Finally got around to scanning the Owner's Manual for the Sparcom Calculus Pac which was a plug-in ROM for the HP48SX. Please do with it whatever you wish, including adding it to any documentation collections.
http://holyjoe.net/hp/Sparcom_Calculus_Pac.pdf ◄
34MB, 222 pages, searchable PDF. The original was 8.5 inches high by 5.5 inches wide, spiral bound. The blank pages in the PDF were blank in the manual.
Great scanning job, thanks much for sharing it.
ÁM
Graet work!
is there somewhere the image of the card to use in an emulator?
Thanks very much for the scan. I have both the H.O.-48SX and 48GX.
I don’t have the Sparcom module. Is there a resource anywhere that lists all the programs on the module along with the source code?
(09-19-2018 07:24 PM)Joe Horn Wrote: [ -> ]Finally got around to scanning the Owner's Manual for the Sparcom Calculus Pac which was a plug-in ROM for the HP48SX. [...]
Many thanks, Joe! I vaguely remember beta-testing that one.
Can't thanks enough Joe Horn for scanning the manual and compsystem for point out where to download the file.
Edit: Attention - the manual does not relate to the dumped Rom link.
One is calculus PAC (manual)
The other is math pro (Rom dump)
FYI, this ended up on the HHC 2018 USB drive. Thanks Joe!
Necro Threading this topic as I picked up a broken for 48SX just to take apart and successfully fixed the ribbon connection. Its slow but for someone who only occasionally graphs a scattergram to see if the ole eqn fits, it does its job.
The Sparcom cards look like it might add some utility. That said.
I checked the 4shared site and *yikes* that lit up the system warnings like a pinball machine. Needless to say the operation was aborted. Does anyone happen to have saved the file? It might be good to have it on the MoHPC flash drive - I checked and didn't see it there.
Or please pop a less exciting link up.
Thanks!
Bill
