Full Version: Horizons: Distance to Horizon
After recently seeing this thread http://www.hpmuseum.org/forum/thread-127...ight=Spher
(implementing surface area visible at height)
I have implemented distance to horizon functionality on the HP Prime.
Note: The HP Prime may be capable of better accuracy than some of my examples might suggest...
Some examples probably started out with a different radius.
Version 0.1 implements simple geometric solutions for spheres, taking no account of refraction.
It includes functions for distance to horizon at a given height, and inverse functions.
It also demonstrates some unexpected cas solve behaviour:
The annotated example Print, if included, often seems OK on the 1st run (returning undef), but on later runs all solves return undef, suggestive of an initialisation issue. Earlier versions of the program sometimes generated a large real instead of undef on the 1st run (and on one occasion a large negative, despite the ">=0").
Update: Changing HT to h in the cas solve seems to fix the 2nd run undef problem.
 LOCAL CRID:="Horizons V0.1 © 2019 StephenG1CMZ";
 //This version has simple geometric horizons
 //No refraction
 LOCAL HT;//FOR SOLVE
 LOCAL AU2KM:=149597871;//GOOGLE
 LOCAL RADIUS:=6378140;//m //MUST BE >=0
 //MOST OF MY TEST VALUES ASSUME THIS VALUE. CHOOSE YOUR OWN.
 //EARTH:WORKING IN m ACCURACY IS NORMALLY WITHIN 10cm (OF LATEST DATA)
 LOCAL NA:=0; //"NA", VALUE RETURNED WHEN EG HT<0;
 //Definitions
 //DD   Direct Distance       (eye-horizon)
 //HT   Height above Sphere   (<0=NA)
 //SLen Curved Surface Length (paw-horizon)
 //Distances and heights in same units
 SpSphere(RADIUS)
 //Return Sphere CAV
  LOCAL SpC,SpA,SpV;
  SpC:=2*π*RADIUS;
  SpA:=4*π*RADIUS^2;
  SpV:=((4/3)*π*RADIUS^3);
  RETURN {SpC,SpA,SpV};
 GetSphereSA(RADIUS)
 //RETURN SPHERE SURFACE AREA
  RETURN 4*π*RADIUS^2;
 EXPORT GetDLen(HT,RADIUS) //Direct distance
 //RETURN D is the straight geometrical eye-hZ dist
 //TIMING 58us
   IF HT*RADIUS<0 THEN
    RETURN NA;
   RETURN √(HT*(2*RADIUS+HT));
 EXPORT GetHeightDD(DD,RADIUS)
 //INVERSE
 //RETURN HT TO SEE DD AWAY
  RETURN CAS("solve((HT*(2*RADIUS+HT))-DD^2=0,HT,HT≥0)");
 EXPORT GetHeightSD(SurfLen,RADIUS)
 //INV
 //RETURN HT TO SEE SLEN (SD) AWAY
 // RETURN HT (OR 0 IF SD IMPOSSIBLE TBD)
  RETURN (RADIUS/COS(SurfLen/RADIUS))-RADIUS;
  //RETURN {(RADIUS/COS(SD/RADIUS))-RADIUS,CAS("solve((RADIUS/COS(SD/RADIUS))-RADIUS-HT=0,HT)")};
 EXPORT GetHeightSAF(SAF,RADIUS)
 //INV
 //Get Height for Surface Area (SA in units EG m^2,NOT %)//correction saf as a fraction
   HT:=CAS("solve(HT/(2*(HT+RADIUS))-SAF=0,HT,HT≥0)");
   RETURN HT;
 EXPORT GetSurfLenDD(DD,RADIUS) //Surface Length from DD
 //D is the straight geometrical eye-hor dist
 //RETURN S IS THE SURFACE DISTANCE
 //TIMING 55us
   IF RADIUS==0 THEN
    RETURN NA;
   RETURN RADIUS*ATAN(DD/RADIUS);
 //BOTH THESE S DISTANCES SHOULD BE THE SAME (EXCEPT ROUNDING)
 //THERE IS NO SIGNIFICANT DIFFERENCE
 //HINT:
 //S(HT) IS QUICKER IF YOU ONLY NEED S
 //S(DD) IS QUICKER IF YOU ALSO NEED D (OR KNOW D)
 EXPORT GetSurfLenHT(HT,RADIUS)
 //TIMING 109us QUICKER THAN D+SD
   IF HT*RADIUS<0 OR (RADIUS+HT==0) THEN
    RETURN NA;
