05-14-2014, 06:06 PM
I find that the 48 series particularly shines when you write a lot of small utility programs to enhance working within the stack paradigm, and keep them in HOME for access anywhere.
With that in mind, here are a handful of programs that convert dates/times to and from numeric values that are compatible with Excel and Lotus 1-2-3; just format the cell values as dates after transferring the data. I use them a lot within other programs that log time-stamped data.
Converting the times to scalar values rather than formatted values (M.DDYYYY, H.MMSS) has the added benefit of making it easier to plot time-based data directly on the 48.
DATE->NUM
Input:
1: Formatted date
Output:
1: Days since December 30, 1899
NUM->DATE
Input:
Output:
1: Formatted date
->EXCELDATE
Input:
2: Formatted date
1: Formatted time
Output:
1: Excel/Lotus-compatible date value (e.g. right now is 41773.5727104)
EXCELDATE->
Input:
1: Excel/Lotus date value
Output:
2: Formatted date
1: Formatted time
DTDIFF
Not directly related to the above programs, but worth including here. Gives elapsed time between two date/time pairs.
Input (all formatted values):
4: Starting date
3: Starting time
2: Ending date
1: Ending time
Output:
1: Elapsed time in H.MMSS format
Some notes:
The programs use date constants that are equivalent regardless of the current date format (flag -42). That's why there's a fudge factor of 2 days, rather than a flag check, two date constants, and IFTE.
Running ->EXCELDATE EXCELDATE-> in sequence will not return the original starting values. Combining the date and time into a single real number will give you a small amount of rounding error, though the time appears to retain about 8 significant digits after the round trip.
DATE->NUM
Input:
1: Formatted date
Output:
\<< 1.0119 SWAP DDAYS 2 + \>>
NUM->DATE
Input:
Output:
1: Formatted date
\<< IP 2 - 1.0119 SWAP DATE+ \>>
->EXCELDATE
Input:
2: Formatted date
1: Formatted time
Output:
\<< HMS\-> 24 / SWAP DATE\->NUM + \>>
EXCELDATE->
Input:
Output:
2: Formatted date
1: Formatted time
\<< DUP IP NUM\->DATE SWAP FP 24 * \->HMS \>>
DTDIFF
4: Starting date
3: Starting time
2: Ending date
1: Ending time
Output:
\<< \-> D1 T1 D2 T2
\<< D1 D2 DDAYS 24
* T2 T1 HMS- HMS+
Some notes:
