(05-20-2019 11:48 PM)Sylvain Cote Wrote: [ -> ]Artur,
I have extracted LR and SR from the PPC ROM.
Sylvain
Sylvain, many thanks for your efforts! Great job!!
I got the code into my HP. It lists as this bellow. Just some thoughts: there's no return between such programs. One acts as part of another. So, I'll try them today and see what happens!
Many thanks!
LBL "SR"
SIGN
SF 10
RDN
RCL b
STO M
RDN
FC?C 10
RTN
RCL IND L
ISG L
X<> IND L
STO N
X<> IND L
STO O
X<> O
STO a
X<> N
CLA // see that there isn't RTN to close label SR!!
LBL "Sb"
STO b // again there isn't RTN to close label Sb!! I believe it's because the program pointer will jump to the new address in b!!
LBL "LR"
SIGN
RDN
RCL a
STO N
RDN
RCL b
X<> M
STO 0
ASTO IND L
ISG L
STO O
ASTO IND L
RDN
CLA
RTN
END //This I put by myself
Hello Artur,
I am at work and cannot do a line by line analysis, but see my notes below ...
Sylvain
Click on "View a Printable Version" below to see the complete source code
LBL "SR"
SIGN
SF 10
RDN
RCL b
STO M // "HERE" after STO b
RDN
FC?C 10
RTN // ok
RCL IND L
ISG L
X<> IND L
STO N
X<> IND L
STO O
X<> O
STO a
X<> N
CLA // ok, fall thru, optimisation
LBL "Sb"
STO b // ok, absolute go to "HERE"
LBL "LR"
SIGN
RDN
+ // assuming typo here, should be a string "+" not the operator +
RCL a
STO N
RDN
RCL b
X<> M
STO 0
ASTO IND L
ISG L
STO O
ASTO IND L
RDN
CLA
RTN // could be removed, END is a super RTN
END // after reading a program with the barcode reader always do a [GTO ..], it will automatically add the END and pack memory
edit: STO b comment corrected
The following are extract from PPC ROM manual:
(05-21-2019 01:45 PM)Sylvain Cote Wrote: [ -> ]
END
Correction: not "could" be removed, but "should" be removed.
END is not just a marker that indicates where a program ends. It is an executable instruction, and when it is executed, it performs
EXACTLY the same operation as RTN.
There is never, ever, any reason to put a RTN right before an END. Never ever. And when you do, a kitten dies somewhere.
(05-22-2019 12:28 AM)Thomas Okken Wrote: [ -> ]There is never, ever, any reason to put a RTN right before an END. Never ever. And when you do, a kitten dies somewhere.
Dammit! I now have to clean up the water I just spit all over my desk, as I was drinking when reading this.
Thanks for that.
Hi, guys!
In a simple test program, the routines worked fine:
The program will show A B (in a subroutine) and user keys A or B. Such branches shall return
1 or 2 to main program, which, in turns, adds 1 to whatever returns.
LBL "AA"
XEQ "BB"
1 // here if RTN from BB works fine, I'll add 1 to the number returned from there.
RTN
LBL "BB"
1 //needed by LR - the first of two regs to store a and b
XEQ "LR" // LR kills alpha register, so, I believe it's better call LR before prompting messages
"A B"
PROMPT
LBL A
1 //needed by SR - the first of two regs that stored a and b
XEQ "SR" //gets back the return stack - we hope!
1
RTN // this RTN would never work in a "normal" program
LBL B
1
XEQ "SR"
2
END //won't put RTN where it is not neccessary any more! Whithout shynt instructions,
// program simple would stop here.
It worked very fine!
I'll add the calling for those routines in my soft menu. Unfortunatelly, this will cost a lot of bytes, which were at limit to use short local labels ...
if someone interested in my routine, I'll could explain and give some examples. May be someone could improve it and we finally got a routine for soft menus in 41C!
Many thanks to Sylvain for his precious support - without you, I would retire my 41 again ....
I forgot to comment something strange about NovRAM:
I just saved the program SR (it has the others: LR and Sb) to NovRAM.
