10-26-2018, 11:47 AM
Program to generate in endless loop of
Two Parallel Resistors with your desire total.
This program give different pair of resistors that match the giving total.
Procedure:
[A] // Total [ENTER] Step [A]
[B] // Press any key to Stop Loop [B] 1st Resistor [R/S] 2nd Resistor [R/S] continue forward loop.
[C] // [C] Backward loop, Press any key to Stop Loop [B] 1st Resistor [R/S] 2nd Resistor.
[E] Initialize
Example: FIX 3
Destination total is 25.75
Pick two difference pair of resistors of your choice.
I will use 0.5 for loop steps.
[E] Initialize
25.75 ENTER .5
[A] ---->Program keep generate two resistors that match your giving total in this case is 25.75
Once you see the pair you like press any key to stop I recommend ENTER key.
[B] I pick this pair: 30.25 [R/S] 173.097 [R/S] --> Continue Loop Forward
[C] This loop go backward: Once you see the pair you like press any key to stop.
I pick this pair: --> [B] 28.250 [R/S] 290.975
Program:
Gamo
Procedure:
[E] Initialize
Example: FIX 3
[E] Initialize
25.75 ENTER .5
Program:
LBL A
STO 1
Rv
STO 0
RCL 0
LBL 5
RCL 1
LBL 1
STO 2
PSE
RCL 0
x
RCL 2
RCL 0
STO 3
PSE
PSE
LBL 3
RCL 4
X≠0
GTO 4
RCL 2
GTO 5
LBL B
RCL 2
R/S
RCL 3
R/S
GTO 3
LBL C
1
STO 4
LBL 4
RCL 2
RCL 1
GTO 1
LBL E
CLx
STO 1
STO 2
STO 3
STO 4
RTN
Gamo
