I would like to know of any SYSRPL code to STO an object in a folder in a port (if its possible).
So far this is what I have found out
{ ID DIR ID OB } tok1 >TAG ' xRCL EvalNoCK ( this works for RCL )
BINT2 { ID DIR ID OB } tok1 >TAG xSTO ( displays Bad Argument type )
HPs document 'SD00 Using an SD Card' is saying it can by using key entries
Any help on this would be appreciated
Jeff
(06-23-2019 08:11 PM)JeffB Wrote: [ -> ]I would like to know of any SYSRPL code to STO an object in a folder in a port (if its possible).
Jeff
The HP note is about using an SD Card, and I believe the techniques do not apply to 'normal' non-SD Card ports. The SD card uses the FAT file system, which inherently supports folders, while the native Port-0/Port-1/Port-2, from the 48, don't support folders.
Non SD ports store objects as single "blobs" at top level.
This is why you can NOT do a sto in a port that is not as SD card in a "sub" object.
At the time, I added code to do RCL in basically anything (as I needed it for the #include functions of the ASM compiler), but a STO is a much more complicated operation to perform and I never implemented it (especially when we are talking about flash which is basically read only).
Cyrille
Thanks rprosperi and Cyrille.
I thought as much, but wanted to ask to be sure.
Jeff