So, I deleted the SR from main memory.
By mystake, I delete the program AA where I called the synthetic routines, so, I was retype it.
Well, when I typed: XEQ ALPHA LR ALPHA, the calculator show XEQ IND A !!!
The same for XEQ ALPHA SR ALPHA (the register after IND I don't remember well).
Running program, it didn't work as desired.
Some explanation? I'll have to keep programs in main memory? Diego says we can call a program stored in NovRAM without problems. Have I missed something?
Best wishes
Artur
(05-22-2019 12:28 AM)Thomas Okken Wrote: [ -> ] (05-21-2019 01:45 PM)Sylvain Cote Wrote: [ -> ]
END
END is not just a marker that indicates where a program ends. It is an executable instruction, and when it is executed, it performs EXACTLY the same operation as RTN.
I was just afraid to remove some byte from a program with synthetic instructions...
(05-22-2019 02:00 AM)Artur - Brasil Wrote: [ -> ]Some explanation? I'll have to keep programs in main memory? Diego says we can call a program stored in NovRAM without problems. Have I missed something?
Hello Artur,
There are fundamental differences between main RAM and HePaX RAM (or NoVRAM HePaX simulation).
I need to do some investigation on how HePaX FOCAL adresses are pushed in the return stack before going further.
I should be able to check it tonight (GMT-4h) and will come back with an explanation.
Sylvain
Hello Artur,
I have investigated the return stack for both RAM and HePaX RAM and it should works for both.
(05-22-2019 02:00 AM)Artur - Brasil Wrote: [ -> ]I forgot to comment something strange about NovRAM:
I just did the same thing and it works on my side.
Do the following:
- GTO .. // to go to end of memory
- PRGM // to enter program mode
- XEQ "LR" // the command should be transformed into XROM "LR", if not then LR is not in HePaX RAM or you have a copy in main RAM
- <- // to delete the above line
- PRGM // to exit program mode
(05-22-2019 02:00 AM)Artur - Brasil Wrote: [ -> ]I'll have to keep programs in main memory?
nop
(05-22-2019 02:00 AM)Artur - Brasil Wrote: [ -> ]Diego says we can call a program stored in NovRAM without problems.
yep
I have done the following test procedure:
- loaded LR/SR routines in main RAM from the barcode sheet
- copied the program into HePaX RAM with HSAVEP
- deleted the program from main RAM with CLP
- entered a test program into main RAM that goes into 9 level deep sub-routines
- run the program in main RAM
- XEQ "RS9" // it shows 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 and stop
- press R/S // it shows 8, 7, 6, 5, 4, 3, 2, 1, 0 and stop
- press R/S // it shows 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 and stop
- run the program in HePaX RAM and I have the same results as above
Test program:
01 LBL "RS9"
02 SF 05
03 1
04 SIGN
05 CLX
06 LBL 00
07 FC?C 05 // skip next line the first time only
08 RTN // stop
09 VIEW X // shows 0
10 XEQ 01 // push return address (line 11)
11 GTO 00
12 LBL 01
13 LASTX
14 +
15 VIEW X // shows 1
16 XEQ 02 // push return address (line 17)
17 LASTX
18 -
19 VIEW X // shows 0
20 RTN // pop return address (line 11)
21 LBL 02
22 LASTX
23 +
24 VIEW X // shows 2
25 XEQ 03 // push return address (line 26)
26 LASTX
27 -
28 VIEW X // shows 1
29 RTN // pop return address (line 17)
30 LBL 03
31 LASTX
32 +
33 VIEW X // shows 3
34 XEQ 04 // push return address (line 35)
35 LASTX
36 -
37 VIEW X // shows 2
38 RTN // pop return address (line 26)
39 LBL 04
40 LASTX
41 +
42 VIEW X // shows 4
43 XEQ 05 // push return address (line 44)
44 LASTX
45 -
46 VIEW X // shows 3
47 RTN // pop return address (line 35)
48 LBL 05
49 LASTX
50 1
51 XROM "LR" // save return stack into data registers 1 & 2 (lines 11, 17, 26, 35 & 44)
52 +
53 VIEW X // shows 5
54 XEQ 06 // push return address (line 55) and looses first return address (line 11)
55 LASTX
56 1
57 XROM "SR" // restore return stack from data registers 1 & 2 (lines 11, 17, 26, 35 & 44)
58 -
59 VIEW X // shows 4
60 RTN // pop return address (line 44)
61 LBL 06
62 LASTX
63 +
64 VIEW X // shows 6
65 XEQ 07 // push return address (line 66) and looses second return address (line 17)
66 LASTX
67 -
68 VIEW X // shows 5
69 RTN // pop return address (line 55)
70 LBL 07
71 LASTX
72 +
73 VIEW X // shows 7
74 XEQ 08 // push return address (line 75) and looses third return address (line 26)
75 LASTX
76 -
77 VIEW X // shows 6
78 RTN // pop return address (line 66)
79 LBL 08
80 LASTX
81 +
82 VIEW X // shows 8
83 XEQ 09 // push return address (line 84) and looses fourth return address (line 35)
84 LASTX
85 -
86 VIEW X // shows 7
87 RTN // pop return address (line 75)
88 LBL 09
89 LASTX
90 +
91 VIEW X // shows 9
92 STOP // stop program, press R/S to unwind the stack
93 LASTX
94 -
95 VIEW X // shows 8
96 END // pop return address (line 84)
(05-23-2019 02:24 AM)Sylvain Cote Wrote: [ -> ]
52 +
55 LASTX
56 1
58 -
Hi, Sylvain!! Wow, you're working hard!!! Well, for lines 51 and 57, you typed: XEQ ALPHA LR ALPHA and same to other line? The calculator so showed XROM "LR" ?!!
I'll try again, as mine showed an strange code instead of XROM LR...
Best wishes!!
Artur
(05-23-2019 12:11 PM)Artur - Brasil Wrote: [ -> ]Well, for lines 51 and 57, you typed: XEQ ALPHA LR ALPHA and same to other line? The calculator so showed XROM "LR" ?!!
To keep it simple, an HePaX module behaves like ROM but with RAM.
All files in HePaX RAM gets an entry in the module FAT table and thus get a XROM number.
In my case ...
- I first copied the LR program from main RAM to HePaX RAM,
- then deleted the LR program from main RAM
- finally, I keyed in my test program in main RAM.
At line 51, when I keyed XEQ "LR" ...
- the HP-41 OS scanned the main RAM to find the global label
- when not finding it, it started to scan ROM spaces (which HePaX RAM resides)
- when he found it in HePaX RAM FAT, it then replaced the line with it's XROM (eXecute in ROM) equivalent
- in my case the XEQ "LR" line (hex: 1E F2 4C 52)
was replaced by XROM "LR" (XROM 11,19 or hex: A2 D3 or bin: 10100 01011 010011)
Hi Sylvain and all guys that helped me in this journey!
The soft menu for 41 is working now! These days I was busy at faculty but, in mean time, I could refine and finish it.
I believe it is a good aproach for soft menus. With it I made some few other programs: CPLX - my approach to deal with complex numbers and some routines to show and get data; LOGIC - some routines to make XOR tests. Of course, LR and SR were too fundamental for SFTMEN.
Before explaining the routines, let me present what was my problem:
- calculating for transformers, motors, magnetism.
- transformers have many equations for calculating current, voltage, magnetic field, magnetic densit flux, etc. The other matters also have their equations.
- each equation has its own variables (sometimes shared with other functions). I would like to preserve, when possible, the same register to hold same variable between formulas. Ex: A = B*C and D = B*H;
- where I could merge functions, I did it. Most like the big equation for calculating TVM in HP-12C, where they merged in only one equation the functions for PV, FV, PMT, I and N. But merging many equations in only one brought some troubles. Let's put as this: A = B/D, but A=E/F too. So, I make: A - B/D - E/F = 0, but user should not supply both B and E at same time, or calculus for A would be wrong. So, I need to test if A, B and E were given at same time and not allow it (XOR between then); also, if D or F were not given, when SOLVE evaluates the equation, a division by zero would happen - for this, the solution is to test the variable and fit it with 1 if not given, independent of given B or E.
