10-28-2018, 03:16 PM
I have a question and a request.
I would like to add graphic elements in the drawing area of an application based on the "function" application (lines, circles respecting the scale of the drawing).
Here is a basic example to illustrate:
You must first add two functions in the symbolic view or download the sample in app format...
With this method I can add graphic elements (here a simple circle of radius 1 unit) but unfortunately if I move the graph or if I zoom (with touch screen capabilities) , the added elements are destroyed ... How to make them persistent so that it moves with the function curves plotted ?
And now a request to HP team:
Often I want (as in this basic example) to use the plot key to allow a choice between different types of plots. I then reserve the function "view" for other tasks (often those provided by default: "autoscale", etc.)
Unfortunately currently, the code contained in the block "Plot () BEGIN END" is not executed when I press the "Plot" key when the graphic view is already active ... I have to leave the graphic view so that the "Plot" key is operational. Could not we imagine a change in this behavior so that the press on the keys "Plot" "Num" etc. is taken into account even if the corresponding view is already active?
Thank you for the time you have spent reading me.
#pragma mode( separator(.,;) integer(h32) )
Plot()
CHOOSE(A,"Choose a graph","sincard","cos");
CASE
IF A==1 THEN CHECK(1);UNCHECK(2) END;
IF A==2 THEN CHECK(2);UNCHECK(1) END;
STARTVIEW(1,1);
VIEW "Circle", circle()
LOCAL r;
r:=Ymax-Ymin;
r:=218/r;
ARC(G0,0,0,r);
//WAIT();
VIEW "Auto scale", auto()
STARTVIEW(10);