   RETURN RADIUS*ACOS(RADIUS/(RADIUS+HT));
 //Surfacevisible at Height
 //FP Fraction
 //PC Percent
 //SA Surface Area (same units as radius)
 EXPORT GetSurfAreaHtFP(HT,RADIUS)
 //Derived From: http://www.hpmuseum.org/forum/thread-12717.html?highlight=Spher
 //Height and Radius in same units. Ht is above surface
 //Return.Proportion Surface Visible at Ht (0-0.5,HT≥0)
 //For example:
 //Radius of Earth = 6378 km
 //Distance of Apollo 17 from Earth's surface at 1972-12-07T10:39Z = 29000 km
 //Visible percentage of Earth's surface in 1972 "Blue Marble" photograph = 40.99% (41%)
  //Guard HT<0:WHAT IS REALLY VISIBLE
  IF HT<0 OR (HT+RADIUS==0)THEN
   RETURN NA;//0 OR 1
  RETURN (HT/(2*(HT+RADIUS)));
 GetSurfaceVisibleHtPC(HT,RADIUS)
  RETURN 100*GetSurfAreaHtFP(HT,RADIUS);
 EXPORT PrintReport(HT,RADIUS)
 //User-Readable-Report
 //Hint: See EX
  LOCAL PLACES:=3;//ROUNDING
  LOCAL DX:=GetDLen(HT,RADIUS);
  LOCAL FP:=GetSurfAreaHtFP(HT,RADIUS);
  PRINT("At Height "+HT+" Radius "+RADIUS);
  PRINT("Geometric visible horizon: "+ROUND(DX,PLACES));
  PRINT("Surface horizon: "+ROUND(GetSurfLenDD(DX,RADIUS),PLACES));
  PRINT("Surface Area: "+ROUND(FP*GetSphereSA(RADIUS/1000),PLACES));
 EXPORT EX(HT,RADIUS)
 //Work an example
 //Exhibits program functionality
 //Hint: See Report
  PRINT("HT "+HT+" R "+RADIUS);
  PRINT("Direct Length "+DX);
  PRINT("SurfaceLenDD "+GetSurfLenDD(DX,RADIUS));
  PRINT("SurfaceLenHT "+GetSurfLenHT(HT,RADIUS));
  PRINT("SurfArea "+STRING({100*FP+"%",FP*GetSphereSA(RADIUS/1000)}));//km
  //PRINT("Verify: HT SD "+GetHeightSD(GetSurfLenHT(HT,RADIUS),RADIUS));
  PRINT("Verify: HT DD "+GetHeightDD(GetDLen     (HT,RADIUS),RADIUS));
  PRINT("Verify: HT SAF"+GetHeightSAF(FP,RADIUS));
  PRINT(" ");
 EXAMPLES()
  // a feW examples : most test data elsWhere
  //HT,D,S (D=STRAIGHT S=CURVED)
  PRINT(); PRINT(CRID); PRINT(" ");WAIT(1);
  PRINT("Sphere: R "+RADIUS/1000+" km. C:A:V:");
  PRINT(SpSphere(RADIUS/1000));//km
  PRINT(" ");
  //HT≤0 RETURNS 0
  //EX(−1,RADIUS);
  EX(0,RADIUS);
  PRINT("//MAN at 2m (D 5.1km)");
  EX(2,RADIUS);
  PRINT("//ISS at 408 km (around 2373 km)");
  EX(427200,RADIUS);
  PRINT("//Eg APOLLO at 29000 km");
  EX(29000ᴇ3,6378000);
  PRINT("//40.5 AU Voyager PALE BLUE DOT");
  EX(40.5*AU2KM,RADIUS);
  //PRINT("//145 AU Voyager 2019");
  //EX(145*AU2KM,RADIUS);
  PRINT("//as Exoplanet of Proxima Centauri");
  EX(268395.131*AU2KM,RADIUS);
  //This last verifies, except solve doesnt
  //CAUTION:
  //INCLUDING THIS PRINT HAS THIS EFFECT:
  //1ST RUN AS EXPECTED (THIS VALUE undef)
  //2ND RUN ALL solve RETURN undef
  //PRINT(GetHeightSAF(0.50,RADIUS));//sometimes undef
  //PRINT("READY");
 EXPORT HORIZONS()
  LOCAL DX;
  LOCAL HT:=2;
  PRINT();
  PRINT(CRID);
  EXAMPLES();
  //PRINT("TEVAL DStraight "+TEVAL(DX:=HZDistanceD(HT,RADIUS)));// 58 CALC D
  //PRINT("TEVAL SurfaceD "+TEVAL(HZDistanceSD(DX,RADIUS)));    // 54 S ADD TO ABOVE
  //PRINT("TEVAL SurfaceH "+TEVAL(HZDistanceSH(HT,RADIUS)));    //109 VS S
Version 0.2:
Improves cas solve implementation (using h instead of HT)
Improves handling of extreme values
Implements inverse surface area calculations (although these may be approximate and need more checking).