For "unicity" tests I make a LOGIC program, with some global routines: XORV, XORR, XORA - makes XOR test on stack, comparing X with Y, Z and T registers, directly by the values they hold, or indirectly, by registers numbers they point to, or by a reference in ALPHA. The difference here is that I do not test 1 and 0, but general numeric values and get back 0 or 1. I could not find such routines in Advantage or Math modules;
The HP41 soft menus offers:
Two levels of menus: first level is a parent menu up to 5 options - I call each option a function or equation. It receives these options in a string "F1 F2 F3..." - remember: up to 5 entries and you have only 12 characters in display (you may add . , or : and they do not occupy a character place)!
From first level menu, I get: 0 - none equation selected - or 1...5 and you must redirect (IND X) to a respective numbered label in your main program.
Each of these labels represents the of variables of formula, the validation over data and a global label to calculate the equation in order it gives 0 (I'll use SOLVE for this).
Your caller program must be as this:
- mount the string for parent menu:
LBL "MAGNET"
"FN1 FN2 ...FN5"
XEQ "SFTMENU" I'll prompt menu and wait the user press A - E - returns 1 - 5; or presst R/S - returns 0;
X=0?
RTN
GTO IND X to the choosen function (a numeric local label from 1-5)
Second level: variables menu - up to 2 groups of menus: A - E or a - e for first group menu; and A - E or a - e for second group menu, representing variables of formulas, or topics, selected in first level. Also the name of function (global label) that will calculate such formula.
You have up to 20 "variables" entries. Each one has a fixed associated register, from 1 - 5, 6 - 10 (A-E, first and second menus), and 11 - 15 and 16 - 20 (a-e, first and second menus).
For that formula I put before:
A - B/D - E/F = 0 the menu should be:
"A B D E F" - no need of second menu neither shift soft key(a-e)
But if other equations share these variables too and have new ones?
For example:
A - F/H = 0
A and F are in first formula, associated to A and E menu keys and so to 1 and 5 registers.
So, the menu can be like this for this second equation:
"A ^H - - F" - respectively letters A, b, - , - , E. Here the use of shift key preserve the original registers 1 and 5 to A and F. H get the register 12.
When the variables menu is shown, the user can:
- just press the associated key: the value previously existent will be shown;
- type in a value and press the associated key: this new value will be stored for respective variable;
When he/she takes one of these actions, flag 1 is turned on;
- finally, press R/S: if flag 1 is on, the solution for last variable whose soft key was pressed will be calculated; if flag 1 is off, it was a mistake and nothing happens.
If there is a second menu of variables, a > symbol is added to string of menus you provided. User must press I to show this second menu. In this case, a < symbol is added to it, remembering user that there exists a first menu (I returns to first menu). Also, if user sees that he/she selected the wrong formula, just press J and returns to functions menu.
If the solve is to be calculated, the routine returns to your main program, when you can:
- test for unicity of variables;
- if inconsistencies were found, you can mount a message, call a routine (XEQ "SFT4") to show it and show again variables menu;
- if no inconsistencies were found, check the divisions by zero and fix them:
By example: A/B - A is stored in register 1 and B in two, so:
RCL B
X=0?
1
STO B
This will put 1 in B if it has nothing (0), but will keep original value if it has one.
Everything ok? XEQ "SFT3" for SOLVE the equation;
It seems difficult, isn't it? But, actually, it is really very easy!
Next post I'll show an example.
I've read through many of the solutions and, I believe the "KISS" (keep-it-simple-..) is missing. See my program here:
https://www.hpmuseum.org/software/41/41tmgr15.htm
The sequence I use for softkeys simply places a number in X.
