I wonder what would be the shortest 2 line display HP/DM calc program to show at what time (exact to a second) past given hour hands would be at 0 AND 180 degrees.
I've solved it, but I'm sure forum's geniuses would be able to come up with better solution.
(03-02-2019 02:47 AM)RMollov Wrote: [ -> ]I wonder what would be the shortest 2 line display HP/DM calc program to show at what time (exact to a second) past given hour hands would be at 0 AND 180 degrees.
I have read this sentence several times, but obviously my command of the English language is not sufficient to get its meaning.
But then... as I write this there are more than 170 views of this thread, but still no reply (this is the first one). Maybe your idea is really a bit hard to get? For instance the part with "hour hands would be at 0 AND 180 degrees". All clocks I know have exactly one hour hand, so it can be either at 0° or 180°, but not both at the same time ("AND"). By the way: 0° and 180° relative to what?
Maybe a more detailled explanation and an example will revive this thread.
Dieter
(03-05-2019 07:17 PM)Dieter Wrote: [ -> ]I have read this sentence several times, but obviously my command of the English language is not sufficient to get its meaning.
+1, English is not my first language and I don't get what's this challenge is about. And the mention of a 2 line display program is adding to my confusion.
Perhaps RMollov means the times at which the hour and minute hands are separated by 180 degrees? That should happen 11 times per 12 hour period, mirror symmetrical about 6 o'clock.
and
(03-05-2019 07:30 PM)Didier Lachieze Wrote: [ -> ]+1, English is not my first language and I don't get what's this challenge is about. And the mention of a 2 line display program is adding to my confusion.
English IS my first language, and I could not follow it either; perhaps it is not RMollov's? I was going to comment but thought I'd wait to see if it was me; I guess not. The 2-line display comment threw me off as well, how is this related?
Yes, please explain this further when you can.
Hi, Bob:
(03-05-2019 11:29 PM)rprosperi Wrote: [ -> ]English IS my first language, and I could not follow it either; perhaps it is not RMollov's? I was going to comment but thought I'd wait to see if it was me; I guess not. The 2-line display comment threw me off as well, how is this related?
English is not my first language (that would be Spanish) but I understood it like this:
"I wonder what would be the shortest program for a 2-line display HP/DM calc (i.e.: HP42S / DM42) that shows at what time (accurate to the second) past a user-specified hour (i.e.: 0:00, 1:00, ... 23:00) would the clock's hands form an angle of either 0º or 180º."
Best regards.
V.
(03-06-2019 02:10 AM)Valentin Albillo Wrote: [ -> ]"I wonder what would be the shortest program for a 2-line display HP/DM calc (i.e.: HP42S / DM42) that shows at what time (accurate to the second) past a user-specified hour (i.e.: 0:00, 1:00, ... 23:00) would the clock's hands form an angle of either 0º or 180º."
Well, this makes sense and it is a non-trivial challenge, so it's a good guess, but I still don't follow the 2-line display aspect of the challenge. An HP-42S is, but the DM42 is not (it shows up to 5), and all the other DM models are 1-line displays. And so, if the 42S was meant specifically, why not just say 42S?
Possibly the intention is to have the program OUTPUT 2 lines, 1 for 0 degrees, and 1 for 180 degrees (hence the AND)?
Anyhow, I imagine we'll know soon when RMollov visits again and clarifies the challenge.
(03-06-2019 02:10 AM)Valentin Albillo Wrote: [ -> ]English is not my first language (that would be Spanish) but I understood it like this:
Best regards.
V.
Thanks, Valentin, that's it! English isn't my first language too
One note, on an analog clock 13, 14 etc. do not exist, so the input ("Hour") is MOD'd to 12.
Thank you all, I should have posted here my solution which does what I meant. Here it is:
00 { 71-Byte Prgm }
01▶LBL "CLOCK"
02 IP
03 12
04 MOD
05 STO "Hour"
06 6
07 X≤Y?
08 +/-
09 SIGN
10 180
11 ×
12 30
13 RCL× ST Z
14 +
15 120
16 ×
17 11
18 ÷
19 3600
20 ÷
21 →HMS
22 +
23 RCL "Hour"
24 11
25 ÷
26 →HMS
27 RCL+ "Hour"
28 END
So hands (past "the" "Hour") are either on top of each other, or one is a prolongation of the other at the times in X and Y of HP42S or DM42 (if stack arrangement fits HP42's) running the program with "Hour" in X.
