(03-01-2015 04:24 AM)supernumero Wrote: [ -> ]Still, in the context of my original question, a wish for the ability to find complex eigenvalues and eigenvectors is not fulfilled.
Here's the adaption of the program from above that works with complex matrices:
001 - 42,21,15 LBL E
002 - 42,26,13 RESULT C
003 - 45 25 RCL I
004 - 1 1
005 - 42,23,13 DIM C
006 - 45,16,13 RCL MATRIX C
007 - 0 0
008 - 20 x
009 - 1 1
010 - 40 +
011 - 42,26,15 RESULT E
012 - 45,16,14 RCL MATRIX D
013 - 20 x
014 - 42,16, 4 MATRIX 4
015 - 45 25 RCL I
016 - 2 2
017 - 20 x
018 - 43 36 LSTx
019 - 40 +
020 - 45 25 RCL I
021 - 42,23,15 DIM E
022 - 45,16,15 RCL MATRIX E
023 - 42,16, 4 MATRIX 4
024 - 33 Rv
025 - 34 x<>y
026 - 2 2
027 - 30 -
028 - 42,23,15 DIM E
029 - 45,16,15 RCL MATRIX E
030 - 42 40 Py,x
031 - 42,16, 2 MATRIX 2
032 - 42,26,15 RESULT E
033 - 45,16,12 RCL MATRIX B
034 - 45,16,11 RCL MATRIX A
035 - 45,16,15 RCL MATRIX E
036 - 30 -
037 - 42,26,14 RESULT D
038 - 10 /
039 - 42,26,12 RESULT B
040 - 36 ENTER
041 - 42,16, 8 MATRIX 8
042 - 2 2
043 - 11 SQRT
044 - 10 /
045 - 10 /
046 - 42,26,15 RESULT E
047 - 45,16,11 RCL MATRIX A
048 - 45,16,12 RCL MATRIX B
049 - 20 x
050 - 42,26,14 RESULT D
051 - 42,16, 5 MATRIX 5
052 - 42,16, 3 MATRIX 3
053 - 43 40 Cy,x
054 - 43 32 RTN
The guess for the eigenvalue has to be stored in matrix
d 1 2. The guess for the eigenvector is expected in the matrix
b which must be in \(\tilde{Z}\) format. The same applies to matrix
A. And the dimension (i.e. 2) has to be stored in register
I.
The challenge was to figure out a means to calculate \(\lambda I\). For the transformation a mix of multiplication, transpositions and change of dimensions was used. As an example the case of 2 dimensions:
\begin{bmatrix}
1 \\
1 \\
\end{bmatrix}
\begin{bmatrix}
a & b
\end{bmatrix}
= \begin{bmatrix}
a & b \\
a & b \\
\end{bmatrix}
\rightarrow \begin{bmatrix}
a & a \\
b & b \\
\end{bmatrix}
a & a \\
b & b \\
0 & 0 \\
0 & 0 \\
0 & 0 \\
0 & 0 \\
\end{bmatrix}
a & b & 0 & 0 & 0 & 0 \\
\end{bmatrix}
a & b & 0 & 0 \\
0 & 0 & a & b
\end{bmatrix}
The other thing to consider is that the elements appear twice in the matrix. This has to be corrected when calculating the norm by dividing by \(\sqrt{2}\). Aside from this both programs are very similar.
This example was used as a test-case. After 5 iterations the result is exact to 4 places.
As a guess for the eigenvector I've used \(\begin{bmatrix}
1 + 0i \\
1 + 0i \\
\end{bmatrix}\) and \(1 + i\) as guess for the eigenvalue.
I haven't tried but I doubt that there's enough memory to handle the
3-dimensional case. The calculation should still be okay if somebody wants to test that with a
DM-15 with extended memory.
