05-11-2014, 02:45 PM
For fluids change, what is your preference?
This is a 100% critical process, often overlooked. You fluids change your Saab or Volvo or Maserati, why neglect your calcs????
I use:
Armour all Ultra Shine as a finisher.
Pro-Gold for gold contact enhancement
http://www.deoxitgold.com/?progold_info=1
ClearAudiio UHE Contact Cleaner
http://www.elusivedisc.com/CLEARAUDIO-CL...CLEACLEAN/
High end Rubber cleaner:
http://www.detailedimage.com/Meguiars-M4...2/16oz-S1/
In reverse order
First, you use the Clearaudio to clean it the contacts of all sorts, then the Pro-Gold on the contacts (e.g. for where you plug modules into the 41/71/48 etc)
Then clean the rubbers. then detail the calc first with soft contact cleaner then the high gloss.
Finally, if you can find it, use O2 blocker on the interior:
http://articles.courant.com/1997-03-06/e...o2-blocker
This REVERSES oxidation. Great on older units. even makes the keys snappier.
Next gentle starch lubricant applied with a cloth on rails and hinges for modules. Use any high end one of your choice.
Finally, AAA Lithiums are a must when useable.
Vagn
I use:
In reverse order
Vagn