Thanks and sorry for the ambiguity in my first post, hope now it's clearer
(03-06-2019 02:10 AM)Valentin Albillo Wrote: [ -> ].
Hi, Bob:
Best regards.
V.
So either 0º or 180º would occur every \(\frac{6}{11}\) hours (22 times per 12 hour period, or 44 times a day).
(03-06-2019 05:57 PM)ijabbott Wrote: [ -> ]So either 0º or 180º would occur every \(\frac{6}{11}\) hours (22 times per 12 hour period, or 44 times a day).
Not only that, but the 0° and 180° events are uniformly spaced: there is a 0° event exactly halfway between two adjacent 180° events, and vice versa. You could generalize this further by counting the moments when the hands are at right angles to each other, which always happens halfway between 0° and 180°, or 180° and 0°.
(03-06-2019 06:40 PM)Thomas Okken Wrote: [ -> ]Not only that, but the 0° and 180° events are uniformly spaced: there is a 0° event exactly halfway between two adjacent 180° events, and vice versa.
The peculiar thing happens between 5 and 6 o'clock when the order of the 0° and the 180° event changes.
Examples:
5
XEQ "CLOCK"
y: 6.0000
x: 5.2716
6
XEQ "CLOCK"
y: 6.0000
x: 6.3244
Until 5 the 0° event happens before the 180° event.
From 6 on the 0° event happens after the 180° event.
This makes the calculation of these events "past given hour" somewhat complicated.
It's not a RPN keystroke solution, but I hope it's ok:
INPUT H
F=12/11
PRINT DMS(H*F)
IF H<6 THEN PRINT DMS((H+6)*F-6) ELSE DMS((H-6)*F+6)
(03-06-2019 10:03 PM)xerxes Wrote: [ -> ]It's not a RPN keystroke solution, but I hope it's ok:
INPUT H
F=12/11
PRINT DMS(H*F)
Excellent! The above works on the HP-71B if a lexfile is installed which adds the DMS or HMS function (e.g. the famous, fabulous JPC ROM). If an input of 12 is allowed (since analog clocks do show a 12), then H=MOD(H,12) should be inserted after the input.
(03-06-2019 07:28 PM)Thomas Klemm Wrote: [ -> ]The peculiar thing happens between 5 and 6 o'clock when the order of the 0° and the 180° event changes.
Examples:
5
XEQ "CLOCK"
y: 6.0000
x: 5.2716
6
XEQ "CLOCK"
y: 6.0000
x: 6.3244
Yes, that is the tricky bit. Thanks
A more compact version with Joe's suggestion:
INPUT H
H=MOD(H,12)
F=12/11
IF H<6 THEN D=-6 ELSE D=6
PRINT DMS(H*F)
PRINT DMS((H-D)*F+D)
The very limited FX-180P makes it somewhat complicated, but it's possible:
P1:
01 Kin1
02 Kin2
03 1
04 2
05 /
06 1
07 1
08 *
09 Kin3
10 Kout1
11 =
12 °′″←
13 HLT
14 6
15 Kin-2
16 Kout2
P2:
01 +/-
02 x>0
03 Kin/2
04 6
05 Kin*2
06 Kout2
07 Kin+1
08 Kout3
09 Kin*1
10 Kout2
11 Kin-1
12 Kout1
13 °′″←
29 steps
Usage example: 7 P1 RUN P2
The 180° result for 6 o'clock is excluded and gives an error.
[quote='xerxes' pid='113402' dateline='1551968341']
INPUT H
H=MOD(H,12)
F=12/11
PRINT DMS(H*F)
Very elegant! Based on it here is my RPN (HP42S/DM42) take:
00 { 39-Byte Prgm }
01▶LBL "CLOCK"
02 IP
03 12
04 MOD
05 6
06 X>Y?
07 +/-
08 LASTX
09 11
10 ÷
11 R^
12 RCL× ST Y
13 →HMS
14 R^
15 RCL- ST T
16 RCL× ST Z
17 RCL+ ST T
18 →HMS
19 END
