Hi. Normally, a new hp-Prime firmware update is released every 6 months. I think we are about to receive a new update. I hope that the hpprime team can include micro-python, as a stand-alone application, the CASIO, NUMWORKS, and TI competition already got on this train.
Introducing the new Python menu of the Graph 90+E Casio Calculator
Hello
Anything that is new will be welcome in future firmware, but if I may choose in what to use the resources, will be in improve maths capabilities.
Instead of implement new languages which are always limited on a calculator, with limited libraries allowed to be downloaded in it, it may be more interesting for me to implement new features regarding math, which I think is the main goal of a calculator.
For example:
Improve several variables calculus like
• Limits in 2 or 3 variables
• Taylor polynomial with 2 or 3 variables
Increase precision. 20 digits? The new G2 is fast enough to allow it.
Improve 3d graphs and geometry. Introduce the possibility to draw lines in 3d with their equations.
There is a group of users (teachers and students) who would be interested in Micropython, especially its language that is used to initiate algorithmic and coding logic. I also believe that it occupies very little space, was developed mainly for embedded systems with microcontroller.
Imagine if the major Python scientific, extended math and numeric libraries could be used with micropython - e.g. numpy, scipy - what amazing power that would give this calculator. However this post says those libraries will likely never be ported to micropython, and also that their size is prohibitive.
In my opinion, the best news about a Prime firmware update would be the announcement of a full implementation of RPL, so that there will be full access to the stack within the programming again.
(06-02-2019 08:46 AM)Karl-Ludwig Butte Wrote: [ -> ]Dear All,
Best regards
Karl
And I'd like to see a unicorn. Sadly, here's not much chance of either happening.
(06-02-2019 08:46 AM)Karl-Ludwig Butte Wrote: [ -> ]In my opinion, the best news about a Prime firmware update would be the announcement of a full implementation of RPL, ...
That's not really feasible.
(06-02-2019 08:46 AM)Karl-Ludwig Butte Wrote: [ -> ]so that there will be full access to the stack within the programming again.
Even partial access would be helpful. You can already access a fixed number of values off the RPN stack through the program arguments. What you cannot do so well is push more than one value back onto the stack. Best you can do is return a list. Seems like it shouldn't be too hard to push/pop values from a PPL program (says the man who has no idea how hard it would actually be).
(06-01-2019 09:46 PM)tcab Wrote: [ -> ]Imagine if the major Python scientific, extended math and numeric libraries could be used with micropython - e.g. numpy, scipy - what amazing power that would give this calculator. However this post says those libraries will likely never be ported to micropython, and also that their size is prohibitive.
What kind of features of numpy or scipy would you like to see on the Prime that are not already there?
(06-02-2019 07:40 PM)parisse Wrote: [ -> ]What kind of features of numpy or scipy would you like to see on the Prime that are not already there?
Nothing in particular - I was actually commenting on MicroPython on the Graph 90+E Casio Calculator being rather limited without any proper Python numerical libraries.
The MicroPython on the Casio is just it’s own little world and has not been integrated with the features of the calculator, so you can’t e.g. call Casio numerical library functions from Python, so I’ve been told by someone in Casio Australia. You can’t even access the graphing of the Casio from MicroPython.
You can run KhiCAS on the Casio and have most of the functionnalities of numpy/scipy with Python syntax, and a more convenient programming UI (syntax highlight, parenthese match, line wrapping, debugger ... I would really like to see the same on the Prime!). And of course CAS.
(06-06-2019 04:56 AM)parisse Wrote: [ -> ]You can run KhiCAS on the Casio and have most of the functionnalities of numpy/scipy with Python syntax, and a more convenient programming UI (syntax highlight, parenthese match, line wrapping, debugger ... I would really like to see the same on the Prime!). And of course CAS.
What would be the modifications to adapt the Python syntax engine of Xcas in hp-prime?
It's not about syntax, but about the UI: the Prime UI does currently not support syntax highlighting or parentheses matching (and a few other things like a checkbox in the settings to select Python or PPL syntax, with consequences on array indices starting at 0 or 1).
It would also be nice to have CAS sessions saving, a new feature I have just introduced in KhiCAS: you can save a session, transfert it to a PC and open it with Xcas or Xcas for Firefox, and conversely. In Xcas for Firefox, you can easily share your session with other, in forums like here or in a private email.
On the Casio, I had to remove part of the Xcas commands because I have reached the addin max size, but on the Prime, we could have much better compatibility.
(06-06-2019 04:37 PM)parisse Wrote: [ -> ]It's not about syntax, but about the UI: the Prime UI does currently not support syntax highlighting or parentheses matching (and a few other things like a checkbox in the settings to select Python or PPL syntax, with consequences on array indices starting at 0 or 1).
I would be satisfied if the Prime just handled quote marks like every other sane text editor/calculator.
Once the update does come out it will be interesting to come back here and compare these wish lists with the actual new features. Many of us will be a bit disappointed but, who knows. We might be pleasantly surprised in some areas. Of course I have no knowledge whatsoever of what's in store so even my prediction may be way off!