LBL "A", 1, GTO 11
LBL "B", 2, GTO 11
LBL "C", 3, GTO 11
LBL "D", 4, GTO 11
LBL "E", 5, GTO 11
LBL "F", 6, GTO 11
LBL "G", 7, GTO 11
LBL "H", 8, GTO 11
LBL "I", 9, GTO 11
LBL "J", 10 # GTO 11 not needed here. fall through...
# All timer toggle keys A-J funnel through here...
LBL 11
Gene: And, for the record :-) the PPC ROM routine does not have the RTN END combination here.
To my knowledge (?) there is only one "bug" in the PPC ROM code. The LBL BE routine has a GTO BE instruction at the end of its loop instead of a GTO local label.
Rather unfortunate, since it must travel the global alpha label chain each time...and a number of routines use the BE routine.
But I am not aware of any other bug ?
(06-21-2019 10:11 PM)Bill Duncan Wrote: [ -> ]I've read through many of the solutions and, I believe the "KISS" (keep-it-simple-..) is missing. See my program here:
LBL "A", 1, GTO 11
LBL "B", 2, GTO 11
LBL "C", 3, GTO 11
LBL "D", 4, GTO 11
LBL "E", 5, GTO 11
LBL "F", 6, GTO 11
LBL "G", 7, GTO 11
LBL "H", 8, GTO 11
LBL "I", 9, GTO 11
LBL 11
Hi, Bill
That's the idea, but we have just one line in display, so I decided do not use the keys from F to H, as user can't see what variables are associated to them directly.
Instead, I make two sequences of menu. Beyond this, you can mix with a - e (shift keys). This gives you, in principle, 20 variables!
Let's study a simple caller programm:
I need to solve four problems:
First one: magnetic flux
φ = B.A --> φ - B.A = 0
φ = Fmm/R --> φ - Fmm/R =0 , let's make just one equation for both functions:
φ - B.A+Fmm/R = 0
But we can't have φ, B.A and Fmm at same time.
If we will calculate φ, only B.A
or Fmm can be given; if we calculate B, only one of φ
or Fmm, and so on.
So, an XOR on three combining two of them giving the another!!! And you don't know which one will be asked to be solved for!
Also, R can't be equals to 0: R<>0
Second one: permeability
u = B / H
ur = u/u0 --> u = ur.uo
(u + uo.ur) - B/H = 0
Same restrictions: XOR (u, uo.ur, B); H <> 0
Third one: relutance
R = L/(u.A)
ur = u/uo => u = ur.uo (relative permeability and absolute - uo is a constant)
R - L/(u+uo.ur).A = 0 (problems usually have ur, but...)
Again, XOR(R, u, uo.ur) A <> 0
The fourth one: magnetic field
H =
N*I/L
Fmm =
N*I
Let's put in order...
H - (Fmm+NI)/L = 0
XOR(H,Fmm, N*I). L <> 0.
Next post I'll present the variables/keys to these formulas (my wife wants to go window shopping now ...)
Have you seen, Bill, as the problem is bigger and we can't waste memory repeating so many menus?
See you soon!!
Well, let's study the variables allocation in registers.
Remember: I'll try do not use the one register for two variables.
First menu can have 5 keys - A-E or a-e or mix of them;
The same for second menu.
For MAGNETIC FLUX: φ - B.A+Fmm/R = 0
MENU | REG | A...B | REG | a...e |
1st..|..01.|.. - ..|..11.|.. % ..| % represents the theta letter!
.....|..02.|.. B ..|..12.|.......|
.....|..03.|.. A ..|..13.|.......|
.....|..04.|.. R ..|..14.|.......|
.....|..05.|.......|..15.|. FMM .|
2nd..|..06.|.......|..16.|.......|
.....|..07.|.......|..17.|.......|
.....|..08.|.......|..18.|.......|
.....|..09.|.......|..19.|.......|
.....|..10.|.......|..20.|.......|
User will see:
- B A R ^FMM
A B C D E
Key A has no meaning in this menu.
