11-02-2018, 02:36 PM
I'm not sure if this is a problem, but it seems like it.
Hopefully not everyone with a 41CL is unterwegs/enroute/in transit to Allschwil right now :-)
I recently did a FLASH update of my v5 41CL to the 180928 ROM level, the latest as of this writing. Everything seemed to work fine, but there are a few oddities I'm not sure are right. It's possible I may have had some of them before, but hadn't spotted them because I put off a really "deep dive" on everything until I did this update to the latest FLASH.
I'll meter my issues out in separate postings to keep things simple(r) and not overwhelm folks.
Problem: With OSX3 installed, if I run CAT 2, I see "8HY" in place of anything that relates to AMC or OSX as the catalog listing rolls by. If I "R/S" at 8HY and hit ENTER, all kinds of encoded characters do a dance and control of the machine seems unrecoverable (even with ON ← reset) unless I take the batteries out for a minute or so.
Investigation Steps
1. I originally noticed this peculiarity with OSX3 on my "main" configuration that employed Library#4, OSX3, YFNX, PWRX, and WARP. Deciding that was a bunch of "power stuff" all in at once, it might be better to isolate things a bit and I reduced to the following more-minimized setup. Everything I am using is from 180928 ROM level.
Page 4: Library#4 R46
Page 7: OSX3
Page 8: YNFZ
Even under this minimal setup, I see the "8HY" issue.
2. Following that, I swapped in YNFX in place of YNFZ just in order to get access to command YCRC (I still see "8HY" on CAT2 with YNFX). I then used YCRC to confirm the CRC checksums for each of the following in FLASH, comparing against the 28 Sep 18 version of mem_ref.pdf on the 41CL site. (This step just verifies that my recent FLASH update didn't install a corrupted version of any of the ROMs in use. All checked OK.
0x120 4LIB -- CRC OK
0x168 OSXB1 -- CRC OK
0x169 OSXB2 -- CRC OK
0x16A OSXB3 -- CRC OK
0x16B OSXB4 -- CRC OK
0x007 YNFZ-4F -- CRC OK
0x00A YNFX-3A -- CRC OK
So everything looks fine.
What's going on here?
•Is seeing "8HY" in CAT2 just "normal"? I don't remember that being the case in the past. My as-delivered prior FLASH dated to May 18.
•Or is there a bug in OSX3 or the new Library 4?
Any thoughts are appreciated.
Investigation Steps
Page 7: OSX3
Page 8: YNFZ
