03-19-2019, 12:19 PM
An extract from HP-41C Programs and Instructions for Probability and Statistics, Naval Postgraduate School, NPS55-84-003, FEB 1984, 108 pgs.
ABSTRACT
A compendium of programs and instructions to solve problems typically encountered in probability and statistics. Programs are designed to operate directly on the HP-41C family of hand-held calculators.
INTRODUCTION
The purpose of this report is to make available a set of programs and the corresponding user instructions so that the problem material found in the writer's textbooks, Probability by Calculator and Statistics by Calculator (hereafter referred to, respectively, as ZP and ZS) may be resolved using the HP-41C calculator. In particular, this means that courses using those textbooks, written entirely around the TI-59, need no longer be restricted to that particular machine as a prerequisite. It is almost essential, however, that the HP user have in his, or her possession either the HP-4ICV, or the HP-41C with the quad memory module installed, along with a card reader for recording magnetic cards. Also, as with the TI-59, it will be necessary to insert the HP applications module STAT PAC for use with the programs in ZS. No additional module is required for ZP.
and now, for something completely different … TI 2 HP …
BEST!
SlideRule
ABSTRACT
INTRODUCTION
BEST!
SlideRule
