09-07-2018, 06:01 PM
09-07-2018, 08:44 PM
You can export all real variables from virtual calculator to the physical HP Prime calculator using Connectivity Kit. Open Connectivity Kit, connect Prime to computer, open virtual Prime. In calculator pane right click on VC «Real», then «Send to class». Then turn off physical calculator and turn it on. Now all real variables from Your VC are in Your Prime calculator.
This also works for Complex variables.
I do not know how to export only one variable or some variables, this is for all variables. I do not know how to export user variables, CAS variables.
09-07-2018, 11:28 PM
(09-07-2018 08:44 PM)Voldemar Wrote: [ -> ]You can export all real variables from virtual calculator to the physical HP Prime calculator using Connectivity Kit. Open Connectivity Kit, connect Prime to computer, open virtual Prime. In calculator pane right click on VC «Real», then «Send to class». Then turn off physical calculator and turn it on. Now all real variables from Your VC are in Your Prime calculator.
I would like to export user variables and CAS variables.
