11-08-2019, 09:01 AM
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
11-08-2019, 10:15 AM
(11-08-2019 09:01 AM)PANAMATIK Wrote: [ -> ]Same to me. Tony, you are a genius!
Bernhard
I wish that were the case ;-)
cheers
Tony
11-09-2019, 11:02 AM
Nope, definitely not a genius. The difference between a fool and a genius is that that the latter has limits and Tony's doesn't appear to have any
11-09-2019, 12:40 PM
(11-09-2019 11:02 AM)Paul Dale Wrote: [ -> ]Nope, definitely not a genius. The difference between a fool and a genius is that that the latter has limits and Tony's doesn't appear to have any
As Clint Eastwood said .... :-)
I'd actually put myself on a lesser par with Bernhard and some earlier achievers.
cheers
Tony
11-14-2019, 11:03 AM
Hi all,
Some more progress.
Here is the HP-65 CPU board almost populated with a little test wire hanging in the breeze.
All power supplies work ok, Battery 3.7-4.5V. Volts out are 8V, 6V, 5V and 3.3V.
Most software has been written, bugs are next.
cheers
Tony
Some more progress.
cheers
Tony
11-17-2019, 05:13 AM
Hi all,
Happy today :-)
The classic display drivers have responded nicely to my new single processor interface.
cheers
Tony
Happy today :-)
cheers
Tony
11-17-2019, 10:43 PM
(11-17-2019 05:13 AM)teenix Wrote: [ -> ]Hi all,
Happy today :-)
cheers
Tony
Great, looks like your plan has worked! Did you try the decimal points?
11-17-2019, 10:53 PM
(11-17-2019 10:43 PM)Harald Wrote: [ -> ]Great, looks like your plan has worked! Did you try the decimal points?
Yes, all good.
I had the test LED across a cathode driver output and it flashed quite bright at first switch on. After a few hours of playing around I figured out the problem and it doesn't light at all now except for a faint glow which looks like normal operation.
cheers
Tony
11-18-2019, 04:18 AM
Hi all,
Quite a bit to go with CPU board but looking good so far:-)
cheers
Tony
cheers
Tony
11-18-2019, 07:12 AM
WOW, Just wow !!!
Congratulations !!!
Congratulations !!!
11-19-2019, 04:28 AM
Hi all,
The HP65 CPU board seems to be running ok.
The display, keyboard and PRGM/RUN switch are working and it will accept and run programs. The PC program connects to it and transfers information back and forth. The calculator menu is working and I can use it to load and save program cards plus set operating options from the keyboard.
Next is the CRC stuff for the card reader.
cheers
Tony
cheers
Tony
11-19-2019, 01:09 PM
(11-19-2019 04:28 AM)teenix Wrote: [ -> ]Hi all,
cheers
Tony
Great! You are making good progress! I'll dig out a 65 and prepare for a board
11-19-2019, 01:56 PM
Hi Tony,
both the HP-65 and HP-67 replacement boards are spectacular,
are these available for sale ?
take care Alberto
take care Alberto
11-19-2019, 02:12 PM
(11-19-2019 01:09 PM)Harald Wrote: [ -> ]Great! You are making good progress! I'll dig out a 65 and prepare for a board
Hopefully not too long :-)
cheers
Tony
11-19-2019, 02:24 PM
(11-19-2019 01:56 PM)albertofenini Wrote: [ -> ]Hi Tony,
take care Alberto
Hi Alberto,
Will be, but a bit to go yet. The 67 appears to work ok but a bug exists in the card read that I haven't sorted yet. If you consider the complexity of PIC machine code emulating HP microcode and the CRC chip while trying to capture data as the card whizzes through the reader... :-)
Anyway, maybe I'm looking at the problem but can't see it so I put it aside for a bit and I'll have a go at the 65 for awhile.
cheers
Tony
11-20-2019, 08:22 PM
Hi all,
Well it looks like the HP65 CPU board is behaving.
All functions work and it now reads and writes cards :-)
It also detects write protected cards which stops the write process and flags an error, but you can override this with a menu option and re-program those cards if required.
Just to test the Bluetooth now and it should be good.
cheers
Tony
cheers
Tony
11-20-2019, 09:27 PM
Very good !!!
Congratulations for the excellent result !!!
11-20-2019, 09:30 PM
Very well done!
Thank you Tony,
Thank you Tony,
11-20-2019, 11:02 PM
That's an amazingly good result after the pain the 67 caused...
Pauli
Pauli
11-20-2019, 11:06 PM
(11-20-2019 11:02 PM)Paul Dale Wrote: [ -> ]That's an amazingly good result after the pain the 67 caused...
Pauli
Yes, I thought the 67 would be easier, but not the case. Now that the 65 is ticking over, I'll get back to find that (hopefully last) elusive bug.
cheers
Tony