Note: The I at the start of the code is a cut-and-paste error - please delete it.
// If you have previously downloaded this, please delete this I:
// I
 LOCAL CRID:="Horizons V0.2 © 2019 StephenG1CMZ";
 //No refraction
 LOCAL HT;//FOR SOLVE //Global h used
 LOCAL NA:=0;  // NA OR 0 => ONE OF:
  //INPUT<0: NOTHING VISIBLE
  //INPUT=0: NOTHING VISIBLE
  //INPUT>0.5:OVER 1/2 OF SPHERE CANNOT BE VISIBLE
  //INPUT=0.5 (INFINITE HEIGHT LIMITING CASE, use UpperLimits for values)
  //AVOID /0 (HOPEFULLY ONE OF THE ABOVE)
 //Definitions
 GetSphereSA(RADIUS)
 //TIMING 58us
   IF HT*RADIUS<0 THEN
    RETURN NA;
 //INVERSE
  IF DD<0 THEN
   //NO UPPER LIMIT TO EYE HEIGHT OR DIST
   //(Imp Limit DD>1ᴇ12 WITH EARTH RADIUS NOT CHECKED)
   RETURN NA;
  HT:=CAS("solve((h*(2*RADIUS+h))-DD^2=0,h,h≥0)");
  RETURN HT;
 //INVERSE
 //Get Height for Surface Area (SAF Fraction of sphere visible, 0..0.5)
 //OR NA IF IMPOSSIBLE
   IF SAF≤0 OR SAF≥0.5 THEN //INCLUDE SAF=0 TRAP
    RETURN NA;
   HT:=CAS("solve(h/(2*(h+RADIUS))-SAF=0,h,h≥0)");
   RETURN HT; //MAX(HT,0);
   //MAX CLIPS SMALL NEGATIVES: NEEDED WHEN SAF=0 UNLESS TRAPPED
 //NB INVERSE SA RESULTS ARE APPROXIMATE
 //BUT NEED CHECKING TBD
 EXPORT GetHeightSA(SA,RADIUS)
 //INVERSE
 //Get Height for Surface Area (SA in units^2)
  LOCAL SAF;
  IF RADIUS==0 THEN
   RETURN NA;
  SAF:=SA/GetSphereSA(RADIUS);
  PRINT(100*SAF);//diagnostic
  HT:=GetHeightSAF(SAF,RADIUS);
  //HT:=RADIUS*((SA*SAF)-1);
  RETURN HT;
 EXPORT GetHeightSL(SurfLen,RADIUS)
 //INVERSE
 //RETURN HT TO SEE SURFLEN AWAY (OR NA IF SURFLEN IMPOSSIBLE)
  IF SurfLen<0 OR SurfLen≥π*RADIUS THEN
   RETURN NA;
  HT:=(RADIUS/COS(SurfLen/RADIUS))-RADIUS;
  RETURN HT;
 //TIMING 55us
   IF RADIUS==0 THEN
    RETURN NA;
 //HINT:
    RETURN NA;
 //FP Fraction
 //PC Percent
 EXPORT GetSurfAreaHTFP(HT,RADIUS)
 //For example:
   RETURN NA;//0 OR 1
 GetSurfAreaHTPC(HT,RADIUS)
  RETURN 100*GetSurfAreaHTFP(HT,RADIUS);
 //Hint: See EX
  LOCAL FP:=GetSurfAreaHTFP(HT,RADIUS);
 //Work an example
 //Hint: See Report
  PRINT("SurfArea "+STRING({100*FP+"%",FP*GetSphereSA(RADIUS)}));
  //PRINT("Verify: HT SD "+GetHeightSL(GetSurfLenHT(HT,RADIUS),RADIUS));
  //PRINT("Verify: HT SA "+GetHeightSA(SA,RADIUS));
  PRINT(" ");
