02-18-2019, 03:16 AM
The program MVCL calculates the minimum vertical curve length for sight distances for crest curves (curve that rises then falls) and sag curves (curves that falls than rises). The equations used were determined by the AASHTO (American Association of Highway and Transportation Officials of Washington, D.C.).
HP Prime Program MVCL
Example 1:
Grade 1: -1.75%
Grade 2: 2.25%
Design Speed: 40 mph
Result:
Minimum Vertical Curve Length
Crest Curve: 70.5 ft
Sag Curve: 243.125 ft
Example 2:
Grade 1: -1%
Grade 2: 1.7%
Design Speed: 50 mph
Result:
Crest Curve: 50.740740741 ft
Sag Curve: 150.925925926 ft
Source:https://edspi31415.blogspot.com/2019/02/...tical.html
Michael R. Lindberg, PE “Civil Engineering Reference Manual for the PE Exam” 11th Ed. Professional Publications, Inc: Belmont, CA. 2008. ISBN 13-978-1-59126-192-2
Link to blog post:
EXPORT MVCL()
// Minimum stop speed
LOCAL g1,g2,a,c,l,s,g;
MSGBOX("Break = 2.5 s,
Decel = 11.2 ft/s^2");
LOCAL l1:={15,20,25,30,35,40,45,
50,55,60,65,70,75,80};
LOCAL l2:={80,115,155,200,250,
305,360,425,495,570,645,730,
820,910};
INPUT({g1,g2,{c,l1}},"MVCL",
{"Grade1%:","Grade2%:",
"Speed:"});
s:=l2(c);
a:=ABS(g1-g2);
l:=2*s-2158/a;
IF s<l THEN
l:=a*s^2/2158;
g:=2*s-(400+3.5*s)/a;
IF s<g THEN
g:=(a*s^2)/(400+3.5*s);
PRINT();
PRINT("Stop speed (ft)");
PRINT("Crest curve: "+l);
PRINT("Sag curve: "+g);
Example 1:
Grade 1: -1.75%
Grade 2: 2.25%
Result:
Example 2:
Grade 1: -1%
Grade 2: 1.7%
Result:
Link to blog post:
