04-11-2019, 12:57 PM
Not much to say, directly on the code
The XCAS terminal gives a big push warning
XCAS also gives the answer
But it is the wrong answer
WolframAlpha: ∫(∫(min(x^2,y^2),y,0,1),x,0,3)
Wolfram Alpha is right
Looking forward to the update of hp prime firmware in 2019
Warning, integration of abs or sign assumes constant sign by intervals (correct if the argument is real):
Check [abs(taylorx10^2-taylorx11^2)]
Discontinuities at zeroes of taylorx10^2-taylorx11^2 were not checked
No checks were made for singular points of antiderivative (taylorx10^2*taylorx11+(taylorx11^3)/3-(-(taylorx11^3)/3+taylorx10^2*taylorx11)*sign(taylorx10^2-taylorx11^2))/2 for definite integration in [0,1]
Check [sign(taylorx10^2-1)]
Discontinuities at zeroes of taylorx10^2-1 were not checked