 EXPORT UpperLimits(RADIUS)
 //Upper Limits = Half Sphere = Infinite Height
 //Appply to SurfLen,SurfArea. Not DD and HT
  LOCAL SpC,SpA;
   SpC:=π*RADIUS;
   SpA:=2*π*RADIUS^2;
   RETURN {SpC,SpA};//HALF SPHERE
 EXAMPLES()
  PRINT("Sphere: R "+RADIUS/1000+" km. Circ & Area:");
  PRINT(2*UpperLimits(RADIUS/1000));//km
  PRINT("Upper limits: SurfLen & SurfArea");
  PRINT(STRING(UpperLimits(RADIUS))+" m,m^2");//m
  PRINT(" ");
  //HT≤0 RETURNS 0
  //EX(−1,RADIUS);
  EX(0,RADIUS);
  EX(2,RADIUS);
  EX(427200,RADIUS);
  PRINT("Verify+:"+GetHeightSA(2.09514275019ᴇ14,RADIUS));
  PRINT("Note the differences in these calculations...");
  PRINT("My inverse surface area may be inaccurate");
  PRINT(" ");
  PRINT("//Viewed as Exoplanet from Proxima Centauri");
  //Test Traps
  PRINT(GetHeightDD(2ᴇ12,RADIUS));
  PRINT(GetHeightSL(π*RADIUS,RADIUS));
  PRINT(GetHeightSAF(0.50,RADIUS));//undef unless trapped
  //PRINT("READY");
 EXPORT HORIZONS()
  LOCAL DX;
  LOCAL HT:=2;
  PRINT();
  PRINT(CRID);
  EXAMPLES();
Note: Some of my examples are incorrect - I mangled km and m. In particular, the AU2KM AU2M conversion.
New in Version 0.3:
GetAngular - Gets angular size of a distant sphere (suitable for celestial use)
GetDip2Horizon (from eye height)
Improves: Examples, PrintReport
 LOCAL CRID:="Horizons V0.3 © 2019 StephenG1CMZ";
 //No refraction
 LOCAL AU2M:=1000*AU2KM;
 LOCAL KR2D:=180/π;
 LOCAL RSUN:=109*RADIUS;
  //AVOID /0 OR √(<0) (HOPEFULLY ONE OF THE ABOVE)
  //AVOID ASIN>1 (ie RADIUS>DistC)
 //Definitions //Distances and heights in same units
 //DistC DistanceToC=HT+RADIUS (eye to centre of sphere)
 //HT    Height above Sphere   (eye to surface. <0=NA)
 //RADIUS                      (of Sphere)
 //AU    Astronomical Unit
 //mas   milliarcseconds
 GetSphereSA(RADIUS)
 GetAngularRadians(DistC,RADIUS)
 //The observed angular diameter at the eye (ignoring physiology)
 ///This DistC ASIN implement is suitable for celestial use (observing 3D spheres)
 ///(An alternate using HT ATAN is known for observing 2D disks)
  LOCAL DIAMETER:=2*RADIUS;
  //LOCAL AS;
  IF DistC==0 THEN
   RETURN NA;//IF INSTEAD HT=0 WERE TRAPPED return π
  IF RADIUS>DistC THEN //TOO WIDE TO SEE??
   //IF NOT TRAPPED OUTPUT JUST STOPS!
