09-24-2018, 09:35 AM
Program to Add Subtract Multiply and Divide Fractions.
Result is simplify to lowest term and convert to Mixed Fraction.
All the procedure is the same from previous post except
"When multiply or divide fraction first must press GTO 072 each time."
Add or Subtract Fractions with separate program for Multiply and Divide Fraction.
http://www.hpmuseum.org/forum/thread-11410.html
This program is the update version from the 12C Add Subtract Fractions with
Multiply and Divide.
Program included all arithmetic because HP-12C Platinum came with 400 program lines
that make it possible where the 12C need to break up in two separate programs.
Program: For Multiply and Divide First press GTO 072 on run mode.
001 STO 4 // Add or Subtract Fractions
002 Rv
003 STO 3
004 Rv
005 STO 2
006 Rv
007 STO 1
008 RCL 1
009 RCL 4
010 x
011 RCL 2
012 RCL 3
013 x
014 +
015 STO 6
016 RCL 2
017 RCL 4
018 x
019 STO 5
020 X≤Y // GCD routines
021 X<>Y
022 STO 8
023 X<>Y
024 STO 0
025 RCL 8
026 RCL 8
027 RCL 0
028 ÷
029 INTG
030 RCL 0
031 x
032 -
033 X=0
034 GTO 040
035 X<>Y
036 STO 8
037 X<>Y
038 STO 0
039 GTO 025
040 RCL 0
041 STO 7 // GCD result use for Lowest Term Fraction
042 RCL 5
043 RCL 7
044 ÷
045 RCL 6
046 RCL 7
047 ÷
048 R/S // Stop and Ready for Mixed Fraction
049 STO 0
050 X<>Y
051 X<>Y
052 ÷
053 LSTx
054 X<>Y
055 ENTER
056 FRAC
057 X<>Y
058 INTG
059 Rv
060 x
061 EEX
062 4
063 ÷
064 Rv
065 Rv
066 Rv
067 +
068 FIX 4
069 RCL 0
070 X<>Y
071 GTO 000 // Program end here
072 STO 4 // Start Multiply or Divide fraction
073 Rv
074 STO 3
075 Rv
076 STO 2
077 Rv
078 STO 1
079 RCL 4
080 1
081 X<>Y
082 X≤Y // Test for when input is negative integer then run Fraction Division
083 GTO 093
084 RCL 1
085 RCL 3
086 x
087 STO 5
088 RCL 2
089 RCL 4
090 x
091 STO 6
092 GTO 104
093 RCL 4
094 CHS
095 STO 4
096 RCL 1
097 RCL 4
098 x
099 STO 5
100 RCL 2
101 RCL 3
102 x
103 STO 6
104 RCL 6
105 RCL 5
106 X≤Y // GCD routines
107 X<>Y
108 STO 8
109 X<>Y
110 STO 0
111 RCL 8
112 RCL 8
113 RCL 0
114 ÷
115 INTG
116 RCL 0
117 x
118 -
119 X=0
120 GTO 126
121 X<>Y
122 STO 8
123 X<>Y
124 STO 0
125 GTO 111
126 RCL 0
127 STO 7 // GCD result use for Lowest Term Fraction
128 RCL 6
129 RCL 7
130 ÷
131 RCL 5
132 RCL 7
133 ÷
134 GTO 048 // Go to Mixed Fraction
Gamo
002 Rv
003 STO 3
004 Rv
005 STO 2
006 Rv
007 STO 1
008 RCL 1
009 RCL 4
010 x
011 RCL 2
012 RCL 3
013 x
014 +
015 STO 6
016 RCL 2
017 RCL 4
018 x
019 STO 5
021 X<>Y
022 STO 8
023 X<>Y
024 STO 0
025 RCL 8
026 RCL 8
027 RCL 0
028 ÷
029 INTG
030 RCL 0
031 x
032 -
033 X=0
034 GTO 040
035 X<>Y
036 STO 8
037 X<>Y
038 STO 0
039 GTO 025
040 RCL 0
042 RCL 5
043 RCL 7
044 ÷
045 RCL 6
046 RCL 7
047 ÷
049 STO 0
050 X<>Y
051 X<>Y
052 ÷
053 LSTx
054 X<>Y
055 ENTER
056 FRAC
057 X<>Y
058 INTG
059 Rv
060 x
061 EEX
062 4
063 ÷
064 Rv
065 Rv
066 Rv
067 +
068 FIX 4
069 RCL 0
070 X<>Y
073 Rv
074 STO 3
075 Rv
076 STO 2
077 Rv
078 STO 1
079 RCL 4
080 1
081 X<>Y
083 GTO 093
084 RCL 1
085 RCL 3
086 x
087 STO 5
088 RCL 2
089 RCL 4
090 x
091 STO 6
092 GTO 104
093 RCL 4
094 CHS
095 STO 4
096 RCL 1
097 RCL 4
098 x
099 STO 5
100 RCL 2
101 RCL 3
102 x
103 STO 6
104 RCL 6
105 RCL 5
107 X<>Y
108 STO 8
109 X<>Y
110 STO 0
111 RCL 8
112 RCL 8
113 RCL 0
114 ÷
115 INTG
116 RCL 0
117 x
118 -
119 X=0
120 GTO 126
121 X<>Y
122 STO 8
123 X<>Y
124 STO 0
125 GTO 111
126 RCL 0
128 RCL 6
129 RCL 7
130 ÷
131 RCL 5
132 RCL 7
133 ÷
Gamo
