04-29-2014, 07:54 AM
hello,
How would I use a user defined equation for fitting in the Statistics 2Var App? Say I have 3 points in the num view. Choosing between the predefined types in the symbolic view works fine, but when I change the equation the type changes to 'User Defined' as expected, but no fitting is done. I've tried Fit1: A*X^2+B as equation instead of the predefined quadratic type.
I noticed that changing the type requires a switch to plpot view to take effect and recalculate the fitting. Is that desired?
thanks
thanks
