03-28-2019, 12:51 AM
I need a ribbon cable that will connect (as female end) to a 40mm 16 pin male (on a LCD screen) and the other end needs to be an 18mm 16 exposed pins which then slides and locks on the PCB.
Does anyone know what part/ribbon cable I could buy to achieve this please?
Another thought I’ve had is is there some sort of adaptor that would connect to the 16 pins on the LCD screen to convert it to still 16 pins but an 18mm size. That way I could just use a standard 18mm 16 pin Ribbon Cable that is 18mm each end?
Thanks
Thanks
