2 days ago, I just released:
* Emu28 for Android version 1.0, based on Emu28 version 1.33 from Christoph Gießelink. It should have all the features of Emu42 for Android version 1.2.
Links:
Github
https://github.com/dgis/emu28android
Binaries
http://regis.cosnier.free.fr/soft/androi...Binary.zip
Sources
http://regis.cosnier.free.fr/soft/androi...Source.zip
It is not available in the Google Play Store because it is not easy for the users to add the KML and the ROMs, and it leads to have bad comments like with Emu42 for Android in the Play Store.
Any way, here the original KML files from Christoph with the fixed filenames (for the case sensitive):
http://regis.cosnier.free.fr/soft/androi...iginal.zip
* Emu42 for Android version 1.2, the big improvements:
- Update from the original source code Emu42 version 1.24 from Christoph Gießelink which support HP10B, HP20S, HP21S too.
- Add an optional overlapping LCD part stuck to the screen when swiping the 2 calc parts.
- Make the setting Layout/Auto Zoom by default.
- Support the transparency in the KML Global Color.
Links:
Github
https://github.com/dgis/emu42android
Google Play Store
https://play.google.com/store/apps/detai....forty.two
Binaries
Sources
The KML files
http://regis.cosnier.free.fr/soft/androi...t-ROMs.zip
* Emu48 for Android version 1.7, the big improvements:
- Updated source code from Eric Rechlin's Emu48 version 1.61+ that was merged from Christoph Gießelink's Emu48 version 1.62.
Links:
Github
https://github.com/dgis/emu48android
Google Play Store
https://play.google.com/store/apps/detai...orty.eight
Binaries
Sources
* Emu71 for Android version 1.0beta1. It is almost there.
HP-IL is not working yet because the socket can connect toward Ilper.exe on a PC with Windows,
but the socket cannot connect back to Emu71 in Android. I don't know why for the moment.
And there are still some small bugs in the port/module configuration.
Links:
Github
https://github.com/dgis/emu71android
Binaries
Sources
The KML files
(11-15-2019 08:28 AM)Vincent Weber Wrote: [ -> ]I have tried Emu28.
It works well, except:
1/As Emu42, Emu28 treats file names as case sensitive, and there are mismatches in case for the KML files. A real pain to fix manually. I would love that the emulators are case insensitive once for all...
2/The orientation is always landscape, even if the UI setting is "auto orientation". Only flipping is allowed, but no portrait mode. A pain on my Galaxy S8. Strange...
1/Android is based on Linux, and the filenames are case sensitive. So, it is difficult to make it easier, sorry.
2/In Emu28 and Emu42 for Android, I made the "Settings/Layout/Auto Zoom" by default,
so, the calculator layout will adapt itself following the orientation (if you have the default "Settings/Rotation/Allow rotation").
Moreover, you can activate the "Settings/Overlapping LCD mode" to have the screen always visible when you swipe.
You can pan or zoom this little LCD screen, and double tap it to put it at its default location.
