10-21-2018, 09:57 PM
The Casio fx-CG 50 joins the HP Prime and Numworks to have Python programming. See the OS Update Information section: https://edu.casio.com/products/graphic/fxcg50/
(10-21-2018 09:57 PM)Eddie W. Shore Wrote: [ -> ]The Casio fx-CG 50 joins the HP Prime and Numworks to have Python programming. See the OS Update Information section: https://edu.casio.com/products/graphic/fxcg50/
(10-23-2018 11:53 AM)tcab Wrote: [ -> ]Great news. I’d probably buy the calculator except I don’t want to pay for a yearly fx-CG Manager PLUS Subscription in order to transfer Python files.
(10-23-2018 02:21 PM)ijabbott Wrote: [ -> ]You can connect it as a USB mass storage device to transfer files. (Actually, it might be MTP or PTP mode - I can't remember!)
(10-24-2018 08:07 AM)tcab Wrote: [ -> ]Also, can anybody compare this calc to our venerable mighty Prime? I can predict the Prime will be way faster, but in terms of design and UI I'd be interested in a quick opinion from someone who owns both.
means.py:
import math
print("Enter -9999")
print("to terminate.")
# initialization
x=float(input("Data: "))
n=0
sx=0
ss=0
ps=1
# Enter data
while x!=-9999:
n=n+1
sx=sx+x
ss=ss+x**2
sr=sr+x**-1
ps=ps*x
print(" n = ", str(n))
# calculations
print("Means")
print("Arithmetic ",str(sx/n))
print("Geometric ", str(math.pow(ps,1/n)))
print("Harmonic ", str(n/sr))
print("RMS ", str(math.sqrt(ss/n)))
(10-25-2018 01:05 PM)Eddie W. Shore Wrote: [ -> ](10-23-2018 11:53 AM)tcab Wrote: [ -> ]Great news. I’d probably buy the calculator except I don’t want to pay for a yearly fx-CG Manager PLUS Subscription in order to transfer Python files.
A subscription is not required to transfer files from a fx-CG 50 files to a computer. All that is needed is the USB cord that comes with the calculator. When you connect fx-CG 50 to the computer, the calculator will offer connection choices. Select USB and the calculator acts like a USB drive.
(10-25-2018 01:35 PM)StephenG1CMZ Wrote: [ -> ]Thats good to know, as the Casio software seems unavailable in the uk (tapping on Purchase Now/Click Pay does nothing)...and if it did, its listed under a "classroom" subdirectory, so might not be available to adults...I was actually hoping to discover the cost, but without graphics probably wouldn't buy.
https://edu.casio.com/products/classroom/fxcgm_plus/
I'm hoping that when you say you need the cable with the calculator, a standard usb cable will work - not something else.
(01-11-2020 05:59 PM)Eddie W. Shore Wrote: [ -> ]The Python I have on Casio fx-CG 50 is pretty limited: Basic commands and a simplified Math library.
(01-11-2020 08:50 PM)Csaba Tizedes Wrote: [ -> ](01-11-2020 05:59 PM)Eddie W. Shore Wrote: [ -> ]The Python I have on Casio fx-CG 50 is pretty limited: Basic commands and a simplified Math library.
And if you compare it to the TI's Python which seems better? TI Python Manual and a Middle school booklet for Python applications.
Csaba