For PERMEABILITY: (u + uo.ur) - B/H = 0
1st..|..01.|.. u ..|..11.|.......|
.....|..02.|.......|..12.|.. L ..|
.....|..05.|. ur ..|..15.|.......|
User will see:
u ^L A R uR
A b .C D E
(The dot is just to align here in my post)
For RELUTANCE: R - L/(u+uo.ur).A = 0
.....|..02.|.. - ..|..12.|.......|
.....|..03.|.......|..13.|.. H ..|
User will see:
u - ^H R uR
A B .c D E
For FIELD INTENSITY: H - (Fmm+NI)/L = 0
1st..|..01.|.. - ..|..11.|.......|
.....|..04.|.......|..14.|.. I ..|
2nd..|..06.|.. N ..|..16.|.......|
User will see:
[font=courier]
- ^L ^H ^I FMM>
A b .c ..d E
second menu (pressing I)
<N
A .B C D E
In real HP code, as we have just 12 characters in display and 15 per line of program, I can use : instead of space to separate some variables.
Bellow, I copy just the appearance of menus. See how I tried to keep each variable attached to one register for all equations.
- B A R ^FMM
u ^L A R uR
u - ^H R uR
- ^L ^H ^I FMM> <N
Next post the implementation of some of these equations.
The caller program:
001 LBL "MAGN" -my program to calculate magnetism problems
002 LBL 15 - a numeric label to save on internals GoTo
003 "MAGN" - repeat the program name,so I can return from menu
004 ASTO X - copy ALPHA to X register
005 "FL PM RL H" - the equations menu
006 XEQ "SFTMEN" - call the main menu program.
The SFTMEN will save program name and menu in registers and will show the parent menu with name of equations (FLux, PerMeability, ReLutance and Field (H))
The user can press from A..D or R/S. It will be returned 0 (nome selected) or 1...5 for the equation selected.
Back to your program:
007 X=0? user didn't select any equation
008 GTO "MAQELE" I'll return to a kind of problems manager (or just put RNT to finish)
009 GTO IND X the user got some equation. It will be executed now.
Here the routine for first equation: magnetic flux
010 LBL 01 - the same number as the position of formula name's in equations menu
011 "FLX" - the global name SOLVE will execute. It will be at the end of this routine (line 32)
012 ASTO X - copy ALPHA to X register
013 "^% B:A:R:^FMM" - the variables menu
014 XEQ "SFT1" - the routine that will start mount the variables menus
SFT1 does not interact with user and returns to caller program:
015 CLA - this equation does not have a second menu, so clean ALPHA
016 XEQ "SFT2" - call the routine for second menu. It will show the first menu and works transition from 1st to 2nd if any.
User can press A-E or a-e, as indicated by display.
Pressing such keys will show any previous value for selected variable;
User can input some value (I'll test flag 22) and press the soft key. I'll save the new value to its register;
When the user does any of these two operations (recall or store), I'll turn on flag 01.
User can also press R/S: if flag 01 is on, I'll solve for the last variable seem/stored; if flag 01 is off, this represents a mistake and menu will be shown again.
Finally, user can press I to go to second menu if there is one (or come from 2nd to 1st menu back) or press J to return to parent menu (equations menu).
Resuming:
A...E; a...e - shows the stored value for the variable; turns on flag 01
number A...E; a...e - stores a new value for variable; turns on flag 01
R/S - if flag 01 is on, will solve for the last seem/stored variable;
I- goes to second/first menu of variables;
J - returns to equations menu (parent menu)
This is all you need for calling soft menus. Now, we will work on data validation.
This point of program only will execute if user selects some variable to solve.
Let's remember the variables versus registers: 11 - flux; 02 - B; 03 - A; 04 - R; 15 - FMM;
Equation: φ - B.A+Fmm/R = 0
First test: XOR over possible variables and the one selected for solving. See that one test is not for a simple variable, but for B.A, so, I have to use the function that tests values in stack (I have others similar functions that can deal with registers numbers, instead of values stored).
017 RCL 11 ............. φ
018 RCL 02 ............... B
019 RCL 03 ................. A
020 * ......................... B.A
021 RCL 15 ..................... FMM
022 RCL IND 44
Register 44 stores the actual register (variable) that will be solved for. So, I'll recover the value stored in that variable.
