove a few and it’ll be perfect”, I thought.
Thank you very much for removing THEM ALL! :-)
Interesting puzzle, interesting approaches!
Spoiler spoiler...
0.
{ DUP 1. n DUP + START NEXTPRIME NEXT }
'n'
PICK3
5. ROLL
1.
SEQ
NIP
The SEQ command actually builds a UserRPL FOR loop behind the
scenes. So I'm guessing its performance should be about the same
as a FOR loop approach (perhaps slightly slower for the overhead
to build the loop).
I'll also experiment with some list-based code for this. The
memory requirements would go up (both for the code and run-time
needs), but it may perform a little better.
A version using list processing with ListExt commands:
Unspoiled...
2. DUP ROT LASEQ
0. NEXTPRIME SWAP
IF
DUP SIZE
THEN
1.
OVER
{ NEXTPRIME }
ROT LMRPT
EVAL
DOSUBS
END
This one weighs in at 97.5 bytes, and finishes an input of
99 in about 383 seconds on my 50g. Two commands from the
ListExt library are used: LASEQ and LMRPT. LASEQ is used
to generate a list of even numbers from { 2..n }, where
the total count of numbers is the input parameter k. In
the case of an input of 99, LASEQ generates the list { 2.
4. 6. 8. ... 198. } in about 43 milliseconds.
LMRPT is used to replicate NEXTPRIME in a list a given
number of times (in this case each of the above even
numbers). So given { NEXTPRIME } and 4 as arguments, LMRPT
creates this list: { NEXTPRIME NEXTPRIME NEXTPRIME
NEXTPRIME }. That result is then executed on a copy of the
last found prime to generate the next one.
Ultimately, all of these RPL programs are at the mercy of
the NEXTPRIME command, which I believe consumes the
majority of processing time. This version achieves a minor
speed advantage by reducing the overall looping overhead
as compared to other versions. It does this at the cost of
a large memory footprint at runtime, though. Using a
k-value of 99 means that a list of 198 NEXTPRIME commands
is created (and executed) for the final pass of the DOSUBS
loop. That list alone is over 2K (bytes) in size!
Thank you all for your interest, comments and great contributions!
Here is my solution, as hidden elsewhere in this thread:
START 1 OVER
NEXT DROP2
73 bytes, 409.2391 seconds for k = 99
Algorithm:
input k
p := 1
q := 0
for i := 0 to k
for j := 1 to q ; notice the loop is executed once, when q = 0
p := nextprime(p)
next j
print p
q := q + 2
next i
My initial goal was making it shorter than 100 bytes, as my previous program was 112 bytes longer, not to mention it was significantly slower, so I didn't try to optimize it any further. All of the pure RPN solutions submitted thus far are slightly faster and yet small enough in size, which is great.
Author time (s, k=99) CK Size
John Keith 402.9453 # 2F5h 83
Claudio L. 403.7325 # 4E5Eh 78
David M. 407.3202 # F924h 75
That's
OEIS sequence A122566.
