06-12-2019, 10:23 PM
This is a little library implementing a toggle which alternates display of complex number on level 1 of the stack in rectangular or polar coordinate system.
It takes advantage of the possibility to assign new definitions not only to keys, but also to events associated to a key such as "key pressed" or "key released".
In particular, given a complex number on level 1, if the toggle key is pressed, and as long as it is pressed, its representation will switch to rectangular if originally in polar and vice versa.
When the toggle key is released, it will switch back to normal.
The library consists of two commands: "INSTTOG" and "UNINSTTOG" which, as their name suggest, are used to bind/unbind the toggle to your favourite key.
Both commands accept a string description of they key to which the toggle is associated, in the ASKKEY command format.
For example, if you want to associate the toggle to unshifted "." (dot) you must run
To uninstall the toggle
Here is the code of the library
"DT." INSTTOG
"DT." UNINSTTOG
"TOGGLE RECT/POLAR DISPLAY v1.0
(c) Stefano Priore 2019"
'$TITLE' STO
'$IGNORE' STO
{ 'INSTTOG' 1 0 "Bind toggle to a key
S →" }
{ 'UNINSTTOG' 1 0 "Remove toggle asn from key
S →" }
'$VISIBLE' STO
'TRPD'
'$LIBID' STO
k « k IF
DUPDUP TYPE
24 == SWAP "" ≠
AND
THEN
DUP ASSN 1 GET SWAP
".L" + 0 ASNKEY
ASSN 2 GET SWAP
".U" + 0 ASNKEY
0 KSTO 0 TSTO
ELSE
24 DOERR
END
'INSTTOG' STO
k « k IF DUPDUP TYPE
24 == SWAP "" ≠
AND THEN
DUP ".L" + DELKEY
".U" + DELKEY
ELSE
24 DOERR
END
'UNINSTTOG' STO
IF
DEPTH
THEN
IF
DUP TYPE 30 ==
THEN
IF
DUP TYPEE FP
THEN
DUP TSTO 1 KSTO →RECT
ELSE
DUP TSTO 1 KSTO →POLAR
END
END
END
IF
KRCL
THEN
DROP TRCL 0 KSTO
END
'ASSN' STO
'KPRESS' LIBSTO
'KSTO' STO
'KPRESS' LIBRCL
'KRCL' STO
'TEMP' LIBSTO
'TSTO' STO
'TEMP' LIBRCL
'TRCL' STO
