11-17-2018, 09:27 PM
Hello friends,
like Eddie Shore showed us HERE an algorithm for integration a function with two variables with the simpson rule and a matrix. He implemented this for the HP 71B.
I do the same thing for the HP 50G but not so elegant, it is brute force:
I implementated this formular:
\[ F = \int_a^b\int_c^d f(t,s)dtds \\ \sim \frac{ha}{3} \left( \frac{hi}{3}\left(
f(a,c) + f(b,c) + \sum_{j=1}^{k-1}\left( 2f(t_j,c) + 4f(t_j,c)\right) +
f(a,d) + f(b,d) + \sum_{j=1}^{k-1}\left( 2f(t_j,d) + 4f(t_j,d)\right) + \\
\sum_{i=1}^{m-1}\left(2\left(f(a,s_i)+f(b,s_i) +
\sum_{j=1}^{k-1}\left( 2f(t_j,s_i) + 4f(t_j,s_i)\right)\right) + \\ 4\left(f(a,s_i)+f(b,s_i) +
\sum_{j=1}^{k-1}\left( 2f(t_j,s_i) + 4f(t_j,s_i)\right)\right)\right)\right)\right) \]
That looks horrible, but I used the stack to sum up all function values and multiplied them afterwards with 2 or 4. And the indices in formular above has to be disdinguish between even or odd numbers (only values with odd indices has to be multiplied be 4 and even with 2). I used in the FOR loops no integer values but the values for the variables (the hp 50g is very happy to use a real variable in the FOR loop.
For instance I used my little program for estimate antiderivatives with harmonic sphere function multiplied with a light function to geht the coeffecients.The one angle goes from 0 to pi, the other one from 0 to 2pi. With N = 15 the hp 50g has to calculate 30*60 = 180 function values and it takes 2 minutes at average. That seems to be very long, but it is faster as you take the built-in function \[ \int \]. I have the impression that the built in function works then (when you have more variables) with recursion.
%%HP: T(2)A(R)F(.);
« \-> UA OA UI OI N @@lower bound outer antiderivative
@@higher bound outer antiderivative
@@lower bound inner antiderivative
@@higher bound inner antiderivative
@@counts of partitial areas (N >= 2)
@@otherwise the formular here is wrong
@@in between the bounds (same for both)
« DUP 2. * \-> TU TO SI H H2 @@ inner loop defined as a subprogram
« TO SI FCSIM @@load the function with two variables
@@with two input (numeric) values, each for @@every variable
TU SI FCSIM @@same again
0. DUP @@reserve two stackplaces for summation
@@the function values
TU H + TO H2 - FOR K @@init the for-loop
K SI FCSIM + SWAP @@save the value in the one stack place
@@and sum it up with the former ones
K H + SI FCSIM + SWAP @@save the value in the other stack place
H2 STEP @@increment the loop variable K with the
@@double value
TO H - SI FCSIM + @@calulate the last value which is multi-
@@plied later on with 4
4. * SWAP 2. * + + + @@multiply the sum of values in their
@@stackplaces and sum it up
OI UI - N 2. * / DUP 2. * @@calculate the delta H for the inner loop
@@and the double value of that
OA UA - N 2. * / DUP 2. * @@calculate the delta H for the outer loop
\-> SFU HF HF2 HT HT2 @@local variables for the subprogram and the
@@delta values
« TICKS -2. SF -3. SF -105. SF @@ticks for time mesure (can be left out)
@@switch to numerical necessary for speed
UI OI UA HF SFU EVAL @@load the subprogram with the boundaries
@@of the inner antiderivative,
@@the value of outer antiderivative and the
@@delta h of the inner antiderivative
UI OI OA HF SFU EVAL @@same one line before
UA HT + OA HT2 - FOR I @@init the for-loop
UI OI I HF SFU EVAL + SWAP @@save the value in the one stack place
UI OI I HT + HF SFU EVAL + SWAP @@save the value in the other stackplace
HT2 STEP @@increment the loop variable K with the
@@double value
UI OI OA HT - HF SFU EVAL + @@calulate the last value which is
@@multiplied later on with 4
4. * SWAP 2. * + + + HF * HT * 9. / @@multiply the sum of values in
@@their stackplaces and
@@multiply it the delta h
@@for both antiderivatives
TICKS ROT - 8192. / @@can be left out only for time mesure
-2. CF -3. CF -105. CF @@switch back to symbolic mode
