02-01-2019, 09:35 PM
An extract from Phase-Locked Loop Design Articles, Mototola, AR254/D
Analyze, don't estimate, phase-lock-loop performance of type-2, third-order systems
a small programmable calculator, the HP-25, easily -and exactly- determines the complete loop transfer function in 48 steps.
Optimize phase-lock loops to meet your needs-or determine why you can't
This article will show you how to optimize … a type-2, third-order PLL system with a 48-step program for an HP-25 programmable calculator … to your requirements.
Suppress phase-lock-loop sidebands without introducing instability
The first two parts of this series showed how to analyze and then optimize type-2, third-order PLL systems and provided simple calculator programs for an HP-25 to do the otherwise tedious computations. This article takes you a step further and shows how to suppress sidebands, especially undesired when the PLL is used in frequency-synthesis systems.
Programmable calculator computes PLL noise, stability
Calculate the noise spectral density and short-term frequency stability in a PLL with a programmable calculator, and vary the parameters to trade off the noise/functional performance requirements.
the first three programs in HP-25 notation are HP-29C compatible.
BEST!
SlideRule
BEST!
SlideRule
