(05-12-2019 12:46 PM)Sylvain Cote Wrote: [ -> ]Thank you Jurgen for these nice updates.
(05-12-2019 12:06 PM)Jurgen Keller Wrote: [ -> ]Known issues:
- In Safari the table title sometimes disappears when sorting the columns. I've checked with Firefox, no problem there. So I assume it's a short-coming in Safari. I didn't found a workaround yet.
I have done at least 30 refreshes on different columns and I am not experiencing this issue with Safari 12.1 on macOS High Sierra 10.13.6
Insignificant issue: the up/down arrow associated with the V2 sub-column is displayed on the side of the Page column.
I also use Safari 12.1 but I'm on macOS Mojave 10.14.4. The test case is the following:
- Click on column 'Mnemonic' to sort by mnemonic.
- Shift click on column 'Description' to secondary sort by description.
Now the table caption is gone.
The up/down arrow left to Page is not the one associated with V2. The up/down arrows are on the right of the column title. The one that you mean sorts all Vx columns, however, I don't really understand the order. Maybe I should explicitly define an order as I did for the XROM column.
(05-12-2019 01:24 PM)Jurgen Keller Wrote: [ -> ]I also use Safari 12.1 but I'm on macOS Mojave 10.14.4. The test case is the following:
You are right, can also be reproduced by clicking on any column title after a page refresh.
(05-12-2019 01:24 PM)Jurgen Keller Wrote: [ -> ]The up/down arrow left to Page is not the one associated with V2. The up/down arrows are on the right of the column title. The one that you mean sorts all Vx columns, however, I don't really understand the order. Maybe I should explicitly define an order as I did for the XROM column.
Sorry, there is no issue, sometime I am so
dumb, I put the remark at the last minute and did not recheck myself.
I just wanted to let you know that I've reworked the 41CL Image Identifiers web page a little bit. Besides some visual changes due to the move to Bootstrap, I've tried to include the information about documentation that is available on wiki4hp. For any image with documentation available somewhere, a 'plus sign' icon appears. Just click it to see the links. I took over the categories (Manual, Book, QRG, Brochure) from the table on wiki4hp. I'm open for feedback if you have ideas how to improve the display.
Please note that the link has changed, however, you will be redirected when using the old link:
41CL Image Identifiers (New)
This is work in progress because my time for hobbies is limited. Currently you will see many "todo's" instead of actual documentation titles. But I promise that I will work on it on a regular base. The file containing the documentation links is available on
Github. So basically, the door is open for volunteering :-) However, I also appreciate any hints in this thread or via PM.
I'd be very happy if this little page could also act as a catalyst to bring documentation to light for previously undocumented HP-41 modules. Recently, I got in touch with an 91 years old HP-41 user who was looking for a QuadRAM. So if I'm lucky I have still plenty of time to explore and play around with HP-41 modules!
Edited: Fixed wrong link to Github repo.
Brilliant work Jurgen, your awesome guide just got even more useful! After you got the idea I'm sure it was an obvious thing to add links to the docs, but at the same time a bit daunting because of all the work.
I'm happy to see you chose to do this despite the work, so a huge THANK YOU for this gift that makes this sooo much more useful.
Well done!
(03-10-2023 05:56 PM)Jurgen Keller Wrote: [ -> ]But I promise that I will work on it on a regular base. The file containing the documentation links is available on Github.
Somehow this github link is not working for me.
(03-11-2023 03:19 AM)Dol Wrote: [ -> ] (03-10-2023 05:56 PM)Jurgen Keller Wrote: [ -> ]But I promise that I will work on it on a regular base. The file containing the documentation links is available on Github.
Not only for you, the link was simply wrong. Fixed and sorry for the inconvenience.
(03-11-2023 01:24 AM)rprosperi Wrote: [ -> ]... a huge THANK YOU for this gift that makes this sooo much more useful.
Glad to hear you like it. You know, constant dripping wears away stone, and that's my approach for the documentation pointers. However, I thought it might be already useful as I go along that path.
(03-11-2023 05:35 PM)Ángel Martin Wrote: [ -> ]Absolutely brilliant, thank you Jürgen!
I'm going through the list checking for missing entries/manual, so far I've found these:
for ELIX:
https://www.systemyde.com/pdf/Orbital_Me...Manual.pdf
Thank you much, Ángel, highly appreciated!
I will update the my list accordingly in the next days.
Extremely nice work, Jürgen. Congrats. This would be a very helpfull addition to my databases. I was thinking about if for a long time, but didn't find the time / knowhow to do it.
It's a Swiss product
Matthias
Thank You Jürgen. Very useful!!
Tobie
