Command Line: laplace(2*t*e^(-3*t)+5,t,s); // purge(t,s,x) first....
Displayed result: (5*s^2+32*s+45) / (s^3+6*s^2+9*s)
How to display result in this form? (2/(s+3)^2) + 5/s
convert((5s^2+32s+45) / (s^3+6s^2+9s), parfrac) ==> 5/s + 2/(s+3)^2
partfrac((5s^2+32s+45) / (s^3+6s^2+9s)) ==> 5/s + 2/(s+3)^2
Edit: tried to break up fraction, say 11/30 to 1/2 - 1/3 + 1/5, but unsuccessful...
(10-20-2018 12:33 PM)Albert Chan Wrote: [ -> ]convert((5s^2+32s+45) / (s^3+6s^2+9s), parfrac) ==> 5/s + 2/(s+3)^2
Thank you for the help on that!
1. normalized laplace expressions
partfrac() is a great way to normalize the output from Laplace for many (but not all) conversions. Maybe we should add parameter to laplace() to tell laplace() that we want the result in the normalized form..., i.e. laplace(expression of parameter 1, [param 1 (i.e. t)], [param 2 (i.e. s)], [normalized flag]) where the normalized flag is either 1 or 0 for yes and no, with default = 1 for yes.
In the normalized form we want a sum of terms, where each term is a function of s that corresponds 1:1 to each term in the original expression (where each term was a function of t)
Example of common terms (of t and the corresponding terms of s):
unit step : 1 <-> 1/s
ramp: t <-> 1/s^2
sine: sin(a*t) <-> a/(s^2 +a^2)
see more attached
2. Found some issues with laplace and ilaplace/invlaplace
I played around with laplace() and ilaplace() and noticed that they no longer behave like the used to
ilaplace((1/(x^2+1)^2)) (or invlaplace() which is and works the same ilapalce())
results in:
1/4*(-x*e^(i*x)-x*e^(−i*x)−i*e^(i*x)+i*e^(−i*x))
which is correct (if you apply Euler) but it is no longer presented in the usual recognizable formal (like it used to do and indeed the help menu shows it should/did):
1/2*sin(x)-1/2*x*cos(x)
I realize that I had "i" checked in CAS settings and if I uncheck that I get the expected result: 1/2*sin(x)-1/2*x*cos(x).
Is this the way this should work - the transformation being dependent of "i" being checked or not?
I was using a "physical " prime
version is 2.0.0.13865 from 2018 07 06
Hardware version C
Also, the virtual Prime does not behave the same way as the "physical" Prime.
The virtual Prime does not like when you use the familiar parameters s and t but prefers x.
results in
"laplace(2*t*e^(-3*t)+5,t,s) Error: Bad Argument Value"
but:
laplace(2*x*e^(-3*x)+5,x,s)
works fine
(5*s^2+32*s+45)/(s^3+6*s^2+9*s)
The Virtual Prime have the same version and date (version is 2.0.0.13865 from 2018 07 06) as the "real" Prime.
Playing a bit more on the virtual Prime, the same issue appears symmetrically (as far as i tried) with ztrans() and invztrans().
invztrans(z/(z^4-1),z,n)
"invztrans(z/(z^4-1),z,n)
etc
Anders: the way to do the computation of Laplace transform depends on the complex setting, since the first step for ilaplace is factorization.
Run purge(t,s).
(10-24-2018 05:27 AM)parisse Wrote: [ -> ]Anders: the way to do the computation of Laplace transform depends on the complex setting, since the first step for ilaplace is factorization.
Run purge(t,s).
I did purge(s), purge(t), purge(x) before when I got above results (virtual and physical Prime. Should have written that. I trred today again and got the same results.
so I found that whether "complex" is checked or not does NOT matter for the output form, but if "i" is set does. I should have included that above as well. I tried today again and got the same results.
Also, it does not explain the difference between virtual and physical prime.
