It was interesting to read the evolution of this routine in your 2010 thread (see Gerson's link below in post #3).
Jeff K
- edited to address an invalid link
(05-25-2014 03:30 PM)Jeff_Kearns Wrote: [ -> ]It was interesting to read the evolution of this routine in your 2010 thread here.
Jeff,
That's a Google Drive link and I cannot follow it. I think you mean this old forum thread:
Short Quadratic Solver (HP-42S)
The influence and inspiration that led me to this even shorter version are described in this thread from 2012:
Fast Quadratic Formula for the HP-41C
Thank you for your interest!
Gerson.
(05-25-2014 09:55 PM)Gerson W. Barbosa Wrote: [ -> ]Thank you for your interest!
Gerson,
I am interested! The following routine for the HP-32sii and HP-33s (slightly modified from Eddie Shore's original to display the roots as x + iy) is the one I use but it is 39 steps long!
Q0001 LBL Q ' Set label Q
Q0002 INPUT A
Q0003 INPUT B
Q0004 INPUT C
Q0005 SQ(B)-4xAxC ' Equation (enter by RS [right shift] EQN)
Q0006 STO D
Q0007 RCL D ' Is the discriminant negative?
Q0008 x<0?
Q0009 SF 1 ' Flag 1 - indicate that the roots are complex
Q0010 RCL D
Q0011 FS? 1
Q0012 +/- ' The HP 33 cannot take square roots of x<0
Q0013 square root
Q0014 STO E ' E = abs(sqrt(D))
Q0015 -B/(2xA) ' enter this as an equation
Q0016 STO F
Q0017 E/(2xA) ' enter this an an equation
Q0018 STO G
Q0019 RCL G
Q0020 0
Q0021 FS? 1
Q0022 x<>y
Q0023 RCL F
Q0024 0
Q0025 CMPLX+
Q0026 x<>y
Q0027 STOP ' press the R/S key: display first root
Q0028 RCL G
Q0029 +/-
Q0030 0
Q0031 FS? 1
Q0032 x<>y
Q0033 RCL F
Q0034 0
Q0035 CMPLX+
Q0036 x<>y
Q0037 STOP
Q0038 CF 1 ' clean up command
Q0039 RTN
Can you think of a way of dramatically shortening it, in line with your 15-liner for the HP-42s, so that it still gives real and complex roots? The memory in the HP-32Sii is so limited and shortening this program might allow me to squeeze one more program in there...
Thanks,
Jeff K
(05-27-2014 05:30 PM)Jeff_Kearns Wrote: [ -> ]Can you think of a way of dramatically shortening it, (...) so that it still gives real and complex roots?
Copied most of it from here:
Short quadratic solver (HP-15C)
Q01 LBL Q
Q02 ENTER
Q03 R^
Q04 /
Q05 R^
Q06 LASTx
Q07 /
Q08 2
Q09 +/-
Q10 /
Q11 ENTER
Q12 ENTER
Q13 x^2
Q14 R^
Q15 -
Q16 SQRT
Q17 ENTER
Q18 +/-
Q19 CMPLX-
Q20 RTN
Doesn't give you the complex solution but that should be easy to add. There are probably shorter solutions possible by using a register.
(05-27-2014 06:57 PM)Thomas Klemm Wrote: [ -> ] (05-27-2014 05:30 PM)Jeff_Kearns Wrote: [ -> ]Can you think of a way of dramatically shortening it, (...) so that it still gives real and complex roots?
Copied most of it from here: Short quadratic solver (HP-15C)
Q01 LBL Q
Q02 ENTER
Q03 R^
Q04 /
Q05 R^
Q06 LASTx
Q07 /
Q08 2
Q09 +/-
Q10 /
Q11 ENTER
Q12 ENTER
Q13 x^2
Q14 R^
Q15 -
Q16 SQRT
Q17 ENTER
Q18 +/-
Q19 CMPLX-
Q20 RTN
Nice use of CMPLX- for saving a step or two!
This might do while we don't think of something better:
Q01 LBL Q
Q02 CF 1
Q03 ENTER
Q04 R^
Q05 /
Q06 R^
Q07 LASTx
Q08 /
Q09 -2
Q10 /
Q11 ENTER
Q12 ENTER
Q13 x^2
Q14 R^
Q15 -
Q16 x<0?
Q17 SF 1
Q18 ABS
Q19 SQRT
Q20 FS? 1
Q21 RTN
Q22 ENTER
Q23 +/-
Q24 CMPLX-
Q25 RTN
If the roots are complex, the flag 1 announciator will be lit and the real and complex parts will be in registers Y and X, respectively.
Cheers,
Gerson[/code]
(05-28-2014 04:18 AM)Gerson W. Barbosa Wrote: [ -> ]If the roots are complex, the flag 1 annunciator will be lit and the real and complex parts will be in registers Y and X, respectively.
