12-03-2018, 11:48 PM
apologies if this is too obvious, but…
I've not done any statistics on my 50g before; I need to compare two small samples, and thought that it would be fun to try it.
I'm wanting to use the Student's t-test to compare the means of the two samples. I see hypothesis testing on the 50g, but it wants me to enter in the statistics already gathered from the samples, i.e. mean, sd & n for each sample.
On the Prime, it seems (from reading the manual) that a similar app (Inference) is able to import the sample data from the 1-var or 2-var apps.
Is this possible on the 50g? Or do I have to make a note of the calculated stats from each sample and then manually enter them into the hypothesis test app?
thank you…
thank you…
