03-01-2019, 04:55 AM
Quote:The point I want to emphasize is the ease with which a new arithmetic can-- Chuck Moore
be defined using the post-fix nature of the FORTH interpreter, and the
readability of the resulting equations.
Based on A LANGUAGE FOR DIGITAL DESIGN I wrote these programs for the HP-48GX.
A signal has bit 15 on (+5V) or off (GND) .
Bits 14-0 hold the time it becomes known (ns or .1ns).
# 32768d == # 8000h
# 32767d == # 7FFFh
Digital logic simulator
S. types the value and time of a signal (+ indicating +5V).
« DUP # 32767d AND
IF # 32768d ROT OVER AND ==
THEN "+" →TAG
END
¬ complements a signal (without changing its time).
« # 32768d XOR »
max returns the maximum of two binary numbers.
IF DUP2 <
THEN SWAP
END DROP
and combines 2 signals with worst case timing.
« OVER # 23767d AND
OVER # 23767d AND
max
ROT # 32768d AND
ROT # 32768d AND
AND +
or combines 2 signals using DeMorgan's law.
« ¬ SWAP ¬ and ¬ »
Technology
AND2¬ is a 2-input nand gate with 9ns delay.
« and ¬ # 9d + »
OR3 is a 3-input or gate with 30ns delay.
« or or # 30d + »
XOR2 is a 2-input exclusive-or gate with 35ns delay.
« OVER ¬ OVER and
SWAP ¬ ROT and
or # 35d +
Logic equations
A is a signal known low at 0ns.
# 0d
B is a signal known low at 10ms.
# 10d
C is a signal known high at 10ms.
« # 10d ¬ »
ENB¬ is a signal determined low by A and B at 45ns.
« A B XOR2 »
XY is a signal determined high by A, B and C at 84ns.
« ENB¬ C AND2¬ A B OR3 »
Examples
ENB¬
S.
# 45d
XY
S.
+: # 84d
Kind regards
