04-25-2014, 11:32 AM
You probably know already that the 41CL has 2MB of flash and 512kB of RAM capacity. Perhaps the most intriguing aspect of that additional RAM memory would be to make it somehow available to the OS; exceeding the built-in limits of the original design...
No doubt that would require patching the OS extensively, probably too much for a reasonable undertaking and a lot of effort to say the least.
But a lower-hanging fruit could be extending the Extended Memory capacity, definitely more tractable than the main memory space. With that idea in mind I've been fumbling with the X-Mem control and linking registers, trying to add additional EM-blocks to the "chain"; and exploring alternate EM configurations in RAM locations above 0x400.
So far the obvious tricks haven't been fruitfull, it appears there too patching the OS code would be required to get it to work. But using a bit of lateral thinking it's easy to come up with easy ways to back up all your X-memory, or even to have an alternative (dual) set of X-Mem configured, so you can switch back and forth between them.
Below is the quick and dirty FOCAL program to hot-swap the standard X-Memory configuration with another one located in the higher memory locations, above 0x400. It keeps the same structure (one base block of 128 registers plus two additional ones of 239 each), at equivalent addresses to maintain the parity. This maintains the compatibility for main-RAM back-ups as well, assuming of course that the switching routine would be running from ROM.
Interestingly it only uses PEEKR and POKER as non-standard functions, available in the CCD Module and a few of its derivatives.
Take it for a spin and report issues or ideas for enhancement, let's see where can this be taken to...
Cheers,
ÁM
PS. Slightly improved code updated
1 LBL "XMSWAP"
2 "BASE" provide feedback
3 AVIEW
4 128 number of base registers
5 STO M store counter in M
6 64 origin
7 XEQ 00 swap block
8 "EM-1" provide feedback
9 AVIEW
10 239 number of base registers
11 STO M store counter in M
12 513 origin
13 XEQ 00 swap block
14 "EM-2" provide feedback
15 AVIEW
16 239 number of base registers
17 STO M store counter in M
18 769 origin
19 LBL 00 swap block
20 CF 00
21 RCL X origin
22 1024 offset address
23 + destination
24 LBL 01
25 PEEKR read destination value
26 X<> Z
27 PEEKR read source value
28 R^ lift for compare
29 X=Y? are they equal?
30 SF 00 flag it so
31 RDN undo lift
32 FS?C 00 equal values?
33 GTO 02 yes, skip writing
34 X<> T position them crossed
35 POKER write them back
36 RDN
37 X<> Z position them crossed
38 POKER write them back
39 LBL 02 merge code
40 RDN locate addreses in X, Y
41 E
42 ST+ Z increase adr-1
43 + increase adr-2
44 DSE M decrease counter
45 GTO 01 loop back if not done
46 "DONE" block is done
47 AVIEW
48 END
Cheers,
ÁM