Cheers,
Gerson
Gerson -
The code (without INPUT prompts) works OK for real roots but not for complex roots (IMHO)...
I prefer to see the results (if complex) displayed as x + iy, as per the 39 step routine based on Eddie Shore's program to which I added a couple of x<>y statements to display 'correctly'. There are two issues with this particular routine that I can't quite figure out:
1) even when I insert a x<>y before the final RTN, I still get the imaginary part in x, i.e. ix + y. With or without a x<>y before the final RTN, the displayed result is the same.
2) Only one complex root is solved correctly. As an example, if you try solving 5x² + 2x + 1 = 0, you get the following: Flag 1 is set with the imaginary part 0.4 in x, and the real part -0.2 in y. Upon R/S the second root (x = -0.2 - 0.4i) is not shown. Granted, all complex roots are of the form x = D ± Ei, so one can deduce the second root and it doesn't really matter I guess BUT...
Can you suggest a better solution?
Jeff K
(05-28-2014 10:17 PM)Jeff_Kearns Wrote: [ -> ] (05-28-2014 04:18 AM)Gerson W. Barbosa Wrote: [ -> ]If the roots are complex, the flag 1 annunciator will be lit and the real and complex parts will be in registers Y and X, respectively.
Cheers,
Gerson
Gerson -
Jeff K
Jeff,
I hope this is better, although not so short anymore:
Q01 LBL Q
Q02 CF 1
Q03 ENTER
Q04 R↑
Q05 ÷
Q06 R↑
Q07 LASTx
Q08 ÷
Q09 ⁻2
Q10 ÷
Q11 ENTER
Q12 ENTER
Q13 x²
Q14 R↑
Q15 -
Q16 x<0?
Q17 SF 1
Q18 ABS
Q19 SQRT
Q20 ENTER
Q21 +/-
Q22 CMPLX+
Q23 FS? 1
Q24 CMPLX-
Q25 FS? 1
Q26 R↑
Q27 RTN
CK=3BA1 LEN 048.5 (HP-32SII)
Usage examples on the HP-32SII
1 ENTER 5 +/- ENTER 6 XEQ Q --> 2 x<>y --> 3 (Two real roots, because the flag 1 annunciator is off)
1 ENTER 1 +/- ENTER 1 XEQ Q --> 0.5 x<>y 8.66025404E-1
R↓ 0.5 x<>y -0.86602540378 (Two complex roots, 0.5 ± (√3)÷2 i, because the flag 1 annunciator is on)
Alternatively, you can use a slightly modified version of Eddie Shore's program to save a few steps:
Q0001 LBL Q
Q0002 CF 1
Q0003 INPUT A
Q0004 INPUT B
Q0005 INPUT C
Q0006 SQ(B)-4×A×C
Q0007 x<0?
Q0008 SF 1
Q0009 ABS
Q0010 √x
Q0011 STO E
Q0012 -B÷2÷A
Q0013 STO F
Q0014 E÷2÷A
Q0015 STO G
Q0016 0
Q0017 FS? 1
Q0018 x<>y
Q0019 RCL F
Q0020 0
Q0021 CMPLX+
Q0022 x<>y
Q0023 STOP
Q0024 RCL G
Q0025 +/-
Q0026 0
Q0027 FS? 1
Q0028 x<>y
Q0029 RCL F
Q0030 0
Q0031 CMPLX+
Q0032 x<>y
Q0033 RTN
CK=545E
LN=169 (hp 33s)
Gerson.
P.S.: Regarding issue #1, that happens because the first RTN instruction (step Q21), not the last, is executed when flag 1 is set.
(05-29-2014 04:23 AM)Gerson W. Barbosa Wrote: [ -> ]
You can remove this step as
D is never used.
(05-29-2014 05:10 AM)Thomas Klemm Wrote: [ -> ] (05-29-2014 04:23 AM)Gerson W. Barbosa Wrote: [ -> ]
You can remove this step as D is never used.
Duely removed above. Thank you very much!
Gerson.
(05-29-2014 03:48 PM)Gerson W. Barbosa Wrote: [ -> ]Thank you very much!
Gerson.
And I thank you both! --- Jeff K
(05-30-2014 03:56 AM)Jeff_Kearns Wrote: [ -> ] (05-29-2014 03:48 PM)Gerson W. Barbosa Wrote: [ -> ]Thank you very much!
Gerson.
You're most welcome!
BTW, the HP-42S code (post #1) has been shortened to 14 steps and 25 bytes, including LBL and END. Perhaps a new world record for the HP-42S :-) (Not being the most accurate, at least that might be the shortest one ever - well, until someone manages to save yet another step or byte)
Gerson.
