03-09-2019, 04:49 PM
This program uses divided differences to determine the Newton polynomial:
\(N(x)=[y_{0}]+[y_{0},y_{1}](x-x_{0})+\cdots +[y_{0},\ldots ,y_{k}](x-x_{0})(x-x_{1})\cdots (x-x_{{k-1}})\)
Definition of the Polynomial
The polynomial of degree \(n\) is defined by \(n+1\) points \(P_i=(x_i, y_i)\) for \(i \in \{0, \cdots, n\}\), where all \(x_i\) are different.
This program can be used to enter the points \(P_i\):
Initialisation
Before you enter points, make sure the counter is reset:
0
STO 00
Example:
Find a quadratic polynomial given these 3 points: \(P_0(-5, 12)\), \(P_1(1, 13)\) and \(P_2(2, 11)\)
0 STO 00
-5 ENTER 12
XEQ "P+"
1 ENTER 13
XEQ "P+"
2 ENTER 11
XEQ "P+"
These are the coefficients of the Newton polynomial:
R03: 12.000000
R05: 0.166667
R07: -0.309524
This leads to the formula:
\(f(x) = 12 + (x+5)(\frac{1}{6} - (x-1)\frac{13}{42})\)
Interpolation of the Polynomial
This program can be used to evaluate the polynomial:
Example:
Evaluate the polynomial at \(x=0.5\).
0.5
XEQ "f(x)"
13.7679
Adding more data points
An advantage of this method is that the polynomial can be evaluated before all points have been entered.
So you can add more points if the interpolation is not considered sufficient.
Example:
Interpolation of \(\sin(x)\) using values at 0°, 45° and 90°.
0 STO 00
0 ENTER
XEQ "P+"
45 ENTER 0.5 √x
XEQ "P+"
90 ENTER 1
XEQ "P+"
Compare the interpolation at 23° with the correct value:
23
XEQ "f(x)"
0.4132
23
SIN
0.3907
%CH
-5.4289
Add an additional point at 30°:
30 ENTER 0.5
XEQ "P+"
23
XEQ "f(x)"
0.3913
23
SIN
%CH
-0.1397
Add an additional point at 60°:
60 ENTER 0.75 √x
XEQ "P+"
23
XEQ "f(x)"
0.3906
23
SIN
%CH
0.0224
Registers
This is the situation with 3 points:
R00: 3 … number of points
R01: k … index
R02: \(x_0\)
R03: \([y_0]\)
R04: \(x_1\)
R05: \([y_0, y_1]\)
R06: \(x_2\)
R07: \([y_0, y_1, y_2]\)
R08: \([y_1, y_2]\)
R09: \([y_2]\)
When the next point is entered, some of the values at the end are overwritten:
R00: 4 … number of points
R01: k … index
R02: \(x_0\)
R03: \([y_0]\)
R04: \(x_1\)
R05: \([y_0, y_1]\)
R06: \(x_2\)
R08: \(x_3\)
R09: \([y_0, y_1, y_2, y_3]\)
R10: \([y_1, y_2, y_3]\)
R11: \([y_2, y_3]\)
R12: \([y_3]\)
PS: For 3 points I've already posted programs for the HP-67 and HP-15C.
00 { 58-Byte Prgm }
01▸LBL "P+"
02 RCL 00
03 1
04 +
05 STO 00
06 3.002
07 ×
08 STO 01
09 R↓
10▸LBL 00
11 STO IND 01
12 DSE 01
13 GTO 01
14 R↓
15 STO IND 01
16 RTN
17▸LBL 01
18 RCL 01
19 2
20 -
21 R↓
22 RCL- IND ST T
23 RCL 00
24 2
25 ×
26 RCL- 01
27 2
28 ×
29 X<> ST T
30 RCL- IND ST T
31 ÷
32 GTO 00
33 END
Initialisation
0
STO 00
Example:
0 STO 00
-5 ENTER 12
XEQ "P+"
1 ENTER 13
XEQ "P+"
2 ENTER 11
XEQ "P+"
R03: 12.000000
R05: 0.166667
R07: -0.309524
00 { 37-Byte Prgm }
01▸LBL "f(x)"
02 1.001
03 RCL 00
04 2
05 ×
06 +
07 STO 01
08 CLX
09▸LBL 00
10 RCL IND 01
11 X<>Y
12 DSE 01
13 R↑
14 RCL- IND 01
15 ×
16 +
17 DSE 01
18 GTO 00
19 END
Example:
0.5
XEQ "f(x)"
13.7679
Example:
0 STO 00
0 ENTER
XEQ "P+"
45 ENTER 0.5 √x
XEQ "P+"
90 ENTER 1
XEQ "P+"
23
XEQ "f(x)"
0.4132
23
SIN
0.3907
%CH
-5.4289
30 ENTER 0.5
XEQ "P+"
23
XEQ "f(x)"
0.3913
23
SIN
%CH
-0.1397
60 ENTER 0.75 √x
XEQ "P+"
23
XEQ "f(x)"
0.3906
23
SIN
%CH
0.0224
Registers
R01: k … index
R02: \(x_0\)
R03: \([y_0]\)
R04: \(x_1\)
R05: \([y_0, y_1]\)
R06: \(x_2\)
R08: \([y_1, y_2]\)
R09: \([y_2]\)
R01: k … index
R02: \(x_0\)
R03: \([y_0]\)
R04: \(x_1\)
R05: \([y_0, y_1]\)
R06: \(x_2\)
R08: \(x_3\)
R11: \([y_2, y_3]\)
R12: \([y_3]\)
