How do I enter system of eqs using program, ex. PROG(sys_eqs,vars). I try variable as strings with/without curly/square brackets and nothing works. What I do wrong? Strings as arguments to programs used to work with CAS(),EXPR(). Does that changed in the latest beta? I use the latest beta firmware. In the PRGM in CAS I use solve or fsolve.
Perhaps it is more convenient to work directly with objects.
For instance:
#cas
SZ_T1(eq_list)
begin
local n:= size(eq_list);
local i, eq;
print ("");
print ("There is " + n + " objects");
for i from 1 to n do
eq:= eq_list[i];
print (i + ": " + eq);
end;
end;
#end
#cas
SZ_T2(eq_list, var_list)
begin
local i, eq;
print ("");
eq:= eq_list[i];
end;
print(" ");
print("Var list: ")
print(var_list);
print(" ");
print("Solution: ");
print(solve(eq_list,var_list));
end;
#end
Examples:
SZ_T1( (2*x+3*y)=1, (x+y) = 2 )
SZ_T2([(2*x+3*y) = 1,(x+y) = 2],[x,y])