   MSGBOX("HORIZONS:GetAngular(RADIUS>DX) => ASIN>1 ERR");
   MSGBOX({RADIUS,DistC});
   RETURN NA; //π/2; //BEST VALUE TO RETURN TBC
  RETURN 2*ASIN(DIAMETER/(2*DistC));
 EXPORT GetAngularDegrees(DistC,RADIUS)
  RETURN GetAngularRadians(DistC,RADIUS)*KR2D;
 GetDipRadiansDD(DD,RADIUS)
 //Dip to horizon
  IF RADIUS==0 THEN
   RETURN NA;
  RETURN ATAN(DD/RADIUS);
 EXPORT GetDipDegreesDD(DD,RADIUS)
  RETURN GetDipRadiansDD(DD,RADIUS)*KR2D;
 GetDipRadiansHT(HT,RADIUS)
 //Dip to horizon
  IF RADIUS+HT==0 THEN
   RETURN NA;
  RETURN ACOS(RADIUS/(RADIUS+HT));
  //OR RETURN ATAN(DD/RADIUS);
 EXPORT GetDipDegreesHT(HT,RADIUS)
  RETURN GetDipRadiansHT(HT,RADIUS)*KR2D;
 //TIMING 58us
   IF HT*RADIUS<0 THEN
    RETURN NA;
 //INVERSE
  IF DD<0 THEN
   RETURN NA;
  RETURN HT;
 //INVERSE
    RETURN NA;
 //INVERSE
  LOCAL SAF;
  IF RADIUS==0 THEN
   RETURN NA;
  //PRINT(100*SAF);//DIAGNOSTIC % INACCURATE
  RETURN HT;
 //INVERSE
   RETURN NA;
  RETURN HT;
 //TIMING 55us
   IF RADIUS==0 THEN
    RETURN NA;
 //HINT:
    RETURN NA;
 //FP Fraction
 //PC Percent
 //For example:
   RETURN NA;//0 OR 1
 //UNITS IS ONLY FOR READABILITY
 //Hint: See EX
  LOCAL UNITS:=" ";
  PRINT("At Height "+HT+UNITS+" Radius "+RADIUS+UNITS);
  PRINT("Eye-horizon : "+ROUND(DX,PLACES)+UNITS);
  PRINT("Paw-horizon : "+ROUND(GetSurfLenDD(DX,RADIUS),PLACES)+UNITS);
  PRINT("Dip-horizon : "+ROUND(GetDipDegreesHT(HT,RADIUS),PLACES)+" °");
  PRINT("Surface Area: "+ROUND(FP*GetSphereSA(RADIUS/1000),PLACES));//m TO km
 //Work an example
 //Hint: See Report
  PRINT("Verify: HT SAF "+GetHeightSAF(FP,RADIUS));
  PRINT("Dip: "+GetDipDegreesHT(HT,RADIUS));
  PRINT(" ");
  LOCAL SpC,SpA;
   SpC:=π*RADIUS;
   SpA:=2*π*RADIUS^2;
 EXAMPLES()
  // a few examples : most test data elsewhere
  PRINT(" ");
  //HT≤0 RETURNS 0
  //EX(−1,RADIUS);
  EX(0,RADIUS);
  EX(2,RADIUS);
  PRINT("//ISS at about 408 km ( ~2373 km)");
  EX(427200,RADIUS);
  PRINT("//51ᴇ3 mas,140 °");
  PRINT(60*60*1000*GetAngularDegrees(427200,108.5/2)+" mas"); //ISS fom Earth
  //The next yields an ASIN error unless trapped.
  //PRINT(           GetAngularDegrees(427200,       RADIUS )+" °");   //Earth from ISS - Wrong Parameters?
  // OK
  PRINT(           GetAngularDegrees(427200+RADIUS,RADIUS )+" °");   //Earth from ISS
  PRINT("//GPS SATELLITES (38%)");
  EX(20000ᴇ3,RADIUS);
  PRINT(" ");
  PRINT("//Sun 31-32");
  PRINT(60*GetAngularDegrees(AU2M,RSUN));
  EX(40.5*AU2M,RADIUS);
  //EX(145*AU2M,RADIUS);
  EX(268395.131*AU2M,RADIUS);
  PRINT("Proxima Centauri from here:");
  PRINT("//angular: (1.02 mas)");
  PRINT(1000*60*60*GetAngularDegrees(268395.131*AU2M,0.1542*RSUN)+" mas");//Proxima DX and radius
  //Test Traps
  //PRINT("READY");
 EXPORT HORIZONS()
  //LOCAL DD;
  LOCAL HT:=2;
  PRINT();
  PRINT(CRID);
  EXAMPLES();
  //PRINT("TEVAL DStraight "+TEVAL(DD:=HZDistanceD(HT,RADIUS)));// 58 CALC D
  //PRINT("TEVAL SurfaceD "+TEVAL(HZDistanceSD(DD,RADIUS)));    // 54 S ADD TO ABOVE