The next step (XORV) is a function of mine. It will test on stack: X must have the value of variable to solve for. Other levels have it too and two others values. Only one of these can be different of zero.
023 XEQ "XORV"
024 X=0? ................if XORV returns zero is because we have more variables than needed
025 GTO 11 ............ user will get a message to zero any variable
2nd test: no denominator can be zero
026 RCL 04 ..... R
027 X=0?
028 1 .............. if zero, puts 1 in it
029 STO 04
030 XEQ "SFT3" ....... now, let's solve for selected variable
031 GTO 01 . after solving for variable, returns to the function and begins everything again
032 LBL 11 .... for treating the errors above
033 "ZERE %:B*A:FMM"
034 XEQ "SFT4"
035 GTO 01
036 LBL "FLX" ... here the function itself: φ - B.A+Fmm/R = 0 - see line 011.
037 STO IND 44 ... as we are using SOLVE, it will bring the value to test on function.
Store it in IND 44, always.
038 RCL 11 .......φ
039 RCL 02 ....... B
040 RCL 03 ...... A
041 * ........ B.A
042 - ........ φ - B.A
043 RCL 15 ..... FMM
044 RCL 04 ..... R
045 / ........... FMM/R
046 - ....... φ - B.A+Fmm/R
047 RTN
This was the first equation.
Now, the second equation: permeability: (u + uo.ur) - B/H = 0
Variables versus registers: 01 - u; 02 - B; 13 - h; 04 - R; 05 - ur; uo is constant - reg 45
We will need to make XOR(u; ur; B) H <> 0
048 LBL 02 ........ second function
049 "PML"
050 ASTO X
051 CLA ............ here I need the u character. It will cause a disturbe in X register
052 12
053 XTOA
054 "> B ^H R "
055 X<>Y ........ I need to restore X register with function name for SOLVE.
056 XEQ "SFT1"
057 CLA ............... also no second menu
058 XEQ "SFT2"
059 1 .................. now, as we don't have to check result of some operation, I can
060 5 .................. use the registers numbers instead of values and call XORR (by registers)
061 2 .................. u; ur; B
062 RCL 44 ......... and the register number for variable solving
063 XEQ "XORR"
064 X=0?
065 GTO 11 ....... if XOR fails...
066 RCL 13 ...... if variables are ok, finally corrects the H variable
067 X=0?
068 1
069 STO 13
070 XEQ "SFT3" ..... everything ok, let's solve
071 GTO 02 .... once done, go back to function
072 LBL 11 .... for treat errors
073 "ZERE "
074 12 ..... again the u character ...
075 XTOA
076 ">*"
077 XTOA
078 ">R:B"
079 XEQ "SFT4" ... just show a message
080 GTO 02 .... go back to function
081 LBL "PML" ...... the function itself
082 STO IND 44 .... always save IND 44
083 RCL 05
084 RCL 45
085 *
086 RCL 01
087 +
088 RCL 02
089 RCL 13
090 /
091 -
092 RTN
The third equation is like others I post. Just a small difference in test.
We can't have both u and ur at same time. So, we must use another function to make the XOR: XOR2, which tests just 2 values in stack (x,y) (in LOGIC program you will find others functions XOR3, XOR4, X#0?L (is X different of zero? Returning 1 or 0), X=0?L
Well, let's put the fourth equation: H - (Fmm+NI)/L = 0
XOR(FMM; N*I) L <> 0
LBL 04
"IND"
ASTO X
"-^L^HÎ^FMM"
XEQ "SFT1"
"N" ............. here the second menu - very easy!
XEQ "SFT2"
RCL 15
RCL 06
RCL 14
XEQ "XOR2"
X=0?
GTO 11
RCL 12
X=0?
1
STO 12
XEQ "SFT3"
GTO 04
LBL 11
"ZERE FMM:N*I"
XEQ "SFT4"
GTO 04
LBL "IND"
no finished ...
