Full Version: CO-OP 41 Data Collector?
Hi all,
Do any of you have any information on this unit or have a manual for it? I bought a complete (maybe) unit which came with a 41CX with a switched speed up installed. It came with the TDS Co-Op Instrument and Surveying modules and the calculator and modules seem to work fine but I am having trouble creating files in the Data collectors memory.
Without a manual I am not sure if I am working it correctly but I have managed to create files in extended memory.
When I try to create a file in the data collector memory it appears to work and memory available drops but it doesn't show up in the directory. Memory shows 64,490 before trying to create a file.
When running a directory a display shows gibberish for a second or two then shows the memory available. It almost seems like I need to format the memory but hav no idea how to.
Not sure if I am just doing something wrong, if the unit is not working or if there is an internal battery which needs charged or replaced.
I am trying to build a list of commands, what they do and the required input for each which is helped somewhat by a quick reference for a Co-Op Sun Shooter rom which shares many of the same surveying commands but has nothing on the data collector.
Any help would be appreciated.
Ken
(05-05-2019 09:59 PM)Ken S Wrote: [ -> ]Do any of you have any information on this unit or have a manual for it?
I have a couple of manuals for the TDS CO-OP 41 Surveying Module, Instrument Module and Plotter Module. Files are too large for my allotted room in the forum, send me a PM with your email address and I'll shoot them over to you.
ÁM
Thanks Angel,
PM sent.
