Full Version: (11C) Finding biggest of 3 integers
Program to find the biggest number of 3 integers.
Procedure: f [USER]
n1 [ENTER] n2 [ENTER] n3 [E]
Example:
1, 3 and 2
1 [ENTER] 3 [ENTER] 2 [E] display 3
Biggest number is 3
14, 10 and 8
14 [ENTER] 10 [ENTER] 8 [E] display 14
-4, -3 and -6
4 [CHS] [ENTER] 3 [CHS] [ENTER] 6 [CHS] [E] display -3
FIX 4
0.9987, 0.9990 and 0.9989
,9987 [ENTER] ,9990 [ENTER] ,9989 [E] display 0.9990
Program: Finding biggest of 3 integers
LBL E
STO 1
Rv
STO 2
Rv
STO3
RCL 2
RCL 1
X>Y
GTO 2
RCL 3
RCL 2
X>Y
GTO 1
RCL 3
RTN
LBL 1
RCL 2
RTN
LBL 2
RCL 3
RCL 1
X>Y
GTO 3
RCL 3
RTN
LBL 3
RCL 1
RTN
Gamo
(10-20-2018 05:41 AM)Gamo Wrote: [ -> ]Program to find the biggest number of 3 integers.
Of any three numbers, not only integers.
Gamo, do you remember the following sequence?
With two numbers in X and Y, X≤Y? X<>Y checks if X is the smaller of the two. If it is, both are swapped.
So this sequence always returns the larger number in X and the smaller one in Y.
Likewise, X>Y? X<>Y returns the smaller number in X and the larger one in Y.
Now assume there are three different numbers in X, Y and Z.
X>Y? X<>Y will put the larger one in Y and the smaller one in X.
Roll down the stack one level to compare this larger number with the third one.
X≤Y? X<>Y will put the largest of all three in X.
So the program simply is:
01 LBL A
02 X>Y?
03 X<>Y
04 R↓
05 X≤Y?
06 X<>Y
07 RTN
Or on the 12C and others without an X>Y? test:
01 X≤Y?
02 X<>Y
03 X<>Y
04 R↓
05 X≤Y?
06 X<>Y
07 GTO 00
You can easily extend this example. This is what we get:
Return the largest of two numbers:
01 LBL A
02 X≤Y?
03 X<>Y
04 RTN
Return the largest of three numbers:
01 LBL A
02 X>Y?
03 X<>Y
04 R↓
05 X≤Y?
06 X<>Y
07 RTN
Return the largest of four number:
01 LBL A
02 X>Y?
03 X<>Y
04 R↓
05 X>Y?
06 X<>Y
07 R↓
08 X≤Y?
09 X<>Y
10 RTN
Dieter
Thanks Dieter
Didn't think about that before now your version is very interesting.
Gamo
