12-20-2018, 02:29 PM
Original blog post: https://edspi31415.blogspot.com/2018/12/...nacci.html
This program is the request of John Cvetan. I thank you for your suggestion.
To generate the Fibonacci triangle,
1. Let r the row and c be the column with
f_0,0 = 1
f_1,0 = 1
f_1,1 = 1
f_2,1 = 1
2. Each row will be determined by adding the last two terms going diagonally. You can use one of two formulas:
f_r,c = f_r-1,c + f_r-2,c
f_r,c = f_r-1,c-1 + f_r-1,c-2
The Program FIBMAT
FIBMAT generates a Fibonacci triangle in matrix form. It's the result is a triangle that is "tilted". n will need to be 3 or greater.
The Program FIBTRI
This is a visual program for Fibonacci Triangle.
FIBTRI(n) generates a visual Fibonacci Triangle - although I don't recommend going beyond 12 rows due to the constraints of the screen. I used the small font for the rows.
HP Prime Program FIBTRI
Source:
Hosoya, Haruo. "Fibonacci Triangle" Ochanomizu University, Tokyo, Japan. 1976. https://www.fq.math.ca/Scanned/14-2/hosoya.pdf
f_0,0 = 1
f_1,0 = 1
f_1,1 = 1
f_2,1 = 1
The Program FIBMAT
EXPORT FIBMAT(n)
// Fibonacci "triangle" in
// matrix form
// 2018-12-17 EWS
LOCAL M1,k;
M1:=MAKEMAT(0,n+1,n+1);
M1(1,1):=1;
M1(2,1):=1;
M1(2,2):=1;
FOR k FROM 3 TO n+1 DO
M1(k):=row(M1,k-1)+row(M1,k-2);
M1(k,k):=M1(k-1,k-1)+M1(k-2,k-2);
RETURN M1;
The Program FIBTRI
EXPORT FIBTRI(n)
// Fibonacci triangle
// 2018-12-17 EWS
LOCAL M1,k;
M1(1,1):=1;
M1(2,1):=1;
M1(2,2):=1;
RECT();
LOCAL s;
FOR k FROM 1 TO n+1 DO
s:=STRING(SUB(row(M1,k),1,k));
IF k≤6 THEN
TEXTOUT_P(s,
140-5.5*(k-1),(k-1)*15,2);
IF k>6 AND k≤11 THEN
TEXTOUT_P(s,
140-8*(k-1),(k-1)*15,2);
IF k>11 THEN
TEXTOUT_P(s,
140-11.5*(k-1),(k-1)*15,2);
WAIT(0);
