03-04-2019, 10:49 AM
(03-03-2019 06:52 PM)Gerson W. Barbosa Wrote: [ -> ]That’s what I get on my TI 57, but on my 12c Prestige (and on the latest Platinums, I presume), arguments on the display cannot be reused after an operator.
But it seems to have worked on early 12CPs, as Robert noted.
(03-03-2019 06:52 PM)Gerson W. Barbosa Wrote: [ -> ]IMHO, this is a feature, not a bug. Although the old behavior is apparently more convenient in some situations, I prefer this new one
I prefer the other way as it can shorten and simplify quite a lot of calculations. For instance the sum formula (n²+n)/2, that's simply + x² / 2. Add an "=" before the division, if required.
On some (many, most, all?) TIs, e.g. the 58/59, there even was a way to re-enter the displayed value during a calculation by means of the CE key, as in
5 x ( CE + 1 ) / 2 =
I really appreciated this as it helped overcome the limitations of AOS (a bit).
But then...
(03-03-2019 06:52 PM)Gerson W. Barbosa Wrote: [ -> ](or at least I would if I chose ALG, which I never will).
That's what I really love about RPN: it's direct, straightforward and unambiguos. It simply does what you tell it to do and intermediate results can be freely stored on the stack.
Dieter