(10-24-2018 02:18 AM)Anders Wrote: [ -> ]1. normalized laplace expressions
ramp: t <-> 1/s^2
see more attached
results in:
Hardware version C
results in
but:
works fine
Running simplify( exp2trig( ilaplace(1/(x^2+1)^2))) works for me.
You can create a program to run simplify( exp2trig( ilaplace( ))).
(10-25-2018 02:01 AM)rushfan Wrote: [ -> ] (10-24-2018 02:18 AM)Anders Wrote: [ -> ]1. normalized laplace expressions
ramp: t <-> 1/s^2
see more attached
results in:
Hardware version C
results in
but:
works fine
Thanks. I get that, but that was not really my point (there were many). To know that you need to apply exp2trig you need to know the answer (which you typically do not until; you have tried ilaplace() first).
My view was that the average EE (or any engineering doing differential equations) undergrad student pov would not immediately know this when they see a bunch of e ^ -ix....., but that a student would reasonably expect the ilaplace() to present the familiar mapping back to the time domain.
You now, like the classic laplace tables the professor gives the students at the beginning a circuit class. Just look at Wikipedia for instance
Laplace transform
same goes for z transforms dealing with the discrete time domain:
Z-transforms
Hugely important also in comp sci.
What that student need to know is that "i" should not be checked in CAS setting for the mapping to work as expected.
In some ways it is actually good that ilaplace can present both the complex form and the non-complex. It makes it more flexible if you want to do more advance stuff but, maybe by default, ilaplace() should always show the non-complex form (regardless of "i" CAS setting) and have a parameter complex on/off to explicitly tell CAS to show complex form. ilaplace(expression of parameter 1, [param 1 (i.e. t)], [param 2 (i.e. s)], [normalized flag Y/N: default Y], [complex Y/N: default N])
Just a thought. I think HP/Parisse, would get fewer questions and the students would better intuitive and immediate use of the HP Prime.
I would certainly have loved to have had and HP Prime with that capability in grad school. It would save so much time and avoid errors in the mapping back and forth the between time and frequency domain of complex circuits analysis.
Anyway, the other errors I mentioned above is still a problem.
(10-25-2018 02:56 AM)Anders Wrote: [ -> ] (10-25-2018 02:01 AM)rushfan Wrote: [ -> ]Running simplify( exp2trig( ilaplace(1/(x^2+1)^2))) works for me.
You now, like the classic laplace tables the professor gives the students at the beginning a circuit class. Just look at Wikipedia for instance Laplace transform
Z-transforms
Having the answers displayed in complex exponential form is essential in a signals and systems course, on an EET (Electronics Engineering) graduation. I learned how to do the transforms by hand in that course before being asked to do them "by table". And in this case, the default settings present the familiar answer (in terms of the functions) as it should, so not an issue IMHO.
And yes, there are a ton of not intuitive and not sufficiently detailed and exemplified things in the cas documentation. Recently, it took me a forum post to figure out that the function "normal()" exists and does what I needed.
(10-25-2018 04:17 AM)rushfan Wrote: [ -> ] (10-25-2018 02:56 AM)Anders Wrote: [ -> ]Thanks. I get that, but that was not really my point (there were many). To know that you need to apply exp2trig you need to know the answer (which you typically do not until; you have tried ilaplace() first).
Z-transforms
Yes, so I think we agree then.... CAS Documentation remains a challenge.
As there are several typs of uses where you absolutely want the complex exponential form (e.g. fundamental to the detail components R,C,L in circuits) and looking at the systems level (time discrete/ continuous systems and control theory) it is beneficial to work in the z and s standard form. Also, it is also beneficial to manipulate and transform entire systems (formulated in s and z) in vector and matrix form back and forth...
Both "complex" and s,z form as well as normalized/default form are needed as output AND need to be documented.
Ideally the laplace() and ilapalce() (as well as ztrans and invztans) needs to have parameters allowing the user to specify what output form he/she wants rather than changing a CAS system setting.
This would allow the user to move between the time domain and frequency domain using different forms efficiently without going in and changing CAS settings back and forth.
However, the issues with the virtual Prime is still a problem. At least it does not work for me even with purge(s,x,t)...
