(10-14-2018 09:44 PM)akmon Wrote: [ -> ] (10-13-2018 08:50 AM)CyberAngel Wrote: [ -> ]Time the Inversion ONLY (leave the display out):
#cas
InvMat1(n):=
LOCAL t,Mat1;
Mat1:=randMat(n,n)*0.1;
MSGBOX(Mat1); // debugging
t:=TICKS; Mat1:=Mat1^-1;
RETURN (TICKS-t)/1000.+"_s";
#end
Usage: InvMat1(50) [ Enter ]
see the random matrix, for the inverse timing press again [ Enter ]
or tap | OK |
Press directly again [ Enter ] tap | OK |
and one more time and the fourth time to get the average
Now increase to 100 and do it 4 times, too by pressing the [ Enter ]
Try four times 200
Does anyone have also the G2?
These are my results:
G2:
Invmat1(50) average: 0,0135s
Invmat1(100) average: 0,0795s
Invmat1(200) average: impossible to test. Calculator crashed, only restart with a clip. reported to calcbeta
G1:
Invmat1(50) average: 0,1665s
Invmat1(100) average: 1,113s
Invmat1(200) average: it shows a strange error message but it can continue doing the calculus: 8,472s.
With eight times the RAM
and perhaps a eight times the MatInv speed
it's a shame that the G2 crashes.
Can anyone try on their phone up to 800, please.
On Android it can reach up to 141 before crashing.
(10-15-2018 05:52 AM)parisse Wrote: [ -> ] (10-14-2018 09:00 PM)akmon Wrote: [ -> ]I´ve just executed the python mendelbrot program, in G2 version, chronograph on hand.
So taking the time in the video, these are the results:
Prime G1: 140 seconds
Numworks: 85 seconds
Prime G2: 57 seconds
Try this one:
#cas
def fra1(X,Y,Nmax):
w=2.7/X
h=-1.87/Y
Y=Y-1
for y in range(ceiling(Y/2)+1):
c = -2.1+i*(h*y+0.935)
for x in range(X):
z = 0
for j in range(Nmax):
if abs(z=z**2+c)>2:
break
PIXON_P(x,y,5100*j+512)
PIXON_P(x,Y-y,5100*j+512)
c = c+w;
FREEZE
#end
fra1(320,220,10)[/code]
G1: 66 s
G2: 16 s
Numworks: ?
With this code, the program is quite faster, on both models.
(10-15-2018 02:01 PM)StephenG1CMZ Wrote: [ -> ]On Android it can reach up to 141 before crashing.
On physical calculators
G1
InvMat1(800): makes a warmstart after 25 secs.
G2
InvMat1(800): crashes
About the example above:
In G1
InvMat1(141): average: 2,988s
In G2:
InvMat1(141): average: 0,21s
In G1
InvMat1(142): after a strange error message, average: 3,083s
In G2:
InvMat1(142): crashes
So it confirms that the crashes happens with n>141
hope this data will help to HP team.
If any size greater than 141 causes a crash, there must be a limit of 20000 elements somewhere, since 141 is IP(SQRT(20000)).
Also an 800 x 800 matrix requires 64 times as much memory as a 100 x 100 matrix, not 8 times. I doubt that any hand-held device could invert an 800 x 800 matrix but I'm prepared to be pleasantly surprised.
(10-15-2018 09:32 PM)akmon Wrote: [ -> ]In G1
I know the inverse were not displayed, but is it any good ?
I think it is better for a benchmark do double duty, timing and verifying.
Instead of display nothing (but timing), we could add this to InvMat1:
err := Mat1 - inv(inv(Mat1)) ;
print(dot(err, err)); // dot product, so just 1 (hopefully small) number
You can do that for matrix inverses (no display, time and check):
a:=ranm(150,150)*0.1:;
time(b:=inv(a));
maxnorm(a*b-identity(a))
(10-16-2018 05:23 AM)parisse Wrote: [ -> ]You can do that for matrix inverses (no display, time and check):
time(b:=inv(a));
On my Prime (hardware version C) around 3.65 seconds.
On the emulator says 0.013 seconds, which seems impossible (7 year old Win7 laptop).
Both running latest beta firmware.
(10-21-2018 02:35 PM)John Keith Wrote: [ -> ] (10-16-2018 05:23 AM)parisse Wrote: [ -> ]You can do that for matrix inverses (no display, time and check):
time(b:=inv(a));
On my Prime (hardware version A around 3.713 seconds.
( Other runs: 3.71 ; 3.723 ; 3.72 ; 3.721 )
On the emulator says 0.024 seconds, which seems impossible (7 year old Win10 laptop).
( Other runs: 0.012 ; 0.0199 ; 0.0187 ; 0.0191 )
Former running 2.0.0.13865, latter running 2.1.14091 beta firmware.
AND
Xiaomi Mi Max 2 running HP Prime Pro 13443 : time= 0.532 seconds.
MIUI 9.6.3.0 Global Stable, Android 7.1.1, patch level 2018-06-01
( Other runs: 0.461 ; 0.434 ; 0.434 ; 0.425 ) - the duplicate is correct!
VPN
I confirm that inverting a 150x150 float matrices takes about 0.01s on my old laptop (7 years old) with Xcas. The emulator timing is perhaps correct (I don't know how precise it is).
(10-15-2018 09:32 PM)akmon Wrote: [ -> ] (10-15-2018 02:01 PM)StephenG1CMZ Wrote: [ -> ]On Android it can reach up to 141 before crashing.
G1
G2
In G1
In G2:
In G1
In G2:
After doing the same example with 14181 firmaware, InvMat(142) still crashes, but at least it restarts automatically, not needed to use a clip on its back. Curious, before restarting it warns you: "your unit will reboot in 3 seconds".
